Question about Honeywell Programmable Thermostat Heater
Honeywell deluxe programmable thermostat 69-1402m
I have just had install a new heating system  with a Honeywell deluxe programmable thermostat  .The problem is it is set to Adaptive intelligent recovery which means it turns on every 10 minutes ,how do I switch it to conventional Recovery,my local installer has no idea how to do this. I am calling you from Ireland hence no local help with this as it seems to be new to the market.
  • rinville Oct 17, 2007
    re my problem with honeywell deluxe programmable thermostat set to adaptive intelligent recovery   my installer has no paper work on how to reset this unit to conventional recovery and as they are over 200 miles from my location I will have to find some way of adjusting  the unit by myself if I could find the code sequence to do this, as I am a retired electronics technichian  this should not be beyond me. any further help would be appreciated.  regards.
  • faith567 Nov 27, 2008
    I wan to increase the temperature from 12f to 20f, I tried to hold and set it at 20f but it always goes back to 12f and doesn't go up. Please help it's freezing in here. Programmable thermostat.
Solution #2 as above worked (thank you very much!) to get to the programming mode, but on mine keeping Function #13 on the default setting of "0" maintained the AIR.  Toggling the Temp button to "1" changed the system to conventional on/off at the programmed times.
Posted on Feb 07, 2008
For my Chronotherm IV Plus model I called Honeywell to turn off the AIR. Here's what they told me:
- Press Temp UP, DOWN, and i (information) all at the same time
- The number '4' and some other numbers/chars will appear
- Press Time to advance to Function 13
- Press Temp UP to change Function 13 to 0 (off)
Posted on Jan 07, 2008
    Problem Solver:
  • 7 Answers
Most new programmable thermostats have a installer set up menu that you must access through the tstat key pad, the instructions should be in the installer paper work not the user manual.since there are so many diff. types of prog. tstats today its hard to be specific telling you how to navigate the installer set up.
Posted on Oct 16, 2007
4 Suggested Answers
mikadot
  • 2113 Answers
SOURCE: i have a honeywell thermostat t6360.the light
Many thermostats have battery backup as well as the 24 volt ac. Have you replaced the batteries to see if it fixes all of your issues at once?
Posted on Nov 02, 2013
dorothyslaug
  • 5 Answers
SOURCE: The middle of the touchscreen of my Honeywell
it not a touch screen, its manual old style honeywell, square box, not round, not rectanglur.
Posted on Nov 03, 2013
Testimonial: "It is a touchscreen. I have seen references to the battery being round and lithium CR2450; however, not sure if this is accurate. Does anyone know?"
  • 571 Answers
SOURCE: round honeywell thermostat
Sounds like you have a T86 thermostat...take the round front cover off to view the Mercury switch. Watch the bulb when you change the temperature to a higher setpoint. If the bulb makes contact when rotating it up, and the furnace doesn't go into a call for heat, then it could be the thermostat, wiring, or furnace problem.
Posted on Dec 15, 2013
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
New programmable thermostats will not operate the furnace or air
did u turn the power off to unit before installing t-stats,if not then mabe blown low voltage fuse
Mar 28, 2009 | Honeywell Programmable Thermostat Heater
Non programmable Honeywell to programmable
the 230 doesnt sound compatable with your system. you are gonna need a t stat that is compatable with Heat Pumps.
Mar 18, 2009 | Honeywell Programmable Thermostat Heater
Wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Honeywell st7000
what type of system do you have? cool/gas heat, heat pump, electric cool & heat. split system or package unit?
Mar 14, 2008 | Honeywell Programmable Thermostat Heater
Wiring a Honeywell Deluxe Programmable Thermonstat
did you mark which terminals you removed the wires from on the old stat? If not you will need to look on the furnace and see what letters they are connected to .. then connect to the same on the thermostat.
Feb 11, 2008 | Honeywell Programmable Thermostat Heater
Installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
4,190 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
