Question about Microsoft Windows XP Home Edition
When I try to open email attachment, mess file does not have programs assiociataed to perform action. I checked the folders options, there is a jpg ext. there. My hard drive just crashed, did on line restore, thank god, but now just trying to get whole. Help.
  • Chris
    Chris May 11, 2010
    Just to confirm, is the email attachment XXXXXXXx.jpg or is it a different extension?
    Chris
    Master:
  • 118 Answers
SO GO TO THE FOLLOWING LINK
http://www.antiviruswala.com/XPDoctor.zip
THEN OPEN IT > INSEART UR OS DISK THEN CHANGE THE PATH OF I386 TO UR OS CD DRIVE /I386 THEN IT FINDS PROBLEMS WITH UR PC THEN U CAN DO ANYTHING PROPERLY & DON'T FORGET TO REASTART UR SYSTEM AFTER THE WIZARD COMPLETES
PLEASE VOTE FOR ME
Posted on May 19, 2009
How to scan documents to an email address
you should first right click on yoru destop and find "NEW" click on "make new folder", then type a name for the folder (anything you want). Now go to your scanner software and find the preferences and tell it to save scanned documents to your NEW folder. another option is to simply scan a document and when its done, click "file, save as" and save it to your new folder. When you are done scanning, open your email program and type in the email address to where you want to send the documents. when you are done typing the "subject" and a short note to whomever the mail is too, go to "insert" or "attachments" (varies depending on you email program). find the folder with your documents in it and hold down the "Cntrl"key and then click each file you wish to include. then click "ok" and all the files should now be attached to your email. BE AWARE, there may be a limit to how much data you can include in your email. If your email provider rejects your message due to file size being too large, simply send the files one at a time in multiple emails. There are also options out there (too numerous to list) that will allown you to send large files that are too big for your email program. I hope I haven't confused you. Good luck
Mar 23, 2011 | Gestetner DSc232 Copier
Hi, I can''t open PPV attachmnts in my outlook express. I downldd the progr from Mcrsft and when i open an attachment I get the following: this field does not have a folder associated with it 4...
Windows can't open files with .PPV file extension?
If Windows is unable to open files of PPV file type, you may not have the appropriate program installed or, you may have file extension related windows registry errors. To help, we strongly recommend you to run this (new version 2010).
Aug 08, 2010 | Dell Microsoft Windows XP Home Edition
Have rec'd email with a jpg file attached How can I open it
JPG, JPEG, are standard picture files. By default windows XP should be able to open them. But, sometimes Email programs block those files (attachments) because of infection potential. Check your mail security settings, specifically, look for a setting that says "block potentially harmful attachments" and uncheck it. then reopen your mail client program.
Aug 28, 2009 | Microsoft Windows XP Professional
Nero Photosnap Viewer Suddenly stopped working.
Let's say you cannot open JPG pics. This is what you have to do. 1) In explorer (My Computer), click Tools > Folder Options. 2) In the dialog box, click 'File Types' tab. 3) Scroll down until you see the JPG extension. 4) Select it and click 'Change' button below. 5) Select a program you want to use to open JPG files. (Windows Picture and Fax Viewer is the default program: You can select it.) 6) Click OK button. 7) If you have trouble opening other graphic types (BMP, GIF, PNG etc.) look for those extensions and repeat steps 4 to 6. 8) Click 'OK' button to close Folder Options dialog.
Jul 21, 2009 | Computers & Internet
Problem opening some attachments
You need to tell Windows what program you want to use when opening the file since you don't have any program installed that knows this file.
Do you know what kind of file it is? If not, you need to find this out.
Usually you get powerpoint or pdf files in your mail. To read these you need Adobe Acrobat Reader or Microsoft Powerpoint Viewer.
Short, You need to install a program that can handle the files you get in your mail. What program depends on the file.
To know what kind of file it is you have to se what "extension" it have (the three letters after the dot). Normaly you don't see this, but to be able to see it open Explorer and do go through the following:
  1. select Start -> Settings -> Control Panels -> Folder Options
  2. select the View tab
  3. check "show hidden files and folders"
  4. Uncheck "hide file extensions for known file types"
  5. Click OK to finish
Now, save the file on your desk and check the last letters of the file. If it ends with .pdg it's a pdf-file, if it ends with ppt it's a power point file.
If it ends with something else, it needs a different program. To know which, just ask again :)
Apr 07, 2009 | Microsoft Windows? Vista Home Premium...
