Question about Pioneer (DVR-K16) DVD RW Dual Layer Burner
Dvd's & Cd's are not being read
Either cd or dvd and games are not being read the mechanism is trying internittantly but no whining of the disc can be heard at all, Its set at area 2 and all drivers are up to date, is this mechanical or drivers? my laptop is acer aspire 1640
Pioneer DVD RW DVR-K16 Problem
  • Pioneer Master
  • 19,396 Answers
When this happen the problem is usually the CD drive, even if a virus can cause same problem.
To test if the problem is software, go to bios or boot options, set primary bot device CD/DVD, and start the computer with a boot disk inside.When asked chose boot from CD.
If the computer does not see the dvd drive, and does not ask you if to boot from CD on this conditions, then you have a faulty DVD RW drive.
Try first removing the DVD drive and refitting it in place, after removing battery and unplugging the AC adapter cord.
If that does not work, you usually need to replace the driver, even if on rare circumstances a faulty motherboard can cause the same.
That is however quite unusual.
the most common is a faulty optical drive.
Posted on May 16, 2009
GoVideo DVD/VCR combo has a disc in it, and it plays, but I cannot ejecti it. I tried turn off machine and restart it but it still doesn't eject. It keeps reading the disc and plays the program.
there is a belt which is driven by a motor to open or close the tray. u place the disc on the try and the try loads the dvd/cd into the mechanism. the belt is loose & needs replacement. you have to open the cover & find the belt on the mechanism & replace with slightly shorter length of belt.
Sep 26, 2011 | GoVideo Go Video DVD/VCR Combo
Stopped playing after I inserted damp CD in 200 disc loading mechanism
this can be due to some moisture in lens.
leave the unit to get dry for 2 days.
Jul 04, 2008 | Kenwood DV-5700 Multi-disc DVD Player
Dvd/cd is not working
You can follow these methods to try to isolate and resolve the problem. Use these methods in the order in which they are presented.
Method 1: Clean the disc
When you have problems with a CD or DVD drive, always check the disc first to see whether it is damaged or dirty. To clean the disc, follow these steps:
1. Remove the disc from the drive.
2. Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth.
Note Do not use a paper cloth, and do not use a circular motion to clean the disc. These can scratch the disc.
3. Reinsert the disc in the CD or DVD drive.
If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to step 4.
4. Try again to clean the disc by using a cloth dampened with water, or dampened with a commercial CD or DVD cleaning solution.
5. Dry the disc thoroughly, and then reinsert it in the CD or DVD drive.
6. If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to method 2.
Method 2: Check the disc for damage
If the disc is clean, check whether it is damaged. To do this, follow these steps:
1. Remove the disc from the drive, and then examine the disc for scratches or cracks.
2. If the disc is damaged, try another disc to see whether the CD or DVD drive can read it.
3. If the computer still cannot read a disc, there may be a problem with the drive. Go to method 3 to troubleshoot the CD or DVD drive.
If the computer can read the other disc, there is a problem with original CD or DVD. Contact the manufacturer of the damaged disc to obtain a replacement.
Method 3: Try a different disc drive
If the disc is clean and undamaged, check whether there is a problem with the drive. To do this, follow these steps:
1. If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc.
If your computer does not have more than one disc drive, you can insert the disc in a different computer.
2. If the other CD or DVD drive can read the disc, there may be a problem with your CD or DVD drive. Go to method 5.
If the other CD or DVD drive cannot read the disc, the disc may not be compatible with the drive. Go to method 4.
Method 4: Make sure that the disc is compatible with the drive
Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
* A DVD disc is incompatible with a standard CD drive.
* A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
* A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
If the disc is compatible, go to method 5.
If the disc is incompatible, use a compatible disc or contact the vendor for a compatible replacement.
Method 5: Use Windows Update to check for updated drivers
If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing.
Good luck
Jan 21, 2011 | Computers & Internet
Can you play PC DVD ROM on an emachines E4026 Desktop PC. because i just had a game brought for me & when i try to load it , the computer reads it as a blank disc Any help appreciated ...
Based on the one and only specs sheet I could find for this model of emachine, it does have a DVD-ROM drive. So in theory it can. Does the unit play DVD Movies? if yes then it should work, try rebooting and then putting the disc in again. I assume the disc is clean and scratch free as the game is new.
If the OS on your computer has ever been reinstalled, you may be missing the driver for the drive, in which case windows would treat it as a generic CD-ROM drive, and not be able to read DVDs, you can get the drivers for the drive from the emachines website if this is the case.
Dec 25, 2010 | E-Machines emachines (emachinees) CD-ROM...
Cannot read Wii CD but can read GameCube CD
Have you tried more than one Wii game?
If you have tried more than one Wii game and none will read,
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Wii including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Wii going again!
http://store.richspsxparts.com/wiiredvddr.html
Sep 21, 2010 | Nintendo Wii Console
DVD-RAW Drive reads most DVDs But not reading this DVD
Visually inspect the bottom of the disc. Look for any medium to large scratches or pits. Try reading the DVD on a few different computers. If the DVD does not work on even some of the other computers, try taking the DVD to a used game store (GameStop/EB Games, for example) and ask them if they can restore the disc for you. They will probably charge you. If you are looking for a free method of cleaning up a disc, try taking glass cleaner (Windex, etc) and a paper towel to the bottom of the disc. Wipe the disc from inside out, not around in a circle. If all else fails, replace the disc.
May 13, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Just wandering if anyone else has reported problems with the Guitar Hero Metallica game. All my games other games work fine, i just bought this game and it wont read the cd. ive been back to the store and...
Is the disc a cd or a dvd? try copying the files inside that game and burn it on a mew cd or dvd then insert the disc into your game console and check if it reads. Pm me if it works or not. thank you..
Aug 07, 2009 | Sony PlayStation 2 (PS2) Console
When playing a DVD, picture & audio stop for a second one a while, no problem when playing a CD
this may just be the mechanism changing diretion as it reads the second layer on the disc usually because the film is too long to go on one side of the dvd disc.
quite normal.
but if happening quite a lot during playing a film then it could be something as simple as cleaning the mechanism. NOT for the untrained
Jun 01, 2009 | Teac DV-H550 DVD Player
DVD problem
Have you tried several DVDs? Maybe it doesn't read some types of DVDs.
Mar 21, 2007 | Dell Dimension 4600 PC Desktop
Pioneer (DVR-K16) DVD RW Dual Layer Burner Logo
597 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
