Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Okay, now I need to get to the thermostat to replace it.  How does the dryer cabinet come off?  I see screws on the back and top of the dryer.  Does the back come off or are the back, side and top all one piece that will lift off?   Or do I take apart the face and reach back to get at the thermo stat?
The front bottom panel comes off.
Posted on Oct 19, 2007
How to replace door switch on washer
The slanted panel between washer and dryer remove lean in look behind top of washer on each side the is a clamp remove screws you should now be able to remove top cover of washer and access switch.
Feb 05, 2014 | Maytag LSE7806A Top Load Stacked...
Washing machine doesn't drain properly and makes screeching noises and has burning rubber smell
On this model the drain pump bearings tend to out often. You can open the machine cabinet and check the pump for a coin or a screw or something of that nature that may have gotten into it and is hanging the pump. Mostly the bearing will be bad and the pump will need replacing. Here is a link to the part.
Jan 22, 2011 | Maytag LSE7806A Top Load Stacked...
Top Load Stacked Washer / Dryer Maytag lse7806ace -- washer will not run, except in spin cycle
I believe there is a fuse on the left side front under the front panel about a foot from the top of the washer.
Nov 20, 2010 | Maytag LSE7806A Top Load Stacked...
I have a maytag stackable washer/dryer and I need to change the water temperature switch. Does anyone know how to go about doing this? I already have the part.
you will need to remove the front panel screws which will allow you to remove the end caps off the front panel after removing the control knobs,then you can replace the temp switch by removing the screws off the controls main body
Mar 07, 2010 | Maytag LSE7806A Top Load Stacked...
LSE7806A Top Load Stacked Washer / Dryer . Do you know where I could get a fuse for this?
Yes. Any appliance parts supply house, either locally or on-line.
Regards, --W/D--
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won't agitate, drain or spin
it only has one block fuse and should be located somewhere close to where the power cord comes into the washer. Go here www.repairclinic.com/SSPartDetail.aspx?s=t-LSE7806A-%3d%3di435797&PartID=435797 this is what you need to check.
Mar 02, 2009 | Maytag LSE7806A Top Load Stacked...
Removal of front panel of a stack washer and dryer mod
Their are screws between the washer and dryer. Undo those and the screws inside the dryer, next too and below the lint trap.
Jan 17, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag Neptune stacked front load MLE2000AYW
I'm trying to remove the top cover in order to relace one of the fins inside the drum. The screws came loose and let go. I'm struggling to get the top off. Which screws in the from need removed to release the front? Thanks.
Jul 13, 2008 | Maytag LSE7806A Top Load Stacked...
Replacing the thermostat on LSE7806 dryer
The front panel has two screws to take if off.  You do not access fromt he back or top.
Oct 13, 2007 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
123 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
