Question about LG L172WT 17 in. HD-Ready LCD Television
Problem with AV Input and TV signal distorted but i know signals are fine from source
I have a LG L172WT and i have vertical lines coming down the AV input. I also have these on the TV input av well. The reception is fine with a normal TV and so is the AV input from my PS2. When i use the DVI input from a PC the picture is fine. Any suggestions?
Dear Sir I have a lg golden eye tv (model no-cf-21d33ke) av signal not coneected
Posted on May 05, 2013
  • 187 Answers
Change devices to other ports, if you are sure some ports are not working properly then you will need to replace the mainboard.
Posted on May 27, 2009
I got a Samsung 1080i television, but when i connect my dvd player to the back, it does not pick it up. i also tried connecting a tv freeway antenna and that did not work either.
Check the input selector. If it is not set to use the source signal type, the set won't pickuup any signal. If the source signal is antenna, you shoud select antenna as input selector. If the source signal is AV, you shoud select AV in the input selection. Press the input button at the remote controller, and do the needy.
May 31, 2017 | Samsung Televison & Video
How do I get a signal?
The only thing between the player and the TV is the cable. Make sure it isn't the problem by trying a different cable or a different input on the TV.
Sep 30, 2015 | LG Electronics - DP132 Multi-Format DVD...
How do i get my westinghouse to recieve signal it shows on the tv no signal and on the box it says that the tv does have a signal
Make sure you have the TV tuned to the proper source.
My TV has multiple input sources ranging from the cable box to various AV and gaming equipment and I must select the right input source in order for the TV to receive a signal.
On my controller, there is a button at the top for selecting the input source. I can cycle through all sources by pressing that button. If you're using a programmable universal controller, that function may not be programmed into the universal controller so you may need to use the original controller that came with the TV.
If, after you've cycled through all of your available sources and still get no signal, check and see if a wire has come loose between your cable box and TV, either at the cable box end or the TV end.
Hope this helps.
Sep 09, 2014 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Connect tv to iPad NO SIGNAL problem
Check the input or source on the TV to make sure it is on the correct input for the ipad.....
Apr 30, 2014 | LG 19LS4R 19" MULTISYSTEM LCD TV...
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
Power board signal
Hi Jim, I hope you have done the right in put "SOURCE" setting. Like AV, PC, HDMI etc. The source setting must match the signal you are feeding to your TV. If not the TV will show no signal. I hope there should be nothing wrong with your TV. Good Luck.
Dec 21, 2013 | LG 46LD550 46 in. LCD TV
My screen is blue and it wont let me see anything
Hello
Your TV is not getting any signal at all to process, or the tuner inside your TV is faulty. Blue back screen comes, when there is no signal to any of its input or faulty tuner. Just connect the tV with any other video source, like VCR or DVD , connected to its AV terminals and set the tV to take input AV, and check whether picutre comes in or not. If picture comes with AV connection, make sure that your tVs tuner is faulty and should be replaced. If no picutre comes with AV connections too, the Chroma Ic insie your TV is faulty, and should be replaced. OK.
Feb 17, 2011 | JVC AV-32S575 32" TV
Vertical stripes in picture image of new tv. Stripes appear on cable signal and dvd player signal. Have swapped hdmi cable to Av input and the condition remains. Is the tv defective?
if its new and it does this on several different inputs from different vidoe signals, take it back to where you bought it and demand a replacement.
Dec 24, 2010 | LG 42LE5400 42 in. LCD TV
I have a Samsung-PS50C91H Plasma TV. It was working fine with two AV inputs, suddenly one day one AV input disappeared and it wouldn't come after all I could manage to do. What should I do? Take it to the...
You have to confirm this AV input dead or no incoming signal from the source. Swap it with a good AV source and see how. If it does not help, reset to the factory mode. If not, you have to change the main board.
Aug 17, 2009 | Samsung 50 in. Plasma TV
I have a 48" LCD television. There are vertical lines across the screen making it impossible to view the picture. However the picture for video camera hook up is fine.
Sounds like the resolution is not syncing or a setting is wrong, depends on the signal source you are using: if using a cable box use the yellow video out cable to the camera input that works and the adjust the resolution lower within the cable box, also check the TVs input settings, the component cables (red,Blue and Green) setting must be set to YbPbr not RGB to work. Due to the signal conversion done inside the TV there are settings to help things syncronize properly.
post more info about the signal sources to get more help.
E
Aug 05, 2009 | LG Televison & Video
LG L172WT 17 in. HD-Ready LCD Television Logo
499 people viewed this question
Computer Repairing
Computer Repairing
