Question about Dell Inspiron 1501 Notebook
My niece's Inspiron 1501 doesn't boot at all. The Dell splash screen comes up and goes to what I assume is the BIOS Screen that then displays the following error codes: PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broadcom PXE ROM. Operating System not found. When I go to the Setup screen after hitting an F key during the splash display, I can see from within the BIOS settings that the machine seems to be detecting all of its hardware EXCEPT the hard drive. I am assuming that this is a sign that her hard drive crashed big time and that the BIOS can't detect it, therefore, no booting. Sound logical?
It is also possible that the cable to connect the hard drive to the computer has gone bad or disconnected itself. This can sometimes happen in laptops. Try checking your hard drive using the system diagnostics in the BIOS settings, or by creating a Drive Fitness Test CD on another machine (http://www.hitachigst.com/hdd/support/download.htm). If neither of these detects your hard drive, it's very likely a connection issue. If you feel comfortable doing so, and it doesn't void your warranty, you can unscrew the cover on the bottom of the laptop and check the connection yourself. Make sure you're grounded, so you don't ruin anything with static discharge. If you don't have a screwdriver that small you can usually get one of those kits at the dollar store. They're the right size, but be careful because they will sometimes strip the screws. Good luck!
Posted on May 16, 2009
I have a dell involve laptop while i was trying to set back to factory specks i got locked out and it wont let me access any thing with out my administrator password and i don't no it what can i do to save...
No laptop is trashed when a password is lost. It just takes a little time to find out how to get into the system. I'll assume it is running XP Home that was originally installed on it from the specs I saw when researching. I'll also assume the password is not the one necessary to get into the BIOS CMOS setup- that one can normally be cleared by removing the CMOS battery and letting it set for a few hours or longer so the information is lost. The OS password can be cleared by making a bootable disk for that purpose. I have a Unix CD program that I made from information I downloaded from the Internet. You can do the same if you have access to a CD burner on another computer, say a friend's or one at work. I can get you the program's name if that's the route you want to take.
Dec 23, 2014 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 - black screen periodically
Hi,your problem could be as a result of a bad screen or screen connector(Flex)have a technician look at it.
Jan 02, 2010 | Computers & Internet
This is a Dell Inspiron 1420 laptop I'm trying to do recovery on it how do i get to my recovery button ? To start the recovery.
After the dell bios boot screen you should get a blank screen with a blue bar at the top saying www.dell.com when you get to that screen you need to press Ctrl+F11 and you should start the recovery partition
Dec 01, 2009 | Dell Inspiron 1501 Notebook
Installed a rangeplus adapter on dell 1000 inspiron xp sp3 home
See if you can go into safe mode by hitting the F8 key right after the dell splash screen and right before the XP splash screen comes up. If you can get into safe mode try to uninstall the rangeplus adapter and try reinstalling again after rebooting the system normally.
Nov 15, 2009 | Dell Inspiron 1000 Notebook
Dell Inspiron 1501 won't boot
The initial Dell Screen you see at the begining is your BIOS access. Push F12 repeatedly when you see this screen and it will take you into a system restore mode. It will let you boot from CD first (which your PC is not set up for). You should be able to start the CD fine from there.
Sep 21, 2009 | Dell InspironTM 1501 Notebook
Where is safe mode option on the DELL INSPIRON 1501
safe mode is appear on the screen before the normal windows system. all you have to do is press F8 or Function 8 before the normal system comes up. This procedure is only for technical assistance, whatever any changes on safe mode is your decision. Good Luck!
Jul 02, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 - tries to boot
Go into your BIOS by pressing F2 and make sure the cd drive is the first boot device. Install the operating system cd first and go thru that. Then you'll need to install the drivers and utilities disk. After that you can put the applications cd in and choose what programs you want to install off of that.
Thats the order you should install the cd's. Assuming your hard drive is good then everything should go thru. If you need more help then let me know and I'll help you as much as I can. I'll be here for a while.
When you boot up off of the operating system cd. It will say press any key to boot up off of the cd, be sure to do that so it boots up off of the cd and goes into the system setup.
May 26, 2009 | Dell Inspiron 1501 Notebook
I am trying to use the pc restore. to reformat my pc
You should try pressing F12 alone to get to the boot options menu, there you can select to boot from your restore cd.
Let us know
Good luck
Apr 15, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
424 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
