Question about Zyxel Prestige 600WH Wireless Router (91-004-164001)
Cannot understand what I do once I have 192.168.1.1 and password 1234 info from ZyXEL
I have been given 192.168.1.1 so that I can get a better signal on my lap top, with a defalt password of 1234 I log in to that number and all |I get is a page of different sites. Can you please advise. Thank you
  • 4,338 Answers
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Locate and download the User manual from ZyXEL site:
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420041221102511,420041221102520,420050117110858,420050117110916,420050117110934,420050831093216,420050831095441,420060420160946,420060420161739,420060816160116
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 16, 2009
Zyxel tm6841g default
This page gives you how to set up this router, which better called the P-600 series. Zyxel do not recognise it any more.
Default: Username: admin
Password: 1234
Default gateway: 192.168.1.1
http://pctechnotes.com/how-to-configure-zyxel-p-600-series-with-pldt-mydsl/
Jun 04, 2013 | NetGear DGND3300 RANGEMAX DUAL BAND...
How to change Pass word
Hello it depends on your router.
Read more here:
http://www.zyxel.com/support/knowledge_base/kb_detail_1850.shtml
http://www.default-password.info/zyxel/
Here is a video that shows how:
http://www.youtube.com/watch?v=19WI2dl-QU4
You might have to reset router to access the page.
Press the reset button at the back of your router for 30 sec.
and release.Wait for it to boot up again.
Now the router is set to factory settings.
Connect your lan cable to the router to one of the ports 1 to 4
and to your computer
To configure your router's wireless network open Internet Explorer and navigate to the router's configuration page by typing 192.168.1.1 into the address bar. When the page loads you will be prompted for your Router configuration password. By default this is 1234.
(You have to find the username and password first)
Try to download a manual for the router:
http://www.zyxel.com/support/download_library.shtml
Please select your model and number.
Do not use a easy password so others can use your internet connection.
Good luck
Nov 03, 2012 | Zyxel Computers & Internet
Forgot my SSID and password. how to make it work again
Best option is to log into the router and make a new one.
Plug the router into your computer using ethernet.
Open interent exploer and type into the address bar http://192.168.1.1
Username: admin
Password: 1234
This may be of some help to you
http://www.zyxel.co.uk/upload/doc/NBG334W%20User%20Guide.pdf
Apr 25, 2011 | Zyxel (91-004-361002) Wireless Router
My wireless router from Zyxel reset and is not on my home network any more, it is broadcasting an unsecure signal, how do I get it back on the network? FYI I have two routers one in the basement and one...
The easiest way to be able to access the router settings in this case, will be to provide a direct connection between your PC and the Zyxel router (using a network cable) and then type in that address.
If the address still doesn't work, double check the router's IP address by opening the Command Prompt (it's under Programs -> Accessories) and typing in "ipconfig", then hitting Enter. The IP-address you're looking for is listed under "default gateway".
(Also, make sure your computer isn't using a fixed IP, set it up so it's dynamically assigned an address by the Zyxel router.)
Mar 13, 2011 | Zyxel Prestige 660R Router (P660R)
Halo..i got a little problem wt my router.. ZYXEL PRESTIGE 660H-61 i forgot the password..can anybody help me to recover or break it.. I've tried to push reset button and use default password '1234' but...
if you can access net, go and download installation program for your router and re-install it.Or better if you have original CD. The only way to solve your problem is to reinstall program.
Oct 26, 2010 | Zyxel Prestige 660HW Wireless Router
What is my password how do I find it
Here is a list of possiblities assuming you have not configured a password yourself and forgot it, if you have forgot your own password your will have to reset the router to default setting by pressing in the reset button on the back, usually its very small and will require a tack, or perhaps a tooth pick.
Possible Usernames/Passwords:
admin/no password
admin 1234
admin/1234
no user name/admin
no user name/1234
root/1234
webadmin/1234
Apr 12, 2010 | Zyxel P320W 802.11G Wireless Firewall...
ZYXEL p-660 configuration for BSNL
in there you just give the dyanamic ip address automatically then you get it but you want to give it the go for the router mode in that you get it i just send a link you just download that think user giude then go througt it step by step ok
zyxel.com in that ftp server is there go througt it
May 05, 2009 | Zyxel Prestige 660R Router (P660R)
Zyxel Prestige 600WH Wireless Router (91-004-164001) Logo
295 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
