Question about MSI K8MM-V Motherboard
I want to install xp on sata but my floppy drive is not working so the mother board dose not detect the hdd.. what shall i do..??
  • armedman74 May 16, 2009
    i know how to boot from xp bootable cd, the problem is the motherboard is not detecting the sata hard disk.. previously i have to install the drivers from floppy drive by pressing F6 but now i don't have the floppy drive..
    "http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml"
    have used this method but this also didn't worked..
  • mohannilesh May 21, 2009
    i am unable to install window xp on my my sata drive with out floopy drive.
  • 28 Answers
Configure BIOS to boot from CD-R then boot from your XP CD-R and install o/s.
Posted on May 16, 2009
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
Mother board masi km4am-l H.D.D. 1 TRA WES 64MB when installing win xp hard not detected by win setup. I updated bios but not worked. advance thanks
you should not update the bios...the issue is the hard disk is on sata ...and you need a raid driver installed to detect the hdd...so ...either get into BIOS and under advanced features..look the place where the drives are detected..and select the hdd and look for a feature called AHCI ..and disable it ..and leave sata like ide..and save with f10 and restart ...after that the hdd will be seen ..
another way is to make a floppy disk with the raid driver on it (the one from the mothermoard drivers disk ) ..and when it ask you to press f6 for 3rd party software ...press it ..and insert the floppy ...it will pick up the raid driver and will go like a charm ..
if you do not have a floppy ..install a second cd drive ..and use a cd ..and after pressing f6 for 3rd party ..browse and point to the raid driver on the mobo driver cd ..
Jul 15, 2011 | MSI KM4AM-L VIA KM400A CHIPSET ULTRA...
Sata HDD NOT DETECTING IN XP SETUP
If you're using a scsi card and connecting the hard drive to the card you need to have the scsi set-up floppy disk. When the blue screen starts during windows installation watch the bottom of the screen. It will tell you to press F6 key then to insert the floppy disk.
If you're using a sata drive connected directly to the motherboard (not in a raid configuration) you shouldn't need anything but the windows disk. The motherboard drivers and utilities disk should have the files to create the scsi install disk.
Sep 11, 2009 | ASUS P5RD1-VM Motherboard
SATA drive not detected
If you will be loading xp on the new drive,You will just need to press F6 during the setup when ask if you want to install 3rd party driver,and follow the instruction and put the SATA driver disk in when ask.(Even during xp setup It will say SCSI device until all the drivers for it are loaded)
May 20, 2009 | Asrock P4V88 (P4V88 RAID) Motherboard
New SATA Hdd detection problem
Have you checked in the bios setup of the motherboard if your SATA ports are enabled?
Let me know if you need further assistance.
Regards,
Graemevm
Apr 19, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
Sata problem
WHEN BOOTING TO LOAD WINDOWS XP START AFRESH BY FORMATING YOUR HDD FIRST AND WHEN U DONE BOOT YOUR SYSTEM UP FROM YOUR CD ROM THE DRIVERS WILL GET DETECTED AUTOMATIC AND THAN START YOUR INSTALLION.
Feb 06, 2009 | PC Chips M955G Motherboard
Cannot install xp
your laptop has a sata harddisk if u have to install windowxp u need a sata hard disk driver then u can install in your laptop xp if u have have black xp there is option on it if ur using normol version of xp then u need a sata driver & u need one usb floppy drive u have make floppy of sata driver during the install u there is option came on when installation start of xp u have press f6 key & load sata driver from the floppy dirvie thne u can install in your laptop xp
Jan 10, 2009 | Fujitsu Siemens Computers & Internet
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
Sata hdd cant install
hi
go to your bios setup
go to advanced option your sata hdd is disable enable it.
if it is enable then boot your sys with bootable disk
go to dos mode.
type FDISK
Y
4 TO DISPLAY INFO OYUR PARTITION.
IF YOUR PARTITION ARE NON DOSE DELETE IT
THEN RESTART YOUR SYS.
U CAN INSTALL XP NOW.
Mar 25, 2008 | Mercury KVM800M Motherboard
MSI K8MM-V Motherboard Logo
252 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
