Question about Acer Aspire L100 PC Desktop
Acer L100 XPinstall, CD Drive not being dectected
Ive just wiped Vista of my system and installed a fresh new copy of XP onto the drive.
Installed all the other drivers (chipset gfx ect) and the CD drive isnt being detected. says its there but nothing.
  • 1 more comment
  • Adam Anon Oct 16, 2007
    No drivers found :/ The model is:
    Panasonic UJ-85j-B
    Its recognizing it  as a PCI device on the computer, and the connection on the drive has a converter cable on it. It plugs directly onto the drive, then the little converter spools out onto a ribbon cable that connected to the mobo.
    Anymore help?
  • Anonymous Feb 12, 2008
  • Anonymous Aug 12, 2008
    Problem Solver:
  • 10 Answers
I would if I was you, [1] go to Acer's website & make sure you have all drivers, [2] goto & download the ffree trial version of Everest. This software allows you to scan & diagnose the exact system details, motherboard/chipset etc..With this info you can then search for the exact items that are needed. Hope that helps
Posted on Mar 15, 2008
  • 2,985 Answers
If you are on line yet go to the drive makers web site for the driver.
Also go into BIOS to ensure it is active.
Posted on Oct 16, 2007
  • 979 Answers
Go to the "my computer" choice from "Start", right click on the drive icon and select "Properties". Make sure that all parameters are selected as per your system configuration....accordianman
I have a Acer Aspire 6920 that ran on Vista had a problem with it and the recovery 1 disk runs but the Disk two says it has nothing in in. Now all I get is Bootmgr is missing... I can not get new...
Unfortunately since you started the recovery process, your hard drive has most likely already been wiped, and without the second disk you will not be able to complete it, the disc may be damaged, or not have been written properly, I would first try to clean the disk simply by breathing moist air onto it then wiping it off with a soft cloth, if the problem is scratches there aren't really any options.
your other option is to install a copy of vista or another version of windows using a standard install disk, you should have a vista key printed on a sticker on the underside of the laptop, so if you know someone with a vista cd then it is perfectly legal to install with theirs and use your key. alternatively you could install xp or windows 7 , but you would have to purchase it, as well as go onto the acer site, going to support, and then downloads, and make sure there are device drivers for the operating system you are choosing. you will also have to do this if you use a vista cd from someone else, as a standard copy of windows will not include your systems hardware drivers as the acer recovery cd does.
please clarify what you mean by the HDD password is frozen. if you mean there is a password on it you do not know, often you are able to reset the bios completely by unplugging the system, removing the battery and holding down the power button for 60 seconds.
May 29, 2011 | Computers & Internet
I had vista and was installing windows 7 and got to the network part of the install and the system went to resart and it went to a black screen with a fashing curser and now i can not access anything on my...
guess u were trying to install Win7 over does not work that way....Win7 need to be a clean install...that must be installed in a new partition after doing a full low level you will have dual boot at start up...and u chose what u want vista or Win7 to work with for that specific session....
Dual boot helps in many ways...
1 - it helps file management better
2 - it helps to boot from one OS in case the other gives trouble
3 - virus attack are removed from either OS
etc etc
the best way to getback you system is to
1 download KILLDISK (DOS) utility program, get the DOS version
2 copy it on to a CD
3 get hold of a Win98 CD (bootable)
4 boot from Win98 cd, dont chose to install Win98,
5 press ESC and let Win98 quit installing, it will lead to a drive letter of you CDROM (say D or E as the case may be)
6 insert the CD that has the KILLDISK DOS utility
7 Run the program by typing KILLDISK at the CD drive letter prompt.
8 Read all the options available there...and kill the drive in which you had VistaOS/Win7 (C)...this will make all you C: drive sectors to "0"
i.e. it will wipe your C: drive clean and u can start with a clean slate....
if u r not concerned with the data in you disk...wipe all drives and disks in the PC....a 20GB disk will take aprox 1 hr to finish
for all this u must have the BIOS enabled to boot from CDROM drive...
once killdisk has finished doing the wiping process....
insert the Vista or Xp cd and install the partition option make 3 or more partitions....C, D, E of at least 30 GB min for Win7 will take aprox 18 GB....
in C: drive install Vista or XP as the case may be.....
once done....let the system boot and let it load Vista or XP
once in Desktop you can insert the Win7 cd and install it on the D or E: drive....the CDROM drive letter will change accordingly....when you make the be carefull to
let me know....
Jul 17, 2010 | Computers & Internet
Help me in formatting my hard disk
Put OS disk in shut off computer
restart computer
push ENTER to boot from cd- this is not happening.
It is possible that your OS disk isn't good
Apr 12, 2010 | Dell Dimension 2400 PC Desktop
How do i uninstall windows vista and making a clean dard drive
You would need a operating sytem cd/dvd (windows xp\windows 7) and a windows COA key. Select your bios to boot from cd\dvd player. Insert the new cd of a different operating system into the drive and restart the computer. It should say press any key to start from cd. Press any key and proceed. You will get to an option to format and install. Format the drive Probably marked C:. This will wipe out the drive and install a fresh copy of whatever OS cd you booted from. Good Luck.
