Question about Husqvarna 28cc Gas Line Trimmer
How do I get the trimmer head off a husqvarna 323rj?
I have dismantled the trimmer head. However, I cannot workout out to remove the part connected to the output shaft.
SOURCE: Husqvarna Gas Line Trimmer Head melting
Not necessarily solving your problem but I've owned 2 335RX brushcutters with shaft bearing problems. Depends on how far up the shaft gets hot. Bearing failure in the centre/upper bearings wouldn't be likely to melt the head. Dealers tell me the product isn't up to the job and don't recommend Husky trimmers/brushcutters to their customers.  Husqvarna UK are not interested.  Won't buy another Husky. The head may also be short of grease, causing the overheating. Take off the grease bolt and inject some in to see if it helps.  If it has been hot enough to melt the plastic head there has probably been damage to bearings and seals. Hope you solve your problem.
Posted on Apr 07, 2009
SOURCE: how to change blades
Use a large pair of pliers to hold the turning metal ring above the T35 trimmer head. I used a medium-sized pair of Channel Lock pliers. Then, turn the trimmer head counter-clockwise and it should unscrew from the mount. There's no need to open the trimmer head for this operation. Then, follow the parts diagram in the trimmer user manual to install the blade parts in the right order.
Posted on Jun 08, 2009
#1 Taper
  • 1040 Answers
SOURCE: Trimmer head wont spin on Husqvarna 125c. It seems
The drive shaft is not seated into position properly or the shaft has broken. Have you had the shaft off recently? If so, take the shaft off again and try to seat the shaft as you gently pull on the rope. If you need further assistance, just let me know.
Jim
Posted on Jun 15, 2009
  • 252 Answers
SOURCE: the trimmer head stopped turning What could be wrong
here is web site for parts
http://www.partstree.com/parts/?lc=husqvarna&mn=225+L+%281994-06%29
almost sounds like the driving drum engagement end has rounded off or the end of drive shaft broke off at either end , or the gear head end is broken / damaged
have a look at the splines on the output shaft on the gear head , check the plate that engages those splines too
physicaly take off the tube / shaft assy from power head and check drum and clutch rotating , check drive shaft end (s)
if ok refit tube / shaft assy ( make sure engaged properly)
tighten mount bolts - remove gear head from end of shaft, start motor and run see if shaft turns ok with some rev s if so
problem is in the gear head
check out website good site
cheers paul hope it helps
Posted on Aug 02, 2010
seabelow
  • 95 Answers
SOURCE: Husqvarna makes a trimmer that
What make you ask this question?
just check this out, it replaces the orig. head and all of Husq. have bumps unless you change it..
Tanaka head semi auto.
Posted on Nov 05, 2010
How do i remove the whole head off of husqvarna 128c
Hi,here is the illustrated diagram of the 128C trimmer head. Most strimmer heads screw on anticlockwise and require the inner head to be held or locked in order for it to screw on.
Apr 21, 2013 | Husqvarna Garden
Remove husqvarna 323l trimmer head
I'll send you a link to the owners manual, its all shown in there.
Aug 06, 2012 | Husqvarna 323L
How to restring a husqvarna 224L
To remove the head to restring, push in the bumper cap/side tabs on the strimmer head, the top should then just pull off exposing the inner spool.
Jul 24, 2012 | Husqvarna Weed Trimmer 224 L 4-stroke Line...
Can i remove cutting head from husqvarna 325c trimmer???
You should be able to if you can lock the arbor below the gear housing with some type of tool. I assume the shaft turns with the head (common problem).If not, maybe you can disconnect the lower gear head from the drive tube and then have a way to get the head off. Echo gear heads are easily removed...not sure about your Husky.
Aug 10, 2010 | Husqvarna 28cc Gas Line Trimmer
How do I remove the head from a Husqvarna 25 R weeedeater so I can load the string? It is a tap'n'go trimmer.
The plate that the head screws onto has a hole that a small diameter, provided straight shaft tool sticks in to lock the plate. Then it's just a matter of turning the head counterclockwise to remove it. Of course I lost mine and had to find the right shaft diameter screwdriver to do the job.
Jun 03, 2009 | Husqvarna 28cc Gas Line Trimmer
How to change blades
Mar 16, 2009 | Husqvarna Garden
Husqvarna 28cc Gas Line Trimmer Logo
673 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
