Question about Canon PowerShot S500 IXUS 500 Digital Camera
CF card slot cover
The CF card slot cover won't stay closed. Advice needed
    Genius:
  • 2,985 Answers
Is the card inserted correctly?
Is the card release button- under the cover locked down?
This needs two pushed to get it to lock in.
Posted on Oct 16, 2007
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
Sony Cybershot DSC-S600 won't stay on
Have you tryed rechargeable batterys on the camera, generally they are higher quality and should work better.
Jun 20, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
I closed camra without memory card in, now I cannot put card in as spring has not returned up.
I'm sorry for the difficulties you're experiencing in inserting the CF Card in the Memory Card slot on the Camera. Based on the information you have provided, it appears that the spring in the slot which gives pressure for the card is not working as expected. Please check the below picture and insert the card as shown in the figure even if the CF card eject button fully extend to resolve the issue. Close the door firmly after putting the Card in the slot.
Thanks for understanding. Please let me know if you require any clarifications.
Aug 13, 2011 | Canon PowerShot S60 Digital Camera
Canon Si5 Lens Error message. Have tried suggestions on line
Welcome to FixYa.
There where wo reasons why do you receive a "lens error".
1. CF card slot cover or battery cover opened with camera on
2 . CF card slot cover or battery cover opened while camera was recording to CF card
In this case you have to ensure that CF card cover and battery cover is closed while camera is turn on.
You also need to be careful not to block the camera lens when turning on. Lens will have issues while retracting if your hands or even small thing that will block the lens to retrack while in motion of turning on.
Thank you for using FixYa.
Apr 08, 2011 | Cameras
Canon 40d won't turn on, LCD is blank.
There are several different things that can cause the camera to not start up. Refer to your user manual to check each of these items. If you don't have your user manual, you can download it here.
1) The battery is not properly installed in the camera. (p.26)
2) Make sure the battery compartment cover is closed. (p.26)
3) Make sure the CF card slot cover is closed. (p.28)
In addition, the battery may not have been properly recharged. Double check that the charger is plugged into a working outlet, and double check that it shows that the battery is fully charged.
If none of these fix the problem then you have a defective camera - one of the switches for the battery compartment or the CF card slot cover may be not properly indicating that the door is closed. If that's the case, you need to either return it to the place of purchase as defective, or send it in to Canon for warranty repair.
Dec 26, 2008 | Canon EOS 40D Digital Camera
SD wifi
I would rather go for CF wifi card, because Panasonic doesn't states that this one has SDIO type slot. If you use CF slot you will have to find WIFI card cover - it's different one - it will allow to close top cover with the card inside.
There was also two models:
  • CF-P1P1CDZ6J - Bluetooth / wireless LAN built-in
  • CF-P1P1CZZ6J - Built-in wireless LAN-model
Apr 28, 2008 | Panasonic Toughbook CF-P1
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
How to replace CF card slot cover?
The door kind of sits in a channel on the case. It should fit with the rod and spring that holds the door closed/in place. You need to remove the old door, and maybe the back part of the camera (there are screws inside the battery compartment, dont' forget them!).
If you can't fix it, leave a note with an email address and maybe my company can fix it for you.
Nov 12, 2007 | Canon PowerShot A80 Digital Camera
CF for Jornada 525
The only advice that I could offer is to try those 2 Compact Flash cards on someone elses PocketPC. If they don't work then there must be something wrong with the cards. However, if they both work then there must be a problem with the CF slot on your Jornada. Try to test out some CF cards from an electronic store if they will let you. Yes, you do not need drivers for CF cards. A preferred CF list? Whomever told you this is blowing you off. People use all brands of CF cards from Viking, Scandisk, Lexar, Mr. Flash, etc. Sometimes there is a bad card and other times the CF slot is bad so check both of those out...
Sep 12, 2005 | HP Jornada 525 Pocket PC
CF card problem
Perform the following procedures if your camera does not detect a CF card. 1. Restart your camera. - Set the camera's power switch to and remove the batteries. - Open the CF card slot cover to make sure the CF card is securely set in the card slot. - Insert the batteries and turn the power switch . 2. Format a CF card. Format the CF card with your camera. Refer to the Camera User Guide supplied with your camera for instructions on formatting your card. 3. Check if your camera detects other CF cards (If you own multiple CF cards.) If your camera does not detect a CF card after performing the procedures 1 and 2 above, the card that wasn't detected may have a defect.
Aug 29, 2005 | Canon EOS-20D Digital Camera with 17-85mm...
Canon PowerShot S500 IXUS 500 Digital Camera Logo
136 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
