Question about Toshiba CF32G40 32" TV
Rainbow pattern on CRT TV
My TV took a tumble while moving it to a new entertainment center.  Despite that it fell a good 20", face first, onto a hardwood floor, the tube is still intact.  Unfortunately, the picture now has pronounced regions that are saturated by with the various three RGB colors.  The picture is otherwise good.  Because this occurred directly after the fall, I did not think of trying to degauss it yet, though I'll give that a try this evening.
I'm an EE with access to test equip and have been 'bitten' before so I'm careful while working inside HV sources.  Unfortunately, beyond understanding the basic theory of operation, I've got very little idea how the fall may have caused this problem.
Any help or suggestions would be greatly appreciated!
Thank you!
  • CarelessGuy Oct 19, 2007
    Thanks AccordianMan!  I did not think of this but it does make perfect sense.  I guess I'll be shopping for a new TV soon...
    Thanks again for your help!
  • 979 Answers
If degaussing doesn't work, it may just be time to pony up and replace the crt as it sounds as if the shadow mask inside the tube has come loose. And, as you know, there is no opening that to service it.....accordianman
Posted on Oct 16, 2007
Which is better between hardwood floor or laminate floor??
I think.. hardwood is much better than laminate wood flooring, but each type of flooring has its advantages and disadvantages. Hopefully this article can help you to choose the floor you want.
Main Differences Between Hardwood And Laminate Flooring
Jul 31, 2015 | Building Materials
Tip
Home Flooring - Some Great Suggestions
If you're moving home or just doing some renovations, you might be faced with the question of what flooring to choose.
There are so many different options other than just plain carpet in a house, but each choice comes with pros and cons.
Here's my basic guide to flooring choices.
  • Carpet:
Okay, so carpet gets a really bad rap as being very 70s but put in the right environment, I still believe that carpet can be a great asset.
Even though it might seem expensive, you can get really good sale offers on carpet, depending on the season.
Also carpet is very hard wearing and so a good option if you're looking for a long term flooring solution that won't need replacing too quickly.
What I love about carpet is its softness, so it's great in cold countries or for rooms where you want to bring a softer more soothing look to the design.
The problem with carpet though is how it gets stained very easily and can be harder to clean. I sometimes worry that despite all the vacumming and carpet cleaning, carpets might be hiding a lot of dirt underneath.
  • Hardwoods:
Hardwoods are the latest trend in flooring. The costs really vary depending on the quality of wood that you go for.
Installation is also important - it not only costs money for the installation but needs to be done by a professional as hardwood flooring isn't something you can experiment with.
Hardwood floors look great and are much easier to clean than carpet. I find that some hardwood floors are a bit loud to walk on but putting rugs down can help with that.
Lounges look amazing with hardwood floors and modern furniture.
  • Tiling:
Tiled floors look wonderful but it's not a cheap material for flooring a large area and requires a big investment of time and money to install.
Personally I love tilling in bathrooms and kitchens and as it's water resistant it's perfect for rooms where spillages are a common occurance.
I suggest that you look around showrooms. Don't limit yourself to one style of flooring thoughout the whole house. You can mix and match between hardwood flooring and carpets.
Have Fun!
on Jan 19, 2014 | Building Materials
I fell and hit my shin hard it hurts realy bad what do i do
Well get fitted carpets next that wilkl break your next fall ,as for the shin ?' put a ice pack on it and dont walk on it for a day or so and make hubby do the housework
Dec 11, 2011 | Code Writer Wall Smilies
32" TV fell over onto carpeted floor and won't
It's probably a write-off. The circuit board inside has been cracked so that some of the copper traces that connect parts have broken. This commonly happens around the area of the horizontal output transformer, which is heavy. The shock of the fall causes the transformer to bounce and breaks the board. Other areas too may have been damaged because of flexing. And worst, the picture tube can be damaged in a fall, so it either doesn't work at all or shows permanently distorted colors.
It's tough to find anyone willing to repair a set that's fallen. Many circuit board tracks are very narrow and hard to repair. Then it's difficult to know if all the damage has been found and repaired, so even if the set starts working a technician doesn't know if something else won't go wrong. And then there's that bad tube possibility; no technician likes to spend lots of time fixing a broken board only to find the set then needs a new tube. Trust me, this has happened to me several times during my career in TV shops.
Your best bet is to use this as an excuse to buy a new LCD or plasma TV. 40-inch models, a good size match for a 32-inch CRT (tube) model, are reasonably priced.
Jul 03, 2011 | Quasar SP-3233 TV
I can not get the base off
Follow the below instruction on how to the base off your Toshiba LCD TV;
  1. Turn off your Toshiba TV if it is on.
  2. Unplug your TV from the wall and any other devices (like DVD players or Blu-ray players) that it is connected to.
  3. Put a blanket, towel or some other kind of soft object down on the floor (if you have hardwood floors and not carpeting in your home).
  4. Set your Toshiba TV down onto the soft surface with the screen facing downward toward the floor.
  5. Use a flat-head screwdriver to remove the two large, plastic bolts on the rear of the TV stand's base. These bolts are holding the stand onto your Toshiba TV. Set the bolts aside.
  6. Use your hand to pull the base off of the Toshiba TV. You will now be able to set your TV completely on the ground. Put the base (as well as the accompanying bolts) aside for safe-keeping, in case you ever need to use them again.
I hope the above helps.
Good luck.
Feb 02, 2011 | Toshiba REGZA 52RV530U LCD TV
My wii fell on the floor (hardwood) and everything works but it won't come on to the tv we tried another friends wii it works fine can u help?
Make sure that the power is still plug in, and hope that that was the solution, yikes and Good Luck!!
Jan 22, 2011 | Nintendo Wii Console
Dropped speaker now has lots of static
the driver inside needs to replaced as the magnet broke or the driver got bent..it may be cheaper to order a new speaker complete from them.
Jul 13, 2009 | LG LHT799 Theater System
My dishwasher won't drain, and leaked out onto my hardwood floor!
I ordered a new hose and the problem is fixed! I probably could have just simply taken the old hose off and flushed it out; but the powdered solution, that is supposed to dissolve, had solidified and clogged the hose in several places. Strangely, it had also made like a filmy flap at both openings. Gross!
Jun 23, 2009 | Kenmore Dishwashers
Orech scratching hardwood floor ???
I would recommend using another cleaning method developed for use on hardwoods. It seems to me like even if you replace the wheels, eventually they will wear down again, causing more damage to your floors. Check home depot, ask them what the recommend. Hope I could help.
Jan 27, 2009 | Oreck XL2200 Bagged Upright Vacuum
Standby/stereo light blinking no picture or sound
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!! My TV is 9 years old.
Aug 31, 2008 | Sony KV-36FS100 36" TV
Televison & Video Logo
407 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
