Question about Pit SSR 110CC Pro Beginner Bike
Carb hi my carb is leting fuel out of bottum pipe i have clean the flot but still doing it will this stop it from running
  • gogo22 May 11, 2010
    have you closed the screw on the bottom of the carb?
    Problem Solver:
  • 6 Answers
No i wold try cleaning out your carbarator
Posted on May 25, 2009
My activa some times its stopping fuel is not comming to carborator after waiting 10 to 15 minutes again it will start why
How do you know fuel is not coming into the carb? Have you removed the fuel inlet pipe into the carb and checked?
1. If yes, i.e. actually fuel flow is stopping into the carb, sometimes, then your vacuum petcock(the contraption just below the fuel tank- which allows fuel to flow into the carb)is malfunctioning due to a leak in the vacuum pipe( the pipe which goes from the vacuum petcock into the engine inlet manifold).
2. If NO, i.e. fuel flow into the carb is NOT stopping - then get your carb cleaned, especially the jets - both main & idle. Hope it helps.
Apr 17, 2014 | 2011 Honda Activa
Having problems after cleaning the carby on dt 175 fuel just comes out all tubes connected to it any ideas would be good
Check you needle and seed maybe needs replacing and most important is the flot level, I would start by striping the carb cleaning it and checking all the parts and jets inside clean and doing what it needs to do, like reducing petrol flow and the right time something is worn I would also replace the little rubbers if possible get a new carb kit if all else fails.
Nov 03, 2012 | Motorcycles
1988 mustang 2.3 has spark,fuel will not start
What you should check is firing order, any motor that has spark and petrol must at least back fire, when try to start, if it is still not doing that I would do a compression test to make sure compression is ok, then check the carb to make sure there is fuel in it and that the flot level in carb is correct check clean the carb all the jets and places where petrol flows through the carb, once you have completely clean and checked the carb then you know it's not the carb then you go to the next thing. Spark, is the bogie cables work properly replace them if it is shorting out against the body of the engine, replace the condenser that is on the side of the rotor cap those things are known to give trouble, they work sometimes and then it stops working, anyway good luck hope this is of use to you.
Nov 03, 2012 | 1988 Ford Mustang
Carbulator dosent stop the petrol and is goin out
the float in the carb is stuck open remove throttle body take out flot and needle clean them and try that the float could also be full of fuel with cracks or holes in it which makes it sink and doesent float to shut off fuel hope this makes sence
Aug 25, 2012 | Cars & Trucks
Carbs leak fuel at the overflo port on the bottom of the flot bowls when you open the screw gas comes out then stops for a minute then starts up again bike runs great just cant stop the leakn
i had the same problem and it was one of the float needles sticking so they was flooding either give it a good clean or change the needles
Mar 27, 2012 | Motorcycles
FUEL IN FLOT BOLE BUT NO FUEL GOING THUR
sounds like blocked pilot jets,clean out carbs
Aug 10, 2010 | 1995 Yamaha XV 535 Virago DX
Strange thigs about YAMAHA TW 125
Hi
I have been working on my carb today,the pipe from the bottom of the carb should just run down by the bottom of the swinging arm,there should be another pipe from the pipe on the left side of the carb just above the fuel intake which also runs down to the swinging arm and connect to nothing.
Cheers
May 30, 2009 | 2001 Yamaha TW 125
LEAKING FUEL
You need to get some new float needles, and have the carbs cleaned and the float heights set correctly.
May 30, 2009 | 2000 Suzuki GSX-R 600
Pit SSR 110CC Pro Beginner  Bike Logo
209 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Tim Rickards
Tim Rickards
Are you a Pit Cycling Expert? Answer questions, earn points and help others
