Question about Network Engines, Inc. (SYS-NEI100-000) Firewall
Driving along suddenly engine oil light comes on then car stalls timing belt is ok but like no oil getting to head
  • philipcroft1 May 16, 2009
    o its a 2000 vectra 2.5 v6
  • 88 Answers
Sounds like the oil pick up pipe blockedin the sump
Posted on Jan 20, 2010
Periodically, EPS comes on Dashboard ,then steering becomes too hard, this will disappear two to three times re start the vehicle or running few meters and switch off the car and re start the car.
well I can't drive it and see all symptoms.
i can't see the idle speed drop below 800 RPM,. !
if the idle drops real low, then engine shakes, and PS gets weaker.
Id ignore the EPS till such time as all other things are perfect.
ever get an engine tuneup this decade?
low engine RPM , top number 1 cause is owners not servicing their cars. (spark plugs bad tops that list)
if you ignore that, tuneup the engine WILL misfire and RPM will drop and P/s (means power steering)will get weak (the assist is pump driven) and then the engine can stall.
i bet you also forgot to say the steering got weak
park or coming to a stop with foot off throttle.
do the head lights dim as this (bad) happens?
can you use your right foot to keep RPM above 800 and save stalls or near stalls?
IF RPM is ok, ?then check the fan belt next. (slips)
or buy a new on, my guess is 11 year old belt is kinda hopeless case.
Aug 14, 2015 | 2004 Suzuki Swift
Oil pressure insufficient light comes on with stop sign from my peugeot 406. lately, i changed the timing belt(cambelt) along side the valves and ever since, the indicator of oil pressure insufficient
the oil pump should have been PRIMED before running the engine , this is done by connecting a electric drill to the oil pump drive and run drill for 3-5 mins , this will pump the oil into all the galleries etc so when engine is started the oil is already around the smaller intricate areas , the oil pump alone will not always get to these parts after having the head removed , that is also the reason for the rise in temp
Nov 04, 2014 | Cars & Trucks
Noise coming from what sounds like the fan...belts ok, fluids topped up. Sounds a little like a hovering helicopter. It started after suddenly stalling at a stoplight. Check engine light is on, but has...
I would be very worried that sounds like the timing belt has split. would not drive the car until it has been checked a stall on and old belt can and will snape. check this out before driving car again...
Oct 13, 2013 | 2004 Toyota Tacoma
Runs rough at idle when cold/check engine light comes on/scanner gives no code
Ok Run,s smooth when WArm ?Check thermostat change it or light comes on using to much fuel so replace the oil And Filter cause you have lot,s Of GAS in OIL so Replace it then Check to see if YA HAve Antifreeze in OIL see when ya Change it Ok See if ther is some If Not change thermostat ASAP ya can wreck the HEADS ON the VAN Over HEat them
Mar 15, 2013 | 2003 Ford Windstar
Other times my car will stall, sputter, **** while driving and seems to not be getting gas. Even going 70 down the highway it will stall. When it stalls while driving the dash lights come on.This happens...
check for corrosion on the sparkplug wires, both ends. Crankshaft position sensor, cam position sensor and lastly, gulp, the ignition control module..
Sep 07, 2010 | 1994 Buick LeSabre
Last night my sebring stalled out of nowhere and then the check engine light along with the oil pressure light appeared. There was no unusual knocking sounds or anything. I keep the oil changed and up to...
Get it scanned for the check engine light, (mil light), as for the oil light, thats normal due to engine not running and making no oil pressure. was this a sudden stall, with no engine surging, then I suppect a failed cam or crank sensor. if it kind of stalled with engine surge and hesatation, I suspect fuel related, possible fuel pump. 2.4L, 2.7L engine have same sensor issues and ideas. if you need more info, just reply back with the mil code, I will walk you through this problem.
GOOD LUCK, RDJRP.
Jul 17, 2010 | 2001 Chrysler Sebring
Replace head & new timing belt
It sounds like the head gasket is leaking.
Is there also antifreeze in your oil? That may be causing your oil light to come on.
I would quit driving it until the situation can be resolved.
If you need more help post a comment and I will get back to you.
Apr 27, 2009 | 2003 Kia Optima
97 olds 88 check engine light on car stalls periodically
when you say stalls, do you mean shut off of just get low on power?
my check engine light comes on and then oil press light come on and the car shuts off but the lights and music stayed on.
if its that the car needs oil and shuts down to protect itself but it will turn on minutes later.
if stalls periodically, shows check engine light and the car looses a bit of power, in the engine, :
1. your coolant may be having problems getting to the engine in the way it was met to get to the engine
2. the belt might be a bit off and that could be why you get the slipping feeling
3. your exhaust may be a bit clogged. or your engine may need cleaning
i had both problems my car shut off and my engine was slipping. my EXPENSIVE but great machanic found out it was my oil level and my coolant was rusty and not getting to the engine. now she drives like the original 97 olds 88
Apr 01, 2009 | 1997 Oldsmobile 88
Engine light flashing
Whens the last time you checked the oil or had it changed, should probably check this first. If it's low add to the line(probably real low) and get the oil changed asap.
Jan 25, 2009 | 2000 Ford Windstar
Will not start
Most likely is the timing belt. Unfortunitly, I believe this maybe a non interference engine, meaning you may have bent all the valves in the head.
This maybe a costly repair. Have it checked properly by your mechanic
Dec 05, 2008 | 1996 Dodge Neon
Network Engines, Inc. (SYS-NEI100-000) Firewall Logo
74 people viewed this question
Top Network Engines, Inc. Computers & Internet Experts
David Payne
David Payne
Are you a Network Engines, Inc. Computer and Internet Expert? Answer questions, earn points and help others
