Question about IBM ThinkPad X41 Tablet PC
Erratic mouse/pointer behavior
The mouse pointer drifts to sys tray and right clicks on clock.  Behavior occurs most frequently when trying to run things.  Have been to Lenovo's website and installed System updates, firmware and even Microsofts fix KB920295 without resolution.  IBM feels it's software related however hard drive was swapped between laptops and the problem stayed with the laptop.
  • Ken_C Nov 07, 2007
    I am having the same problem. I am glad I found someone that is experiencing the same problem because I need to know how to get this fixed. Right inthe middle of doing something the pointer will activate the Date and time Properties. I then have to Close that window and hope it does not happen again, but it always does. Please if there is something that can be done please let us know.
  • Anonymous Feb 29, 2008
    Same thing here, unfortunately warranty is over and I am away from USA-so I guess I have a problem... Anything else apart from changing the planar card as solution?
I ended up calling IBM support (after many calls to them) and since the Tablet was still under warranty I sent it out for repair and they ended up replacing the planar card. Tablet was returned and I have had no further issues with the mouse.
Posted on Nov 08, 2007
Create mailboxes In yahoo mail
Enter the email address you'd like to create in the "Email Address" field. You may also enter a display name in the "Name" field. Then click the Next button.
If you will use only POP (Post Office Protocol) to access this new email, you can select the second option; you won't need a Yahoo ID to activate the address.
On the invitation page, enter the email address to send the invitation to.
Be sure to assign mailboxes at your domain only to people you trust. Yahoo maintains a strict policy against spam and abuse and will suspend domain names that are associated with these types of behavior.
You are responsible for actions taken by anyone using an email address associated with your domain. If anyone using your domain is found to have violated the Yahoo Terms of Service in conjunction with a Business Mail plan, Yahoo reserves the right to suspend the domain and deactivate any mailboxes associated with it.
Feb 26, 2015 | Apple iPad Tablets & eReaders
Irulu 7" tablet keeps disconnecting from internet. It's connect for a minute or so and then just drops. Just received replacements for 2 in the mail yesterday. No connection problems with old ones.
How many 'bars' are showing on wi-fi signal strength indicator (presuming you are using wi-fi for internet access)? If the signal strength is low, you could be losing connections that way, or there might be interference on the wi-fi channel that the tablet is using. Try changing channels in your wi-fi setup and see if there is an improvement in the behavior.
Feb 07, 2015 | Tablets & eReaders
My trio stealth 10 tablet dose not see my internal memory and every time I shut down its goes back to factory settings like I just took it out of the box.
This is somewhat odd behavior, I recommend to take it back to the store and ask for replacement if it is less than 2 years old.
Nov 20, 2014 | Tablets & eReaders
Forgot password for acer tablet/aspire one
The default root password for an Acer Aspire One running Linpus Lite is 111111
So open a terminal, and enter
Code: [Select]
and the password 111111 when asked.
your prompt should change from an $ to a #
If it's the user password you want to change, now enter:
Code: [Select]
you will be prompted for the new password twice
[END EDIT]
You'll need to get the into advanced mode - you'll see why once you've done it. To do this go to "Files" > "My Documents" to open the File Manager. Then go to "File" > "Terminal" (use the word menu at the top of the File Manager window.
Linpus Linux uses Xfce, so use "xfce-setting-show" to get the Xfce Settings Manager.
Click on "Desktop" to get to the "Desktop Preferences" and select the "Behavior" tab.
Now under "Menus" click the "Show desktop menu on right click" option and close the window.
This setting will allow you to bring up the normal desktop menu when you right click somewhere on the desktop. The Desktop Menu contains many more options than the limited user interface on the Aspire One.
OK. Now you're in advanced mode, right click somewhere on the desktop to bring up the menu. Go to "system" and then go to "terminal"
Once the terminal has opened type this:
Code: [Select]
sudo -su it will prompt you to enter a password. type this:
Code: [Select]
passwd It will now prompt you to enter your new root password (Just type it - you won't see anything appear but it's registering it).
You'll be happy to hear it asks you to repeat the password to make sure you were paying attention...
Note: That the password can be anything you want but needs to be longer than 6 characters.
Done!
Aug 07, 2014 | Acer Tablets & eReaders
Screen doesn't adjust to the way its being held
Try a hard reset by holding the Power button down for 60 seconds, then release. Wait 60 seconds and turn the tablet back on, if the Kindle continues to act odd, contact Amazon for a replacement, this is not normal behavior and may be a sign of something serious failing.
Mar 27, 2013 | Amazon Kindle Fire HD
Son switched on guided access on iPad and doesn't know what pass code he used. Now stuck on safari and can't get to settings to switch guided access off
To disable guided access try the following:
Triple-click the Home button and enter the passcode chosen during setup of Guided Access to unlock the device
You'll now be back to the usual behavior of iOS.
If you'd like to turn off Guided Access completely, just go back to Settings > Accessibility > Guided Access > and flip the setting to OFF. You'll need to enter the passcode again to do so.
Oct 31, 2012 | Apple iPad 2 lack Tablet PC
My laptop is Hp TouchSmart tx2,the problm is :-The pointer moves unwnted icon it click by it self.
The problem is very simple. The sensitivity of the mouse pad is too high in your laptop i guess. Try adjusting the sensitivity of the mouse. Go to control panel-> mouse options->mouse sensitivity. Try changing the double clicking speed, mouse sensitivity etc and check your mouse operation now.
Aug 03, 2010 | HP Tablets & eReaders
My keyboard wont type anything, the mouse works, but when i try to type it wont do anything, the buttons do work because when i open word to try to type if i click f the file drops down and when i click v...
Somehow the left ALT key is stuck in a pressed position. Usually when you press left ALT and the letter underlined in a menu, it deploys that menu. In the File menu, the F is underlined and in the View menu it is the V that is underlined, hence the behavior.
Hope it helps.
Oct 07, 2009 | Toshiba Tecra M4-S435 Tablet PC
When I click the mouse pointer it doesn't work I have no choice but to use the right mouse buttons to make selections. How do I fix this issue?
Usually this problem can be easily solved by accessing and changing your mouse settings. On your PC desktop, click "start", then click "control panel", then click "mouse", then on the "buttons" tab you'll see an option that says, "button configuration". That button needs to be adjusted according to which side of the mouse you'd like the pointer to work from. Once you set the side you'd like, make sure you click, "OK" to seal the deal!
Hope this helps.
Sincerely, CBR2009
Jul 16, 2009 | Gateway M280E
Open Questions:
IBM ThinkPad X41 Tablet PC Logo
563 people viewed this question
Top IBM Tablets & eReaders Experts
Steven Wander
Steven Wander
Andrew Taylor
Andrew Taylor
Are you an IBM Tablet and eReader Expert? Answer questions, earn points and help others
