We are trying to do power point on infocus projector the picture is projected upside down help
  • 431 Answers
Hi this is Vortash check the menu and you will find that you have the setting on inverted or flipped ... see this site for user manual if you dont allready have one .. http://www.safemanuals.com
Regards Vortash
Posted on May 21, 2009
Can infocus IN1100 be installed upside down?
The only option for screen orientation is left-rght and right-left , and there doesn't seem to be an upside down option. So you are probably correct in that it cant be used upside down.
Jul 28, 2011 | InFocus IN1100 DLP Projector
Turning it back to normal after ceiling mount for LP755
hi,
1. perss menu button
2. select controls
3. then select ceiling projecton (When you turn Ceiling Projection on, the projector turns the image upside down for ceiling-mounted projection. Highlight Ceiling Projection, then click either button to select turn this feature on and off.)
ok
Dec 21, 2010 | InFocus LP 755 Multimedia Projector
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    Upside down images
    the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
    Jan 07, 2010 | InFocus In2102 Projector
    Need to invert the picture--ceiling mounted
    The SYSTEM menu provides options for ceiling mount and rear projection. From the main menu, select SYSTEM, move the cursor down to CEILING and then click the SELECT button. That should put a check mark on that option. Then go to PREVIOUS and finally EXIT the menu,
    Aug 19, 2008 | InFocus ScreenPlay 4805 Multimedia...
    Picture is upside down
    flip the projector over
    Apr 30, 2008 | InFocus IN36 Projector
    Reversing the picture on the monitor
    Here is the manual:
    ScreenPlay 4805 ScreenPlay 4805
    Check page 38 on picture settings, you can revers the image to project from behind a screen (mirror), I don' think you can have picture upside down (180 rotation) using projector settings. You need to reverse image source (eg. picture on computer).
    Apr 24, 2008 | InFocus ScreenPlay 4805 Multimedia...
    Televison & Video Logo
    69 people viewed this question
    Top Televison & Video Experts
