Question about Mtd Garden
Neighbor has a Ranch King riding lawn mower Model 130650G205/E280X 12 HP 42 in deck. I think this is a 1980 unit? The deck height adjustment doesn't work smoothly. He bought it used without the owners manual. Is there a manual availabe on line so I can see how the deck was suppose to be installed and adjusted. There are broken springs and the deck gets wedged and will not stay level. This unit appears to be poorly designed. If I could see the manual I will be able to determine how it should have been installed and what might be missing or altered before he got the mower.
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
  • 153 Answers
SOURCE: ranch kind 16.5 horsepower riding lawnmower
A dead battery would be top of the list by far, followed by solenoid, keyswitch, wiring, starter in that order.
Posted on May 29, 2009
  • 636 Answers
SOURCE: mtd ranch king lawn mower drive belt
Try this site it is called manuals online, should be able download a manual for it for free, also for future reference would be nice.
Posted on Jul 11, 2009
lester482529
  • 226 Answers
SOURCE: Need manual 18Hp 46
go to partstree.com put in your make & model numbers.then click manuals;or go to the part your looking for ,they will show a diagram if needed hope this helps
Posted on Jul 15, 2009
mowerman1857
  • 389 Answers
SOURCE: hower do you do the adjusting for height on the
The dial only sets the height or the total deck, it is more of a stop than an adjuster.
If it seems too low in the front, you can adjust it by tightening the nuts on the 2 bolts/pins that are attached to the deck and the frame.
First of all, though, check your tire pressures, 10 psi in the rear and 14 psi in the front. If front pressures are too low, this will make a huge difference in your cut. You want to adjust the bolts an equal amount to maintain your side to side level keeping in mind that it should have 1/4 to 1/2 " difference front to rear.
Make your adjustments on your driveway or garage floor so you have a flat level surface to go by.
If you make these adjustments and it still scalps, you will either have to set the deck to cut a bit higher or approach the high spots from a different angle or remember to lift the deck up a bit with the handle when you get to those areas
Hope this solves your problem
Posted on Nov 03, 2009
How to adjust the deck height
left to right, there is a nut on each side between the deck and floor where your feet sit. front to back is the drag links attached to the front of the deck. adjust left/right first, then front to back. make sure tires are aired up before you do it.
Jul 15, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My lawm mower dont cut evenly
need to adjust deck side to side height and front to back height. this is usually in the owners manual. just search for your model number and you should be able to find it. if you cant, let me know and i will see if i can.
Jun 24, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What size belt fits 14.5 hp 42
Mower Deck 5/8" x 74" Kevlar TSC has for $24.
May 12, 2012 | Garden
How do you adjust the mower deck belt on a craftsman 21 hp 42 in. Deck Lawn Tractor
adjust in what manner . the lift lever raises it and lowers it .anti scalper wheels limit the height from the ground .
Oct 01, 2011 | Craftsman Garden
How to adjust the mowing deck properly?
Find a level surface (concrete garage floor for example) ... adjust front to back ... use a tape meadure to mneasure floor to deck edge ... then adjust side to side.
Jul 29, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hi, got a Craftsman 20 Hp 42 inch cut , the Deck will not lay flat, it is always on a angle. any ideas ? No matter what the cut height is set at.
Hi tubbed,
Most of these decks are held on at three points. Two are in line 90 degrees from front to back. The other is attached to the height adjust lever.
The first two are adjustable to change the type of angle problems you are having. Make sure you have the engine off when checking. Adjust until the desired angle is reached.
Also, if the model your problem is categorized under does not match your model, the cause of the angle and the solution may be different.
Best regards
Mike
Jul 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do I raise the blades
there should be a big bar on the right side of the mower that changes the deck height. if it only going up a little look for a height limiter dial on the other side of the mower about where the height adjustment bar is on the right side.
good luck and be careful!
Jul 01, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mowing the lawn high and low
Mowing the lawn low and hi can only mean where are the adjusters or which is best.
The best height for grass is about 2 - inches for my nickle. There is no best - it is to your taste.
As for adjustments on your unit they are done with the handle that sets your deck height.
Let me know if after reading the instructions you still need help.
thanks
Gary @ Fix Ya
Jun 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
20 hp 42 in. Deck Lawn Tractor - CA Model: can you give me a diagram for a craftsman mower de...
i have a 16.5 hp with a 42 deck for some reason one blade cuts alot lower then the other is there a way to adjust thanks
May 17, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
304 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
