Question about Canon Pixma MP800 All-In-One InkJet Printer
Printer Error I have a Canon MP800 that is driving me crazy. I replaced the ink cartridges (I have done this several times in the past with no problem) and am having an error that states "More than one tank of the following color is installed "Cyan [8]. Use only one ink tank per color at a time" I have doubled and triple checked the ink cartridges, They are all new and in the proper places. If I take them out, and put them back in, sometimes it will work, but most of the time it does not. Is there a way to reset the printer? It sounds like a problem with the printer. Thanks, Sean
  • 1 more comment
  • Anonymous Nov 01, 2007
    Mine does the same exact thing.
  • nackers Dec 09, 2007
    same but with yellow, turn it off, turn it on, sometimes it recognizes it, sometimes it thinks there is two of them... so god damn frustrating it hurts, tempted to hurl the thing across the room.
    Question did this happen to yours just after the warranty ran out? 'cos mine is three months out of warranty... engineered obsolescence???
  • jeffwarner Dec 22, 2007
    My printer tells me there are two magenta ink cartriges installed. I have checked and there is only one installed.
    Sometimes I can fix it by taking the magenta cartrige out and reinstall it.
I fixed this problem by installing a new magenta ink cartrige. This makes me believe the problem is in the replacement cartridges. Of course this is not very satisfying because I had to discard a 3/4 full ink cartridge.
Posted on Mar 29, 2008
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
Error code 6A00
Hope this helps.
Feb 10, 2011 | Canon Pixma MP800 All-In-One InkJet...
Error code 6A00 shut down machine. How do you fix it?
Oct 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Printing B&W on a Pixma MP800 with empty color cartridges
no you cant print with emapty colour catridges you have to install the other full catridges.
Nov 23, 2009 | Canon Pixma MP800 All-In-One InkJet...
Canon Pixma MP 800 When it prints it just feeds the paper through there is noting printing on the paper. How xan I fix it
clean the printer head using the printer software tools, do these 3 to 4 times then print a page, if still work check your ink level, if you have a full ink cartridge and there no printer error aside from this have your printer head check by a qualified tech
Nov 22, 2009 | Canon Pixma MP800 All-In-One InkJet...
Service Error 5100 on Canon MP150
i need a mp145 cartridge reseter pls give me a link to download. tnx!
Oct 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP800 won't recognize refilled cartridge
Try holding down the red reset button for > 5 seconds. This should get rid of the error by disengaging the ink level detector.
Jun 24, 2008 | Canon Pixma MP800 All-In-One InkJet...
My cannon pixma mp800 does not recognize the cyan ink cartridge, which is brand new.
I had same problem with yellow ink cartridge. After going thru other suggestions I found on different forums that didn't work (turning printer off and on, cleaning contacts with alcohol, taking out and putting cartridge back in several times) I finally called Canon as my printer was still under 1yr warranty, and they sent me a brand new cartridge free of charge and it works great now (even though my cartridge that was giving error mssg was almost brand new too). I think they have a lot of lemon cartridges out there.
May 09, 2008 | Office Equipment & Supplies
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma MP800 All-In-One InkJet Printer Logo
195 people viewed this question
old marine
old marine
