Question about Samsung SC-D353 Mini DV Digital Camcorder
LCD Screen is White
I have a Samsung SC-D353 miniDV Digital Camcorder.  It records videos and captures still pics just fine, but my lcd screen no longer shows what is being captured.  It only shows a white screen. Everything worked fine until a couple of months ago.  Will you help me please?
  • 2 more comments
  • jonodegaard Jul 16, 2008
    camcorder does not playback video, and was previously making high pitched noice and lines in video playback, but now no sound at all and no image either,
  • Anonymous Jul 27, 2008
    yes i too have the same problem what the hell is going on with samsung we should sue
  • Anonymous Aug 09, 2008
    I also have the same problem 1 day i used the camera and lines started to apear on the lcd the next day i went to check it and the screen was completely white.
  • jntt4425 Aug 19, 2008
    i have sc-d353 and the display screen is not clear
The ribbon cable you require is here:
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=1228041&query=Samsung%20VPD351&model=VPD351&path=98821,112905:98830
Posted on Oct 28, 2007
    Scholar:
  • 155 Answers
Yes, there is a flat cable that connect the display to the camera and after some time it brakes. If you replace the cable you will solve the problem. Be carefully it is not an easy job to do.
Posted on Oct 19, 2007
I have the same problem and it goes away when i completely flip the display. It looks like the inside ribbon cable need to be replaced.
Good luck
SOURCE:
Samsung sc-d353 lcd panel doesnt show any display
check with mains power if that works then battery stuffed
May 15, 2010 | Samsung SC-D353 Mini DV Digital Camcorder
LCD Screen goes white when you open it all the way.
The flex wire connecting LCD with camcorder is broken. I bought it in the repair shop and did it by miself. It's very common problem with LCD.
Good luck
Meggita
Sep 03, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
My lcd won't display a picture. it is white with colored lines going across it. If i flip the screen it used to show the picture, but now will just show a blank screen. I'm thinking there is something...
the connector between the LCD and internal parts of the camcorder is called RIBBON. based on what you said, you need to call Samsung hotline for repair of your camcorder
Jun 30, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Lcd display-tft active matrix -2.5 in - color
hi .probably the lcd screen cable is cracked..it will break shortly and the screen will be white or vertical line.. the cable that runs through the hinge on the screen needs to be replaced..this does seem to be a common fault with the rotating screens.. info on solutions if you attempt to do home repair...stefan
Jun 05, 2009 | Samsung Compact MiniDV Digital Camcorder
Not able to view anything on screen
I work on this model of samsung the lcd problem is a common thing with this camera
The ribbon cable to the lcd from the camera cracks and causes what you are talking about .
Normally the camera will still work buy using the eye viewfinder for recording and playback but you will not hear the sound unless the lcd door is open but then the picture in the viewfinder goes away when this door is open and comes back when it is closed
my email is spinboss@comcast.net and sell on ebay as uromastyx
Jan 25, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung MiniDV Digital Camcorder model SC-D353
Manufactured Oct 05, my Mini DV Camcorder SC D353 LCD screen went white with vertical colored lines when opened more than 1/4 of the way. I'm sure there had been less than 10 hours on it, so this is not a wear and tear issue. It's a component ill suited for the stress of a pivoting LCD screen.
After my internet research I've determined that the problem is a broken flexible lcd ribbon that cracks around the hinge / pivot joint.
After writing to Samsung USA and Samsung Canada, and getting the run around from them and service centers reparis and shipping exceeding the value of the camera and technicians telling me its not worth repairing, part prices ranging from $50 - $150, Samsung's finally referred me to the place, http://www.globalsemi.com/ .
I entered part number AD97-06489 and to my surprise found the part listed for $4.51, Canadian and located in Mississauga, just west of Toronto.
It is also found it here
http://www.encompassparts.com/products/?AD97-06489A
A picture here
http://www.partstore.com/Part/Samsung/Samsung/AD9706489A/New.aspx
So I'm going to pick up the part tomorrow and I'm going to try and do it myself. I think $4.51 is worth a try. Pray for me :) Cheers
PS Can anyone direct to the service manual?
Jan 19, 2008 | Samsung Compact MiniDV Digital Camcorder
Problem in my samsung sc-d353
the part is 40.. let me no if u need the part number. it is from turning the lcd around.. samsung did not engineer this properly
Nov 25, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Sc-d353
hi the ribbin in the lcd wears after a time it rubs on the side as you open the lcd a common fault i have just fix min £20 for new ribbin
Oct 12, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
SAMSUNG VP-D353 DIGITAL CAMCORDER
BAD CCD ( CHARGED COUPLER DEVICE ) THIS IS WHAT ALLOWS LIGHT IN YOUR LENS TO GET THE IMAGE
Jul 09, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung SC-D353 Mini DV Digital Camcorder Logo
851 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
