Question about Lands Phones
Hi I have aquired a second user Haier p7 Mobile Phone. I need instructions to turn on the ring tone as it does not ring at present. can you help me please. Many thanks Albert
  • mikewalters May 16, 2009
    Hi
    Thats the problem, at the moment I can't select any settings or options other than the phonebook?
    Any other suggestions?
    Thanks Albert
    hi
    Not so far. I have to go out for a bit. I'll try again later and get back to you.
    Thanks
    Albert
  • Lands Phones Master
  • 13,433 Answers
Hi
It was pretty difficult to find the documents for this p7 mobile. Actually all I got from Haier was a Normal 0 21 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} P7 Mobile Link User Manual which is for the pc software, I have that manual for that pc software and the driver and program for it. But no trace of user manual or owners manual for this product itself.
Basically what you will need to find from the player is a Volume, or ring tone volume setting, do you have a menu on the phone can you open something like settings or options and find it?
I have the above things I listed if you wish to have them, I can email them to you if you give me your address.
Posted on May 16, 2009
  • Ekse May 16, 2009
    You should be able to open the menu, possibly with another button? or is there a selector that goes on the screen if you press something?
My phone won't ring
If you are using Android phone you need to make sure that the ring-tone volume is not muted. Just goto setting and sound and then increase all the volume, sometime even if the phone is not in silent mode it won't ring due to Android sound settings . You can also use the volume rocker key to increase the ring tone volume. Just in case also change the ring-tone as well in case if the ring tone file is corrupt. Now try ringing your phone from another phone and see if that works. If it still doesn't work, just turn off your phone and take the battery out for 10 seconds and put it back. Try ringing it again. If nothing works, there might be problem with your built in speakers. And you need to contact the manufacturer.
It would be better if you could tell your phone make, model and mobile operating system name and version, to help you further.
Cheers!
Dec 27, 2013 | T-Mobile Concord
The User Manual does not explain how to change the ring tone, can you help please?
Hi gary468780 There are two ways by which you can change your samsung mobile phone ringtone . For changing ringtone of your cell use one of the following methods : 1} Go to Music option from main menu then you will get music library files to play and listen music if you like any song then you can set it as your ring tone by selecting option menu and then select set as Ring tone 2} Go to setting option from main menu and then select profile setting and then edit the profile setting after editing profile you will get another menu from which select Vice call ringtone option and then change ring tone and save it
Jun 06, 2011 | Samsung GTC3300 Cell Phone
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
I have purchased a mobile phone LG GS290 I need to connect the phone to the lap top to down load music to change my ring tone could you please tell me how to do this
Hi.
I have to download a software: http://www.lg.com/uk/support/mc-support/mobile-phone-support.jsp Click Download and the just follow the instructions there. After install you have to connect the phone to the PC by an USB cable.
After you download the file you want to use as a ringtone click on it, the music player will open, then click on the top left icon (the icon it seems like a page with 3 lines on it) and the scroll down to "use as" and click ring tone.
Also you can download the user manual using the software above.
Please don't forget to vote me.
Regards, Achil
Mar 12, 2011 | LG Cell Phones
Hai i am vino. i don't know how to download themes for samsung s3310 . pls help me...
Support for you phone can be found here:
http://www.samsung.com/in/consumer/mobile-phone/mobile-phone/multimedia-phone/GT-S3310ASAINS/index.idx?pagetype=prd_detail&tab=support
Mobile Phone : How to delete or download image / ringtones / wallpaper?
To download ring tone, picture and wallpaper you have two procedures. First get the Gprs activated by your Service Provider and download the same. Secondly get a data cable and download the same using Pc Link Software.
Through Gprs please follow the below mentioned steps:
Step 1. In the WAP browser, enter the URL. http://202.87.41.147/samsung/home_new.php
Step 2. Select Zone.
Step 3. Select option, (Game, image, Ring tone etc.)
Then follow the Instructions to Download images.
Through Data Cable please follow the below mentioned instructions:
For sending data from pc to mobile please use Pc Link software that is coming totally free with Samsung Mobile. For more information for data synchronization please refer to manual.
To delete a downloaded image,
Step 1. Go to "Fun box".
Step 2. Select "Download".
Step 3. Select "View Picture"
Step 4. Select "Option".
Step 5. Select "Delete".
Wallpaper can't be removed, you can only change it.
Trust this is what you are looking for. Please vote. :)
Dec 12, 2010 | Computers & Internet
Key tone volume
press the down button on the left hand side of the handset, this controlls the key volume
Sep 13, 2008 | Samsung U900 Soul Cellular Phone
I don't know how to change my text tone on my Samsung z400 there are no Sound options and when I click on the file I want to set as my tone, i click options and there a no options to set it as a...
hi,
To change the ringtone on your mobile phone please follow the instructions below:
Select 'Menu'
Select 'Settings'
Select 'Profiles'
Select the Profile you wish to edit
Select 'Options'
Select 'Edit'
Select 'Voice Call Ringtone or Text Tone'
Highlight required ring tone
Select required ring tone
display_flip('id4570', 'divId4570');
Jun 30, 2008 | Cell Phones
Cant get ring tone or phones to work
This question was posted on the troubleshooting page for the VT-9118. This answer is specific to this model; other models have slightly different sequences.
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Mar 13, 2008 | Vtech VT-9118 Cordless Phone
Set Up
I need User manual in English for initial setting up.
Feb 04, 2008 | Panasonic KX-TG1100 Cordless Phone
Phone not ringing
Just recently the Innovage LED touch screen phone stopped ringing. It has worked perfectly as a home office phone since Oct. 2005. Cannot find anything in the tiny manual to correct this problem.
Dec 26, 2007 | Vtech VT-9118 Cordless Phone
Lands Phones Logo
52 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
