Printer problem I have a lexmark z45 printer when i try to print the paper will not go all the way through it gets stuck before it gets to the rollers and will not print
  • margoa Aug 05, 2008
    The paper is drawn up to the roller but sticks there with about one quarter of the paper actually in the roller. The problem really started when the paper was drawn towards the roller but never was picked up. I open the paper drawer and the page is bent backwards toward the roller but still detached. Now it is picked up by the roller but sticks there.
    It appears that the rubber roller between the two white plastic wheels that guide the paper has cracked in several places.
Scanner not working why
Posted on Oct 10, 2008
Samsung 4100 laser printer, scanner, copier
The paper gets stuck in the roller and is not drawn up to the drum. The beginning of the problem started when the paper was never pulled from the drawer. When I open the paper drawer after a Paper Jam error, the paper is bent backward but still detached. Now it is drawn in but sticks.....margoa
Posted on Aug 05, 2008
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
I have a lexmark x2650 it wont feed the paper keeps jamming and not printing there is no paper stuck in it
try cleaning the paper supply roller with alcohol and a lint free cloth. if it helps for a short time, then you need to have someone replace the rollers in the paper supply
Feb 19, 2011 | Lexmark C533DN InkJet Printer
Lexmark z45 not working with windows xp. i installed a lexmark z45 on my laptop that has windows xp and it will not print
Check the printer status:
1 Click Start > Control Panel > Printers and Other Hardware > Printers and Faxes.
2 From the Printers folder, double-click the Lexmark Z45 printer icon.
3 From the Printer menu, make sure:
– Default Printer is selected.
– Pause Printing is not selected.
Check the printer port:
2 Click the Ports tab.
3 From the list of ports, select the USB printer port. If the USB port is not listed, uninstall and then reinstall the printer software.
4 Click Apply.
5 Click OK.
Make sure you have not installed multiple copies of the printer software:
Windows XP: From the Start menu, click Control Panel Printers and Other Hardware > Printers and Faxes.
In the Printers folder, make sure there is only one Lexmark Z45 printer icon. If you have installed multiple copies of the printer software, uninstall each copy. Then restart the computer and reinstall the printer software.
If the printer port is incorrect or you have installed multiple copies of the printer software, uninstall and then reinstall the printer software:
1 From the Start menu, click Programs or All Programs Lexmark Z45 Uninstall.
2 Follow the instructions on your screen to uninstall the printer software.
3 Restart your computer.
4 Reinstall the printer software
Oct 27, 2009 | Lexmark Color Z45 InkJet
Lexmark 2500 printer paper gets stuck and won't print
. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Mar 07, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper stuck while printing on lexmark X5470
You might have a little paper stuck inside your printer or just clean the pick-up roller with alcool and try it again.
Mar 25, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark Z45 printer won't print
I am the same user as the guest above, I just found a solution. I took mine apart. I found that (when looking at the unit from the front with the cover off with the gears on the left) the 3rd gear from the bottom left had a crack in it. It was the gear that turns the 4 large round rubber cylinders from underneath the paper. Anyway, I kept turning on/off until the crack was on top and then I dropped a drop of Super Glue (red cap version for use on Rubber/Plastic/etc.). I put a little pressure on it using 2 thin screwdrivers in the gear teath to compress it but in looking back I don't think that was necessary. I think the crack in the gear was causing mine to slip so just making it solid again helped enough to make one work like normal again. I'll see how long this holds up. Good Luck. Scott.
Mar 01, 2008 | Lexmark Color Z45 InkJet
Install lexmark Z45, don't have set up disk...
Just wanted to say this worked great for me and saved me from having to purchase a new printer. Thank you VERY much. The computer was in by budget, but not a new printer. Blessings!
Jan 17, 2008 | Computers & Internet
250 people viewed this question
k24674
jasbo
jasbo
