DVB usb dongle A05 / Ao5+ version 7.1d my
DVB usb dongle A05 / Ao5+ version 7.1d my installation disk has become damages and i have changed laptops.
Now i cannot find any downloads or re-install.
A05 on screen. Will not let me change temperature. Will not come on.
turn on heater ao5 comes on hit temp switch clicks but goes back and forth from ao5 to temp degree is it the printed circuit board please email at archieholdsworth@yahoo.com
Jan 08, 2016 | Comfort Zone CZ1500WC Infra-Red...
I have installed artista v3.0 software and dongle on a machine running Windows 98. When I open the software to run it says it cannot see the security device.
Dongle will not be recognized
NOTE - If you have encountered any of the following when installing your v5 BERNINA Embroidery Software:
After the computer reboot the screen will prompt for the new dongle but will NOT recognize it.
After the computer reboot the screen will prompt AND recognize the new dongle but never ask for or recognize the older dongle.
The software installation seems to complete but when attempting to open the program you will get the tool tips for a period of time then get taken back to your Desktop.
After rebooting the PC, you get an "error 7" message in the black DOS screen.
You may try one of the following (NOTE: Disconnect ALL USB devices from the computer EXCEPT for the version 5 dongle. If doing an update, attach the old dongle only when prompted):
1. If the version 5 software is installed, go to MY COMPUTER > Local Disk C: > Program Files > BERNINA > Embroidery Software > BIN folder and in the BIN folder will be a file called 'DATAGATHER' or 'DATAGATHER.EXE'. Locate this file and double-left click it to restart the 'verifying the security device' process and should finalize the brain transfer.
2. If step 1 was not successful, you will next need to try to run the REPAIR feature from the v5 install CD. To do this, reinsert the version 5 installation cd, and choose the REPAIR feature when you are asked to make a choice. Click NEXT and YES to finalize the REPAIR and restart the computer when prompted
Also doesn't look like it will run on Windows 98. It is SOOO Old! Version 5 won't anyway.
http://www.berninasoftware.com/faq-i710-p5343c140e7c855f8d1d842476841b61ef6b09596-sE.html
Sep 14, 2015 | Sewing Machines
I have an Acer 5321-1805 laptop and installed a Medalink version 3.0+ class2 dongle, but I can't print on my hp 6980 deskjet printer which also has a dongle installed. It pairs, but the printer driver...
Welcome to FixYa.
You have to configure the Bluetooth settings of the printer first. I assume that you have the HP bluetooth dongle on your printer.
Configure Bluetooth settings
You will need a USB cable to configure the Bluetooth settings
  • Connect a USB cable from your computer to the rear USB port on the printer.
  • Open the printer Toolbox.
  • Click the Configure Bluetooth Settings tab.
  • Configure the settings you want, and then click Apply
    Keep me posted.
Sep 09, 2011 | Computers & Internet
Bought dongle E173 works on dell computer Xpworks on laptop windows 7 but wont install on PC Specialist windows XP why ????
Hi there! If the E173 worked with your windows 7 then that means the E173 is working properly, try to check first if the PC specialist windows XP computer can detect the dongle if not then try to use a different USB port now if is detected but won't install try to find it in the drive go to my computer then look for the removable disk or the e173 then manually install it but if after trying different USB ports and the dongle is still not being detected then check if it is compatible with that computer or you can try to use another USB device to check if the ports are working properly.
Hope this helps!
Sep 01, 2011 | Microsoft Computers & Internet
My comfort zone infrared hearter has a display message of A05 and will not run, what does that mean? How can I fix it?
Hi. I have the Comfort zone 1500 (cz 1500) and just ran into this AO5 problem. Turns out the thermostat was set lower than the actual room temperature. I just turned up the heater temp and it kicked right on. Hope this helps!
Nov 16, 2010 | Comfort Zone Heating & Cooling
Sir i want to install a bluetooth facility in my laptop it is accer/emachines e727
The easiest way is to purchase a bluetooth dongle for your usb port. I use one myself- generally the install just involves running the drivers disk then inserting the dongle. I would personally recommend using one of the micro dongles that does not stick that far out from your system- I have broken 2 longer form factor adapters by having them get bent!
Oct 03, 2010 | Computers & Internet
A05 code
ao5 is showing on the display of my indiset de73 dishwasher
Aug 19, 2008 | Indesit 24 in. DE73 Evolution...
System error found Divio Fusion hdtv Software dvb-t version 3.68
system error found Divio Fusion hdtv Software dvb-t version 3.68
Solution:- Re set drivers off the Divio Web Site,the installation disk that came with the product was out of date being an earlier version.
Two attempts were made to install new up dated drivers,incorrect product description was selected from off the list at first before correct description in the 3.68 version was selected
globalpage
Jul 17, 2008 | Televison & Video
Indesit evolution de 73 dishwasher with an AO5 error code
a05 is pressure switch not reset. check for blockages in the drain pump, filters and sump
May 06, 2007 | Indesit 24 in. DE73 Evolution...
Computers & Internet Logo
744 people viewed this question
David Payne
David Payne
