Question about SSI America Neo Car Jukebox 20GB
Shut down I turned the unit on & now it will not shut off. I usually use the wired remote to operate & it has worked just fine, but I turned the unit on in the trunk & now it will not shut down.
There are 2 power buttons on this player. One on the actual device and one on remote. If you have one on, the other will not shut it off.
Posted on Dec 02, 2007
I have a 2004 Ford Ranger and when I try to remote start it, it starts but it sounds like its trying to start it again and then shuts off
If the truck starts fine with turn of the key in the ignition,look into finding the problem with the remote starter system.
Components maybe faulty or not proper.
Module.( Hidden underneath, usually somewhere under steering column area)
Receiver/Transmitter.( Mounted inside vehicle windshield )
Switch.( Under Hood,usually on the top radiator support bar )
Wiring.( all connected to the Module )
Fuse / Relay.
Remote / programming/ remote battery.
Connections that maybe loose,corroded, loose or wrongly connected.
Its also possible your vehicle might need a by pass module to connect with the remote starter module, to enable vehicle starting by remote.
Have a nice day.
Apr 17, 2016 | Vehicle Parts & Accessories
Beverage Air. Model: CFG24-1. The evaporator fan motor does not turn while unit is operating. The entire condensing unit is working, except the evaporator fan motor. When I removed the evaporator fan motor...
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Jan 19, 2011 | Beverage-Air CFG24 Freezer
Main remote control is not working can you bypass the remote temporarily
No. However you may be able reset the thermostat to its factory setting.
Turn the thermostat off.
Shut of the gas and water supply to the unit.
Unplug or disconnect the unit from its electrical power source. Disconnect the thermostat from the heater.
Wait approximately 5 to minutes, and then reattach the thermostat wires to the heater.
Turn the water supply on and open the tub faucet to its hottest setting for about a minute.
Turn the faucet off and make sure no water water is flowing anywhere in the house.
Turn the gas supply back on.
Reconnect the thermostat wires to the heater.
Connect or turn the power supply back on.
Wait at least 2 minutes before turning the thermostat power button back on.
After the thermostat power button has be pressed, wait an additional 2 minutes before running water.
Test the heater at this time. Turn the water on at the farthest faucet to its hottest setting. measure the temperature with a cooking thermometer.
If you need to make adjustments to the water temperature, either up down, shut all the faucets off first.
The thermostat should read 100 degrees Fahrenheit when it first starts.
If you are receiving an error massage, consult with the manufacturer.
If the thermostat is reading the correct water temperature but the unit is not operating, there are other issue need to deal with. Let us know if this works or you need further assistance.
Sep 26, 2010 | Rheem Tankless Water Heater Main Remote...
Door goes up on its own after using remote to close door upon returning home to find door is open
Make sure the door doesn't hit the floor and then reverse. If it does you need to adjust the 'down limit' which is on the side of the motor unit. Turn it a bit in the opposite direction of the arrow printed on the cover. You may also have a bad wall control or the wiring to it. The wall control goes bad from use and the staples holding the wiring sometimes cuts through the insulation and cause intermittent operation. You can eliminate this possibility by removing the wire on terminal #1 on the rear of the motor unit. You can eliminate the wall control by removing the wires connected to the back. Your remotes will still work.
Sep 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
My amp is working fine but turns off when i insert a CD
Hello pumpin_up_da,
The most likely cause for the problem you describe is that the remote turn-on lead to the amp is functional only when the head unit is operating in tuner mode. This could be caused by using a power antenna lead instead of a remote lead. Some head units have both, some only one or the other. Check the wire going to the amp remote terminal with a voltmeter. If it shows 12V when the radio is operated in tuner mode but 0V when you switch to CD, then check the wiring. If this is the cause, and your head unit has a dedicated amp turn-on lead, then connect it to the amp terminal. Most head units that have both power antenna and remote leads code them "Blue" and "Blue/White". If your head unit does not have an amp turn-on lead, you need to wire it to a 12V switched source, usually the "red" wire on most aftermarket receivers. You can then put a SPST toggle switch (available at Radio Shack or most auto parts stores) in line with the wire and turn it on and off as desired.
If the correct wire from your head unit is currently connected, then the receiver is defective and needs repair or replacement. Or, if everything else still functions normally, and really don't want to bother with repair or replacement, you can still use the 12V switched source as described above.
Hope this helps.
Jul 09, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Amp works fine when car not running...shuts down when car started
It could be a problem with the head units remote wire (blue wire) that connects to the amp. It turns on the amp when the head unit is turned on, Check that wire for 12+ volts when head unit is on.
Be sure the amp is properly grounded,and the input and output signal (speaker) wires are connected.
You could also use a temp. jumper wire at the amp by jumping the power and remote terminals, just to see if the amp works.
Note: Do not leave the temp. jumper in place, amps are not meant to be continuously powered up. Make sure it is in a well ventilated area so as to disperse its heat.
Good luck
Aduz
Mar 14, 2009 | Alphasonik PMA1800A Car Audio Amplifier
Genie 2020L - Garage door does not close using remote/pad
You have loose wire(s). After speaking with Genie Customer Service, they had me disconect a few of the wires and try operating the unit, to no avail. I noticed when reconnecting the wires that several other wires on the same row of connections were loose. I tightened all wire connections and VOILA, it works.
1.Open plastic cover in front of the Unit.
2. Look on upper right corner for a row of screws. Model 2020L has a verticle row of (6) connection screws numbered from top to bottom, 1-6. These screws connet to a green circuit board. Looks kind of like a video card from a computer.
3. Tighten all these screws top to bottom assuring good connection of all wires.
My contention is this. As the motor runs, it causes a vibration that tends to loosen those screws causing a faulty connection to the circuit board. Hope this works for you.
Delta Dan
Nov 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Mio digi walker 220
application MioUtility,exe has performed an illegal operation and will be shut down. if the problem persists, contact the program vendor
program:MioUtility,exe
Exception:0xC000000D
Address:8C06DF8C
Mar 20, 2008 | GPS
Receiver shuts down after loud bang
You said Unit is enclosed!! Does that mean it is inside something? Receivers & Amps need to have a clearance above them so air can circulate, otherwise you'll have an overheating problem. You also might have some of your wires crossed which will cause the Amp to shut down. Look at all your connections and make sure they're correct, including speaker wires.
Sep 22, 2007 | Audio Players & Recorders
SSI America Neo Car Jukebox 20GB Logo
369 people viewed this question
Top SSI America Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a SSI America Car Audio and Video Expert? Answer questions, earn points and help others
