Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
INDESIT IDL 40 Lights 2 and 3 keep flashing, machine stopped
I have tried everything, ie:
Turned off at plug, left for an hour, turned back on Turned off at ON/OFF switch Pressed start/reset button for 5 and 10 seconds Changed to another cycle when machine off and when on Checked nothing is blocking the door, everything stacked okay Checked sprayer arms - fine Refilled salt and rinse aid which were empty Every time I turn it off, then on again, first the second light comes on and I can hear water, then the third light comes on and they both flash Any solutions?
SOURCE: Indesit idl 705 Dishwasher
Having read another users fault (LUNNY) that has same fault. They got engr out and it was a blocked pump. Where is the pupmp located on this model as I have the same fault and want to resolve it asap.
Posted on Sep 23, 2007
SOURCE: idl 705
i have similar problem machine starts then stops while bleeping the second and third lights then flash nothing more happens have checked water intake which is ok no blockages any more ideas would help thanks
Posted on Mar 04, 2008
SOURCE: Indesit IDL705
use descaler
Posted on Apr 03, 2008
SOURCE: Indesit D41 lights 1 & 2 flashing
1, Tilt machine and remove base plate 6 screws.
2, fixed to the inner ring at the bottom of the machine is the water level control.
(brown, round with 3/4 wires attached.
3, remove it, lift and pull forward.
4, remove the attcahed clear plastic tube.
5, tip up and drain out any water in the unit, Should be none.
6, Blow throught the free hanging rubber tube, should be clear
refit.
Posted on Dec 22, 2008
SOURCE: Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Posted on Oct 06, 2009
How do I fix my panasonic vierra that won't come on after a power outage?
Pull the plug and with the power disconnected hold the power button on for 60 seconds. After at least the 60 seconds plug the tv in and try to start it. If it works great if not , hold the power button in the on position for a count of 20 with the tv plugged in . If theres still no Joy try power with one of your volume buttons at the same time . One of these should provide a hard reset for the tv.
SOLVED 50 panasonic Viera model no TC P50C2 won turn on red light blinks...
Jan 26, 2018 | Televison & Video
Our dishwasher idl 40 indesit has 1 and 3 flashing lights on the panel seems to be a problem
I have had this problem also and no longer take anything apart take out the filter plate pour boiling water into the well leave for 20 mins put on a 25 min fast wash and hey presto works every time. Mine seems to block up about every 4 weeks and the lights come on but this solution always works
Mar 06, 2012 | Indesit 18 in. D41 Slim-Line Free-standing...
Forgot the password, was in storage for since dec 2008. tried the initialization procedure out of the manual and . . . no change.
I just wanted to clarify a few things,
The initialize procedure is:
  • power on projector
  • press enter
  • turn off the projector by pressing
  • unplug the projector
  • plug the projector back in
Once the projector has been initialized the factory password is:
"up - right - down - down - left - up - right - down - left" and hit enter
This will allow to then enter in a new password
I hope this helps,
Magoo
Mar 07, 2011 | Panasonic PT-LB75U LCD Projector
Ndesit IDL 535 DW, not cycling, water coming from under unt.
The washer is fitted with an anti flood device that detects water leaks and closes water inlet valve and puts washer in pump out mode. The anti flood device is a polystireen float with micro switch at the bottom floor of the washer. Dry the water and find the leak (pipe or pipe clamp) and this should then solve the error.
Jan 22, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Please reoperate after pressing reset button
When you switch it on the red led will light up but within 10 seconds it will flash and then a message on the screen will come on to tell you to reset then tell you "in service".
This will repeat itself forever to frustrate you no end but I have stumbled onto tricking it into working, ie get the led on without progressing to flash. Try switching it on and as soon the led comes on, switch it off, do this a few times, then leave the switch on and voila it might stay on like it did for me.
Just now I have ran it for an hour, switch it off then after 30 seconds turn it back on and it stays on.
I thick the reset button is all bull. Let me know how it all went or am I all bull for your NV-DS38.
Jun 19, 2009 | Panasonic NV-DS38 Mini DV Digital...
Indesit idl 40 2&3 lights flash
The problem is lack of water. Check that the water is turned on at the stop **** and make sure that the hose hasn't been traped if the dishwasher has been pulled out from it resess as happened to mine.
Jan 21, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
372 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
