T.V. problems Turned the t.v. on the green power light came on but no picture or audio. Tried to turn it off but the green light remains on and blinking. I tried unplugging the t.v. for a while but still the green light remained on and blinking when plugged back in.
  • 5 more comments
  • TASas Nov 04, 2007
    I have the same problem with my Samsung LTN1765.
  • maather Nov 16, 2007
    there is no audio there is no picture just screen colors every minute
  • dubcity Nov 24, 2007
    my sharp 37d43u is not turning on and its flashing green on the power led and the opc led but no pic or sound/
  • gift12 Nov 25, 2007
    panasonic th-42pd6ou red light blink off and on 8x no picture or sound had 6 month the same problem happened had it repaired now 7 months later the same problem.
  • ironflake Dec 01, 2007
    I have the same proble looks like turn on but nothing the green still on
  • jaemac Jan 06, 2008
    I have a polaroid LCD TV with the same problem I have a power ligt with no picture or sound
  • cigijojo Mar 13, 2008
    Same problem only the light on my TV is a red blinking light. No picture ,no sound, Just stopped working. Repairman says new modual is needed which will cost around $1000 when all is said and done. Don't think I'll bother. Will never buy another toshiba TV!!!
  • 25 Answers
Ok guys! This is a easy fix. just replace dried capacitors in power board. You need a ESR Capaciotr tester and find the culprit.
The cheapest I found is at matelectronics.
Posted on Feb 24, 2010
  • 3 Answers
Broken screen, how much to fix panasonic th-42pd6ou
Posted on Jan 06, 2010
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have no picture or audio on my TV. The green
It sure sounds like the mainpower supply problem, the power supply may be trying to turn itself off because it detects short circuits.
Nov 01, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
No picture, no sound, green light flicker ongoing
The power supply in the Tv has failed and should be looked at by a qualified technician.
Sep 09, 2009 | Samsung Televison & Video
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
May 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
Apr 10, 2009 | Actiontec GT704WG Wireless Router...
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
Televison & Video Logo
1,536 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
