Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Horizontal banding on the epson stylus CX 4300 there is horizontal banding when printing. The black cartridge is new with color cartridges almost empty. How can I fix the banding - we have already followed directions for cleaning and re-aligning. Thanks
  • 30 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takio-24
Posted on Sep 04, 2009
    Problem Solver:
  • 5 Answers
It could be colour in levels are to low give it another headcleaning about 3-4 times
Posted on May 17, 2009
I have a Stylus CX 5000 with a new black ink cartrige and empty color cartriges. I only need black/white printed material. It won't print at all. What can I do to make it print just black and white...
Epson software does not permit printing when any of the cartridges are empty. It is a way to make sure you purchase more ink (It stinks, we all agree). They also use the color cartridges to make up black ink, then print the black over the top!! Again a way to make sure it uses more ink than it is supposed to.
Good thing is there are plenty of compatibles on the market that work very well and cost much less than Epson OEM's.
Sorry it is not the answer you are looking for.
Regards GM
Apr 07, 2011 | Epson Office Equipment & Supplies
Epson CX 4300 printing problem
This can happen to cartridges with attached print heads. All cartridges are weighed and tested before leaving the factory so lack of ink isn't the problem. It usually has to do with the print head of the cartridge not having any ink to feed it. This happens because cartridges are kept flat or upside down for weeks or months before being used and the ink settles away from the print head. The easiest remedy is to open the box and stand the cartridge upright for a few minutes before using. Then get a damp paper towel, fold it into quarters and sit the cartridge print head down onto it. Hold the cartridge down to the damp paper towel for three minutes. This will help pull the ink out of the print heads, priming them and getting them ready to print. Finally, install the cartridge into your printer and print a few test pages.
Feb 19, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Broke and can't buy new color cartridge can I print in black only
No, the printer will not work with missing or empty cartridges.
Jan 07, 2010 | Epson Stylus CX9400 Photo Printer
My epson stylus SX200 2C will not print black , i have replaced the ink 3 times and cleaned it - it has a lot of gaps and sometine doesn't print black at all. Colour is fine. Help please .
I have excatly the same problem. I have cleaned the nozzles mutiple times and replaced the blck cartridge twice but I still have patchy printing in the black portion of the test print and horizontal banding in word documents
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Horizontal lines
try to clean your Ink cartridge inside you printer.. or try to replace with another Ink Cartridge.. maybe you cartridge was damaged.. ^^
Mar 10, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Epson CX7450 Black Ink Won't Work...
I was having the same problem. This fixed it:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Feb 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Non printing epson c20ux
Sounds like color cartridge ran out. Were u using color to print black?
Try new color cartridge.
Then if you don't need color go in and set to use black cartridge to print black (text).
If you need color on something only takes a minute to turn color back on.
Since printer worked you can go in and select black which uses the black cartridge and if it prints gives validity to a bad/empty color cartridge.
Good luck.
JC
Nov 27, 2008 | Epson Stylus C20UX InkJet Printer
Won't print unless all ink cartridges have ink.
Try changing it in the properties section under device settings
or go to color management if you have it and change the setting to black only,.
Aug 07, 2008 | Epson Stylus C84 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
359 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
