Question about Compaq Presario 5000 PC Desktop
I have a compaq pessario 5000 laptop. Hard disk is formated with no drivers for windows xp. If I am able o get connected to internet I can dowload all the drivers.
  • 3 Answers
Call your computer engineer with all windows driver disks or use the cd you got with your laptop.
Posted on May 16, 2009
Is a compaq presario 5000/8000 quick restore cd compatible with a compaq presario 2175us laptop?
I guess not. Drivers for compaq presario 5000/8000, are not the same as those for a compaq presario 2175us laptop. Now, actually that "notebook" looks to me rather outdated. You won't lose anything by trying. Worst case, format hard drive and install Windows XP SP3. Try to search internet for missing drivers.
May 15, 2015 | Compaq Computers & Internet
How do i re install windows xp on my compaq presario 5000
If you place your XP OS disc in the DVD/CD drive and boot from it, let the OS disc format your hard drive and there you are, when it has finished, all done. XP on your hard drive.
All you have to do then is try and find the drivers you need. Good luck as XP is no longer supported.
Feb 14, 2011 | Compaq Presario 5000 PC Desktop
I replaced a hard drive and after loading windows xp, my laptop wont boot, it only gives a hard drive read error.
Remove it then insert again. if the problem as is use another hard drive... also check the set up setting of your unit.
Aug 19, 2010 | HP Compaq Evo n800c Notebook
Desktop won't boot up
it has to be your hardware problem must be your keyboard connection or hard disk failure
Jul 15, 2010 | Compaq Presario 5000 PC Desktop
I have a Compaq Presario 2715US. Started having
The problem maybe a loose electrical connection with the RAM modules and hard disk. Re-seat the RAM modules and the hard disk.
If the problem persists then the hard disk maybe faulty.
To test the hard disk, remove the hard disk and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If this computer has trouble seeing it as an external hard drive and unable to open the folders and files then the hard disk is faulty.
Then the hard disk needs to be replaced in the Compaq and Windows XP needs to installed on the new hard drive and the device drivers and programs.
Oct 12, 2009 | Compaq Presario 2715US Notebook
How to install windows xp into compaq presario cq40
compaq cq40 is one particular model from compaq which is literally designed for vista and when you want to install win xp ;it doesn't work becoz the BIOS block it;the only way out is to downgrade the system BIOS which is a risky thing.check your bios model and version and google for a lower version and download it and flash the ealier BIOS.gooogle more on How to downgrade BIOS
Sep 21, 2009 | HP Compaq Presario CQ50Z-AMD Sempron(TM)...
I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
May 04, 2009 | Compaq Evo N610C Notebook
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Installing windows xp
You cannot install Windows XP over WIndows Vista. Microsoft has put a lock on the Vista software and will not allow you to downgrade to a lower software. The only way you can do it is to wipe your hard drive completely clean first with a disk deleting software or with the command "fdisk" at the DOS prompt. However, this is dangerous and I do not recommend it unless you have someone professionally trained to do it. It will wipe everything off of your disk and then you can load Windows XP.
Don't forget to rate his solution with 4 stars before you log out.
Jan 27, 2009 | Compaq Presario C700T Notebook
Have no discs to reboot system
Xp was corrupt and had to be rebooted useing a new Xp disk, Also Hard Drive was not formatted correctly Needed new Hard Drive.
Dec 13, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Compaq Presario 5000 PC Desktop Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
