Question about Acer Aspire One PC Notebook
Internal mic doesnt work
I have an acer aspire one with Ubuntu 9.04 Jaunty installed. Problem is that internal mic is not working. It worked fine on XP but i cant get it to work on linux. When I use the sound recorder it gets only noise.
Hi, Internal microphone on my acer aspire 8920g which originally has vista is not working now on windows 7. To be honest I didn't pay attention while I had vista and can't now remember if it worked at...
I suggest you go into control panel and device manager and see if your internal mic is listed there. If it is right click on it and see if it is selected as your default mic. I believe it may be un-selected. If that doesn't work I would just use the external mic with Skype as the internal mics with most laptops aren't that good anyway.
Mar 06, 2011 | Acer Aspire One PC Notebook
Internal Mic problems
it should work straight away on skpe. Have you checked to see that the microphone check box is not checked? To do this right click on the speaker symbol (bottom right of tool bar if you are using XP)
Apr 26, 2010 | Acer Aspire One PC Notebook
Acer Aspire 5720 sound not working
that means the guy or someone who replace the new harddrive didn't to a good job on restiall a new window vista for you, just simply go acer.com and search your model, redownload the sound card driver.
that's it.................
must be sound card driver problem.
Dec 29, 2009 | Acer Aspire 5720 Notebook
Internal Mic did not work
try to used diffent mic.
thanks,
Jun 23, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 5610Z, linux, wireless modem won't work
ubntu community posts can help u better way try that
Jun 16, 2009 | Acer Aspire 5610 Notebook
Acer Aspire internal mic won't work.
You need to check the record settings and make sure the mic is not muted or turned down to low. Click START, CONTROL PANEL, then SOUND icon. Click the AUDIO tab up top. Make sure that your sound card is selected in the drop down menu under Sound Recording. Now click VOLUME tab. A new window will open up. Click OPTIONS then PROPERTIES. Make sure you have a check by the MIC and click OK. In the Recording Control window, turn the level up for Microphone and make sure it is not muted. Let me know what happens.
May 02, 2009 | Acer Aspire One PC Notebook
Internal mic does not work
Be sure to find up-to-date drivers for your mic. What kind is it? That is most likely your problem. Either that, or you installed something that is conflicting with it.
Apr 06, 2009 | Acer Aspire 5315 Notebook
No. im on linux with the acer aspire one. i dont want to change to windows, so is there a solution for the mic involving staying on linux? appreciate the help. email me carl.guevarra@gmail.com thankss
pls try to search this forum u will find the solution soon
https://help.ubuntu.com/community/AspireOne
the latest is the internal mic will only work for Skype and the Internet Messaging applications installed on the unit
Mar 02, 2009 | Acer Aspire 5610-4648 Notebook
My microphone on my acer aspire one isnt working
This solution works for the Windows XP version. Go to msconfig.exe, then the Startup tab. UNCHECK rthdcpl and restart. Realtek driver doesn't load, but who cares...the microphone works now.
Aug 09, 2008 | Computers & Internet
Acer aspire 5050 display faliure
you cant see the damage physically, i think it has internal parts that is damage that is why it won't work. try to check internal display wirings of your lcd.
Mar 12, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire One  PC Notebook Logo
248 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
