Question about Compaq ( 277498-001) Motherboard
I have motherboard Compaq #277498-001 P5008640WP8N2BSM AS#253242-002 DG#011346 and can't find information for jumpers setting, please for help-marior77@abv.bg
  • marryor May 16, 2009
    About MB Compaq 277498-001 I can't find settings jumpers, please for help
  • 28 Answers
What model does this MB belong to? If it is a newerMB the only jumper settings you should see would be the clear BIOS jumper. Alot of the newer motherboard settings are done thru the BIOS.
http://www.compaq.com/cpq-country/cpq_support.html
try looking here
good luck
Posted on May 16, 2009
Were do u get HP UNLOCK CODES
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Mar 05, 2011 | HP Compaq Presario CQ61410US Notebook
Forgot password haw i can reset bios
May 20, 2010 | HP Compaq nx9030 Notebook
Don't reset password BIOS HP DC7100
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
Open the CPU casing locate the CMOS battery in motherboard and remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it. Good luck!
Oct 04, 2009 | Computers & Internet
Smsc motherboard jumpers setting(compaq presario 5000
no need jumpers, the smsc are being setup in the BIOS, enable it or disabled... go to BIOS Setup
Jun 19, 2009 | HP Compaq Presario 6310US (DA201A#ABA) PC...
Motherboard 277498-001 setting jumpers - help please
Visit http://www.compaq.com and select the product then download the user's manual. Such informations are usually given in the users mnual. Although Compaq is presently owned by HP, but user support is still there. (ehteshamhusain@gmail.com)
May 16, 2009 | Compaq ( 277498-001) Motherboard
Hi! i have mobo ms-6541 Ver:2.1, i would like to know the jumper configure can you help me?
I think the below link will be helpful just try it
Ms-6541 diagram
manual with jumpers information
I hope this will be helpful for you
all the best
Jan 05, 2009 | Compaq (252608-001) Motherboard
Im looking for the jumper settings on a compaq motherboared. its a presario 7478
hello CAVdesert,
I don't think you ever have to change the jumper settings on the motherboard.You may need to change in few cases but otherwise, changing motherboard jumper settings is not recommended.
However, if you need to configure the jumper settings for your Hard Drive, CD/DVD Drive etc, Please refer to the following document.
Jumper Settings for the Installation of Hard Disks and CD, CDRW, and DVD Drives
Oct 12, 2008 | Compaq Computers & Internet
Compaq-TPN10-01-Motherboard
F1 / DEL / CTRL + ESC / F2
Try any of the above
Oct 02, 2008 | Compaq (010391-001) Motherboard
Compaq presario 5340 motherboard jumper setting
search for the manual on the net.use its model number placed near the cpu socket.
May 22, 2008 | Compaq (252608-001) Motherboard
Compaq ( 277498-001) Motherboard Logo
472 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