Nov 24, 2009 | Microsoft Windows Vista Ultimate Edition
Copy windows vista from my laptop to my acer pc
you can not just copy vista. you would need to get an install cd of vista and install it onto the pc. this still may not fix your internet problem as there is no guarantee that vista will even have the drivers for your pc components.
Mar 10, 2009 | Acer Veriton 7600G PC Desktop
Factory settings?
Try this, if you are running xp i know it will work.
Start menu> All programs>Accessories>system tools>System restore.
This will restore your computer to factory and you won't loose any data. If you want to start fresh with nothing installed, install windows with the cd and choose fresh installation and follow the direcions.
Jan 22, 2009 | Acer Aspire 3610 Notebook
Resource cd for aspire 4315 laptop PC
Some Vista driver may work on XP, however, to avoid any risk of getting in troubles with your Windows xp installation, you can download drivers and utilities for XP starting from this page.
Jun 08, 2008 | Acer Aspire 4315 Notebook
How to remove windows vistra from a acer extensa 5220 and replace with windows xp
HAVE A VALID REGISTRATION KEY for WINDOWS — Microsoft will not let you upgrade your operating system with necessary patches until you VALIDATE your copy of Windows XP - by phone or online. If you try to update or format your system with a shared or borrowed copy of Windows XP, your result may be a crippled or non-working copy of Windows XP on your computer. You’ll need that 20 character number from your Windows Certificate of Authenticity. A certificate of Authenticity looks like the image below:
coa.jpg TO BEGIN:
1 ) Put the installation CD of XP or Windows 2000 into the CD drive and start the computer. Your computer should display “Press a key to start from CD”. You must boot from the CD because you’ll need to format the C: drive partition where Windows is installed on the hard drive.
If your computer is displaying a blue screen with white text, then you can proceed to step #2.
Your computer’s “Boot Order” tells the computer which device to check first when starting the computer. If your computer did not boot from the CD, you’ll need to power on your computer and press either the F2 or F10 or Del key — depending on your computer — to display your computer’s BIOS menu. In the Bios Menu, find the menu that allows you to change the “boot order” and make a change so that the computer will boot from the CD first, instead of the hard drive.
2 ) A blue screen with white text will be displayed. Press F8 to accept the Windows XP Licensing Agreement. The Windows XP Setup program will search for existing Windows installations and “repair or install fresh copy” will appear if a Windows installation currently exists on your machine. Press [Esc] (don’t repair).
3 ) A list of your computer’s disc partitions will be displayed. Press the UP or DOWN arrow keys to choose your main install partition. Note that your system partition must be a primary partition (usually the first partition that appears in the list), not a logical partition.
4 ) Once you have selected your main partition, press ENTER. “You already have a system installed” will be displayed if you already have Windows installed on this partition.
5 ) Press C to continue. From the options displayed, select “Format the partition using the NTFS file system” then press Enter. Windows XP can also run on FAT32, but the NTFS file system is recommended because it is more stable. You will receive a warning about formatting the drive unless the drive is brand-new -Press “F” to confirm you know that you will be formatting the drive. The disc formatting may take a while depending on the capacity of your hard drive.
6 ) The Windows XP install should begin automatically after the formatting is complete. If not, restart the computer with the Windows XP CD in the drive and follow the instructions for installing Windows XP. This can take 35 minutes or more depending on the speed of your computer.
7 ) Once Windows XP has been installed, connect the computer to the Internet, start the Internet Explorer browser, and visit to download and install the latest security patches and updates for your operating system. This could take up to an hour depending on the age and version of your freshly installed copy of Windows XP. When I did this last week, there were 79 security patches for the version of Windows XP that I installed.
8 ) Install the sound, video, modem, and other drivers that are specific to your computer and your operating system — as mentioned in the very first step. Follow the instructions as provided by your computer manufacturer. You may be told to restart your computer between installing some drivers according to your manufacturer’s directions.
9 ) Restart your computer, then select “Start > Help and Support” Click any update links you see to install the latest patches and drivers from Microsoft and from your computer manufacturer.
That’s it. Good luck!
May 23, 2008 | Acer Aspire 5100-5022 Notebook
Acer Aspire 5000 CD Drive Problem
1.this is not a problem of your operating don't format again. must install the drivers for the CD rom.
3.if not fix it is a problem in the circuit board of CD rom,very difficult to fix.
Mar 01, 2008 | Acer (91.AB264.023) Internal 32x CD-ROM...
Install win xp and erase win vista
Would like too know how to erase win vista and install win xp
Dec 29, 2007 | Microsoft Windows XP Professional With...
Acer Aspire L100 PC Desktop Logo
168 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
