Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
When i open call of duty 2 it shows that 18 sound files are missing or in a bad condition what do i do.
  • 49 Answers
U need to re-install it.
Posted on May 29, 2009
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
My 1991 ford F350 w/460 EFI is really hard to start after sitting for a week or so, and once I have it running it does not want to rev. It pops and misses, almost like a bad mass air flow sensor.
Sounds like a lean misfire condition. Have you run a fuel pressure test? Should be 55-60 lbs. If pressure is ok during idle and reving, Ttry disconnecting MAF and see if any difference on accel.
Apr 11, 2015 | 1991 Ford F350
Call of duty black ops 2 will not load, Have reloaded but to no avail. Keeps saying DXG1.DLL is missing
DLL stands for Dynamic Link Library
One of the files necessary for the game to initialize is missing. you may need to uninstall the game and make sure your OS is updated with the most recent frame work.
Mar 24, 2013 | Activision Call of Duty: Black Ops PC...
There is no wire feed through nor a spark. The fan comes on but. No arc
Check to make sure there is an open circuit voltage across the ground lead and the welding tip. Open circuit can vary from 18 to about 40 volts.
If you do not see that, open it up and check the condition of the fusible link inside the cabinet. If you overheated unit by exceeding the duty cycle, it may have simply melted open.
Dec 27, 2011 | Lincoln Welding Tools
Engine misfires and tacho flutters at around 5000rpm it can be very vicious problem has worsened no fault code showing do you recomend changing spark plugs
Hi, Tom and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark.
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP sensor.
9. Intake air leak.
10. Water, dirt, or rust in the fuel system, carburetor and/or filter.
11. Fuel tank vent system plugged or carburetor vent line closed off.
12. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
13. Carburetor controls misadjusted.
14. Damaged carburetor.
15. Incorrect valve timing.
16. Weak or broken valve springs.
17. Damaged intake or exhaust valve.
18. Check for engine trouble codes
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
5000 rpm engine flutter motorcycles
http://forums.cycleworld.com/showthread.php?t=88599
https://r1videos.files.wordpress.com/2011/04/2002-2003-yamaha-r1-service-manual.pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Aug 26, 2011 | Yamaha YZF-R1 Motorcycles
Hi when i trying to load os it gives crc error sometimes at 4% sometimes at 18 % please help
Issue:
Cyclic Redundancy Check or CRC error.
Cause:
This error message could be generated by any of the below reasons.
1. During the transmission of the file it became corrupt or bad
2. The file was sent inappropriately
3. The device being opened from is bad or contains errors
4. The file itself is bad or the program attempting to open the file is bad.
Jan 05, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
Audio problem
possible conditions of malfunctioning audio on PC desktop
Hardware conditions
1. The computer speakers are malfunct
a. The computer speakers have a blowout
b. The computer speaker are misconnections to the computer
software condition
1. The computer has missing audio programs
a. A restoration of the computer program systems requires peripheral system function adjustments or updates
Repairing computer hardware malfunctions
1. check for misconnections between computer to speakers. The speaker connectors should be inserted in the audio output posts on the computer.
2. A restored computer to new version of operating system would have obmitted the patch codes to a speaker that was disconnected during the process.
Repairing computer software malfunctions
1. Open up a multimedia player on the programs menu, examples windows media player, real one player, jukebox players, apple players.
a. Select a soud file from the player list category to be played.
b. A functional media player would display a sound file represented with a status bar about the sequence of motion generate.
c. The sound at which point requires out devices like speakers attachments to the computer ports to be heard.
4. A connected computer speakers should display sounds of the clips being played on two conditions
a. First, the sould loudness has not been muted to a shut down
b. Second, the sould loudeness has not been reduced least being heard
Important notes
1. hardwares required to generate sound from a computer, an intergrated speaker on the monitor or an external speaker device connected to the system tower unit,
2. Software programs on the system unit are available, examples real media players
3.A system restore to computer defaults alters the conditions of connectable devices like speakers requiring adjustments. Note, a missing program contributing towards achieving sound soon after a media player has been launched, a sound file selected, would display a message prompt requiring UPDATES, UPGRADES or MISSING DRIVER CODES
contact expert technical support
Dec 20, 2010 | Computers & Internet
No sounds are coming from my speakers or headphones
Hi friend,
firstly you check,sound driver is available in your system or not,as per your comment i think sound driver is missing in your system.
follw the given instruction and check sound driver is available on not.
1- right clieck of "My Computer" icon
2- Chose the Manage option.
3- Go to the Device Manager option
4-Check Audio,video driver (if yeloow indication are showing in audio,video option)
Thats means sound driver are missing or need to be upgrade.
(Go to control pannel and open "Sound and Audio Devices" properties if all the options under it is disable thats means audio driver is missing)
When you parchase the system you carry a motherboard CD,put in that cd into cd drive and install the appropriate drivers,if you have no Cd in that condition you download the drivers from net,
Thanks,,,,,
Mar 19, 2010 | Dell OptiPlex GX240 PC Desktop
Ps2
some of the game file is missing.some exe file is missing in the dvd
Jul 17, 2008 | Sony PlayStation 2 (PS2) Console
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
110 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Shawn DuRee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