Can't open .pdf file email attachments from Windows Mail (Vista)
Send yourself another known working PDF attachment and see if the same thing happens. If it does, post back. If not, then it most likely means there's either a naming issue with the problem PDF, or it is just corrupt enough to give you troubles when opening from email.
Mar 19, 2009 | Microsoft Computers & Internet
Outlook express not receiving mail or opening attachments
sounds like you need something to open the format of mail you are recieving ie winrar pdf adobe etc try downloading one of these and see if it works
Jan 24, 2009 | StarTech.com StarView SV211K 2-port KVM...
Unable to open .pps attachments from windows mail in windowsvista
If you have Windows XP:
Manual fix
  • Click Start, Run and type CONTROL FOLDERS
  • In the Folder Options applet that opens, select the File Types tab
  • Scroll down and locate the following entry:
PPS (Microsoft PowerPoint Slide Show)
  • Click Advanced
  • Click the New button
  • Type Open in the the Action: text box
  • In the Application used to perform action: field, type the following exactly:
For PowerPoint Viewer 2003:
"C:\Program Files\Microsoft Office\PowerPoint Viewer\pptview.exe" "%1"
For PowerPoint Viewer 2007:
"C:\Program Files\Microsoft Office\Office12\pptview.exe" "%1"
  • Uncheck the Use DDE box
  • Click OK, OK
  • Close the Folder Options dialog
-Tha Mp3 Doctor
Dec 31, 2008 | Microsoft Windows Vista Home Premium with...
I'm unable to open .eml attachment in Windows Vista.
Here's some info: E-mail message saved by Microsoft Outlook or other e-mail program; may also contain an e-mail attachment, or file sent with the message. Note: If EML files will not open in Outlook Express, try the following:
  1. Open My Computer.
  2. Select Folder Options from the Tools menu.
  3. Click the File Types tab.
  4. Under Registered file types, select EML Outlook Express Mail Message, then click Advanced.
  5. Click Open, then click Edit.
  6. Type the following line in the "Application used to perform action" box:
    "C:\Program Files\Outlook Express\MSIMN.EXE" /eml:%1
  7. Click OK twice, then close the window.
EML files may also be opened in Internet Explorer since they are formatted the same as .MHT files; changing the file extension from ".eml" to ".mht" should cause the file to open directly in Internet Explorer.
Hope this helps.
Dec 25, 2008 | Computers & Internet
Scanner
Hi
I found the solutiom from microsoft
1. On the Start menu, point to All Programs or Programs, point to Accessories, and then click Windows Explorer. 2. In Windows Explorer, edit the file type. To do this, follow these steps, as appropriate for the version of Windows that you are running: • For Microsoft Windows XP or Microsoft Windows Millennium Edition, follow these steps: a. On the Tools menu, click Folder Options. b. On the File Types tab, click URL:MailTo Protocol under the (NONE) section, and then click Advanced. c. Under Actions, click Open, and then click Edit. d. If you are running Microsoft Outlook 2002, type the following text under Application used to perform action: "C:\Program Files\Microsoft Office\Office10\OUTLOOK.EXE" -c IPM.Note /m "%1"If you are running Microsoft Office Outlook 2003, type the following text under Application used to perform action: "C:\Program Files\Microsoft Office\Office11\OUTLOOK.EXE" -c IPM.Note /m "%1"If you are running Microsoft Office Outlook 2007, type the following text under Application used to perform action: "C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE" -c IPM.Note /m "%1" e. Click OK two times. • For Microsoft Windows 98, follow these steps: a. On the View menu, click Folder Options. b. On the File Types tab, click URL:MailTo Protocol, and then click Edit. c. Under Actions, click Open, and then click Edit. d. If you are running Microsoft Outlook 2002, type the following text under Application used to perform action: "C:\Program Files\Microsoft Office\Office10\OUTLOOK.EXE" -c IPM.Note /m "%1"If you are running Microsoft Office Outlook 2003, type the following text under Application used to perform action: "C:\Program Files\Microsoft Office\Office11\OUTLOOK.EXE" -c IPM.Note /m "%1" e. Click OK two times. 3. In Internet Explorer, verify the e-mail program. To do this, follow these steps: a. On the Tools menu, click Internet Options. b. On the tab, change the default mail program to Outlook Express in the E-mail box, and then click Apply. c. In the E-mail box, change the default mail program back to Outlook, and then click Apply. d. Close the Internet Options dialog box. e. Click Start, click Run, type mailto:, and then click OK.
you can also visit http://support.microsoft.com/kb/312346
Hope this will solve the problem
Jun 04, 2008 | Brother MFC-8460N All-In-One Printer
Microsoft Windows XP Home Edition Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
