Question about Compaq Computers & Internet
As soon as i connect the mains supply green light on front panel comes on then out then red front panel flashes four times then wait then four times etc...
As soon as i connect the mains supply green light comes on then out then red light flashes four times then wait then four times ...
  • bray273 May 20, 2009
    thank u for your help i did look at the hp website but came to a dead end when it sujested compleate replacement!!! as it is a small form pc the psu is speicial size so i got down to it and repaired it myself (switch mode controler ic bad) now working ok BUT boots up then says 'clock battery low needs replacing ...reolace and set time and date in your op system'. ive replaced the battery tried to set the date in the bios still get the same message ...cant set the date in xp as xp will not load all i get is the windows screen with the loading bar running then back to the error message... any ideas??? regards geoffrey
  • Compaq Master
  • 4,338 Answers
Here is a HP/Compaq document to help you diagnose the issue:
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=uk&dlc=en&docname=bph06788
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 16, 2009
  • JDTec
    JDTec May 20, 2009
    Power off the PC......
    Take the battery out and short the 2 connections in the battery holder. Then replace the battery, power up and set the time in Bios. Date and Time should stay permanently.
Red light and 2 green lights on front panel on.
This is an error code it means the TV is in protection mode. Which means it has detected a problem and is preventing power up so not to cause further damage. Error codes are generally 2 numbers 1 seq of flashes a pause and a second sequence of flashes. Most common problems for LCD are Video logic / Main input board or the power supply. For more info and possible solutions post your make and model.
For parts and info check.
http://www.RNS-Systems.com
or E-bay
Oct 20, 2009 | Televison & Video
Does not power on
ok on pioneer most of the time it is because of bad connections all over the main power supply board solder these and see what happens like i said most of the times it starts with bad connections.
Nov 18, 2007 | Pioneer PRO-119 60" Rear Projection...
Battery light green, then flashes four times red, repeats
remove the battery
clean the connecting ends of ur laptop & battery,
plug it back in & then start it...
Aug 27, 2009 | Dell Latitude D600 Notebook
When comp pluged in just a green flashing light
If you are sure that the 110 volt power is coming into the computer then the most likely problem is that th epower supply died. Obtain a new one of the same or larger wattagge as the one you are replacing . It does nto have to come from the manufacture of the computer.
Nov 26, 2008 | Compaq Presario SR1000T (568657) PC...
TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Aug 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Thomson DTI6300-16 digital TV recorder frozen, red light on constantly, no resposnse to any commands. I think it needs a factory reset - how do I do this?
Try Resetting the box to its factory setting:
  • Menu > Setup > Help
  • Then press the Green Button (Even though it doesn't show as an option)
  • Then press the Red button for a full reset
Warning: You will lose all data on the Hard Disk!
I did this when mine wouldn't record anything and dumped all my pre-recorded programs.
Worked a treat.
Jul 20, 2008 | Televison & Video
TV will not turn
Please unplug the tv for 30 min and then plug it back to power supply and see if the lights are blinking again...
Good luck......
Jul 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
TV won't turn on.
The problem is the digital main board if you can get ashop to order it for you its easy to replace yourself four screws and three or four plug in connectors.
Jun 30, 2008 | Sylvania LC320SS8 32 in. LCD Television
Philips 42PF9630A 42 in. Plasma 42 in. Plasma
Ok 7 red blinking led, remove the back cover of the TV. Looking at the power supply in the upper left of power supply. If everything is working fine you will see a solid green led if there is an error, you will see this light blinking also. Right below this led on the power board you will see a list of numbers 1-13 this will give u the problems that this led flashing problems are. More and likely u will have a problem with VSET or VSCAN. Which is connected to the Y-Main and Y-buffers,( the board that is too the left of the power supply if u look on the small print on this board you will see that it reads. 42HDV4 Ymain and the 2 small boards connected to it are Y buffers. To be sure that this board is bad if the TV keeps going into error protection. unplug the power supply and wait for the led to stop flashing. Disconnect the cable that plugs into Y-Main from the Power Supply. It should stay running. If u remove this board and look underneath u should be able to see where this board is getting hot. Easiest fix is to order a replacement. Y-main assembly.
May 05, 2008 | Televison & Video
Plasma turened off and red light flases twice
Red flashing x2 = Panel power supply fault
It would be easier to replace the power board than attempt a repair at component level (dangerous voltages)
Oct 13, 2007 | Pioneer PureVision PDP-504HDE 43 in....
Computers & Internet Logo
208 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
