Question about JVC Audio Players & Recorders
Sound just lost , nothing going via subwoofer , cant find the fuse - please help who can
Lost of sound, possible burnt of fuse
  • zaika May 17, 2009
    just turned it on one day- and no sound and no light on subwoofer - checked wires and did all what the manual advise- nothing working
    Brigadier General:
  • 8,546 Answers
Yup.
Want a better answer? How about some details?
Posted on May 16, 2009
  • David Dunn
    David Dunn May 17, 2009
    Please give details. EVERY problem starts with "I turned it on and it doesn't work". Is the subwoofer the type that turns on only on the presence of a signal? Configuration, connections, model numbers. Did you try another power outlet. Instaed of tellng us you did 'everything' fill in the blanks. We don't know what your manual told you to do.
Car will turn over, finally started but lost all components in dash, i smell antifreeze inside car, but nothing wet inside in my 2004 Alero
Check both sides of the fuses and test all relays. Sounds like you may have a burned up computer or bcm. Antifreeze smell? Possibly the heater core.
May 04, 2015 | Cars & Trucks
Hi ive got a b&w as2 subwoofer but theres no sound? the power light works but my denon recievers not picking up the sub is there a fuse in the sub which may have blown ive tried all the settings on...
Are you running this subwoofer via an LFE (RCA line level) connection, or via high level (speaker lines in and out of the subwoofer)? There may be different ways to hook up this unit and it would be helpful to know how you have the unit connected. Thanks!
May 04, 2011 | B&W Audio Players & Recorders
Blown subwoofer fuse..
Well, it should state in the manual what the replacement fuse is.
There might be a fuse holder near the pwr. plug. , Or near the controls for it. If not....
You might have to open up the sub unit ....and find the blown fuse, and remove it to see what you have. Be sure to unplug the unit before opening it up.
Take the fuse to Radio Shack, or your local electronics supplies stores. Replace with the same, or the correct fuse.
Apr 06, 2010 | KLH (AT2100) System
Just quit. no seem to be burnt .does not work. no sound. fuses good. similar problem it seems like that posted jan. 15,2009
Please check +12 volts at Q809 emitter pin and -12 volts at Q810 emitter pin on power board. Also check collector voltages on both transistors and let me know to move further.
Jun 04, 2009 | Sony SA-WX700 Subwoofer
Blown fuse??
there is an underlying cause for the fuse to blow. if something shorts out you would rather a 40 cent peice goes then the unit causing a fire. disassembly is require... look for obvious burnt parts first.
Robert
Sep 01, 2008 | MTX SW2 Subwoofer
JVC THM303 - No Sound
Its your wire connection problem. Plz check that all the wires are connected to specific location. If wiares are ok then it might be internal circuit error! that should be repaired at authorised service stations.
Dec 07, 2007 | Audio Players & Recorders
Diaphram replacement
http://www.trsmusic.com/speakerrepair.htm
i hope this helps.if you burnt out a coil chances r u might ve warped the basket or magnet . check that first. rating please
Nov 03, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Subwoofer not working
if u are a technician then its easy to check, problems are, blown fuse, power amp IC output transistor may be blown, check for burnt componenets. changing and blowing a fuse means ur output IC or transistors are shorted.
May 15, 2007 | KEF Audio KHT 2005.2 System
55 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
