Question about GE WJSR4160D Top Load Washer
GE Washer overfilled, now won't spin
My GE Washer recently overfilled while filling with water to begin a new load and wouldn't stop until I pressed the start/stop button.  To get the water to drain, I placed it on spin and it drained the water, but never spun.  Now, the machine will not spin at all, and no matter what cycle you set it on, it will just start agitating without refilling, but still, it will not spin.  It's acting like it thinks that it is already full of water.  Any suggestions on what caused the original overfill or what may be causing everything else???????  Please Help!
  • jj91003 Oct 17, 2007
    any instructions that I can get will be helpful!!!!  Thanks so much!
Fuyck you it dont work
Posted on Apr 09, 2012
  • 240 Answers
Could possibly be that the water level switch in the console has gone bad.  Sometimes the small hose that connects the basket and the switch can come off, causing the overfill.  Sounds like maybe the water switch has gone bad though if I were to guess at it.  If it goes bad, it will send the timer a signal that its full, when its not.  Could also be a bad timer, but that only happens on rare occasions, but it does happen.  Let me know how it goes or if you need break down instructions, etc.  Jim
Posted on Oct 17, 2007
  • James Greene
    James Greene Oct 17, 2007
    Ok, dont know the model or type, but if its a newer unit, you should see 4 screws that hold the console onto the rear frame (should be on the very top of the console).  These could be phillips head screws, but most of the time they will be Torq head screws.  Remove these screws, and tilt the front cover of the console towards you.  Be sure that the unit is unplugged as well.  You will see the switch right behing the knob.  Make a note to how the wires go back on, and remove the wires from the switch.  Remove the small water hose (be sure that the hose isnt disconnected at this time, if it is, blow into the switch and see if it clicks at all).  There are a number of ways to remove these switches, but the common type is to look at it from behind.  You will see a small clip like thing made into the switch.  Slightly lift (or push down on the console slightly) and rotate the switch out.  Be sure to remove the knob as well.  Be sure that when you replace the switch, to rehook the small hose.  Also check to see how tight or loose it fits back on the switch.  If its to loose, cut a small amount to make it tighter.  If these dont look right, send me a model number and will see which one you have.  Let me know if you run into problems or need any other help.  Just looks like a big job, really very easy.
    Jim
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Washing machine overfills
Grab the tube off the water level switch that comes from the bottom of the tub and blow it out so that the sand in the bottom won't be blocking the operation,pump out the water, secure the tube tightly to the pressure switch and retry.aff8f03.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 10, 2009
How to soak somethings overnight in my new LG washer ?
The method we use on our LG WF 8071TTP top-loader:
Load stuff to be soaked.
Add soap.
Set load size and water inlets.
Start wash cycle.
Wait until water is full, and begins washing.
Press Start/Pause button.
Press Auto Stop button to switch machine off.
Next morning:
Press Auto Stop button to switch machine on.
The fuzzy logic (if machine has this) will register that machine is full, and washing will continue.
Jul 16, 2018 | Office Equipment & Supplies
GE WASHER STOPS DURING WATER FILL WASH AND RINSE LIGHTS LIT.
there is a small plastic tube that runs from the washer tank up to a pressure switch to let it know tank is filled and to start washing. As water fills it creates increasing air pressure in that tubing. If the tube is clogged at bottom end or is leaking ANYWHERE that pressure bleeds off. Those switches are also adjustable via a small set screw on the switch. Is problem affected by load size? If tube leaks usually it may overfill and NOT shut water fill off. Likely the switch is bad, but inspect that line thoroughly.
Oct 26, 2017 | GE Washing Machines
Kenmore Front Load Washer filling up and giving LF warning
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!##@
Oct 15, 2009 | Kenmore Elite 45986 Front Load Washer
I turn on the top load washer ,it starts to fill
Flood Condition:
Oct 13, 2009 | Kenmore Washing Machines
Flashing FL
Hi
If you have error code FL it means flood condition i.e. FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
If its LF which means long fill i.e. when the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed. Press STOP/CANCEL to clear the display.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
GE PROFILE WASHER DOESN'T CYCLE TO WASH FROM FILL
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Aug 19, 2009 | GE Profile WPRE6100G Top Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Wahser does not stop filling water
replace the water inlet valve
May 03, 2009 | Washing Machines
GE top load Washer won't stop filling or spinning
Remove the plastic hose from the water level switch and blow through it until it flows freely.
If it does not clear this way. Remove the front panel.putty knife needed.
Remove the water level tube from the tub and clean out the gunk.
Reconnect it to the water level switch.
Set the machine to spin and run it.
Reset water level control and try your machine.
Feb 04, 2009 | GE WBSE2090A Top Load Washer
GE WJSR4160D Top Load Washer Logo
204 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
