Question about Sewing Machines
No Manual Need Manuals for SP-ST-SU models
    Problem Solver:
  • 13 Answers
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Apr 29, 2017 | Elna Sewing Machines
Having trouble replacing the bobbin case
Elna SP ST SU sewing machine repair tips - YouTube
? 2:25
https://www.youtube.com/watch?v=TqrbimZyP1U
Oct 24, 2011 - Uploaded by Absolute Sewing
More Photos on replacing gears and some repair ti... ... I amhaving trouble with my Elna SU 62 skipping stitches when I sew on knits. ... Elna Lotus SP bobbin case repair - Removing a cotton jam from a Elna Sewing machine ...
Amazon.com: Bobbin Case 627569106 - Elna, Janome ...
Jan 12, 2016 | Elna Sewing Machines
Where can I get a manual?
Good day / Buenos Dias LindaPerry
The link to the manuals collection for Elna can be found here: (You'll need your particular model number: /
El enlace a la colecci?n de manuales de Elna se puede encontrar aqu? : ( Usted necesitar? el n?mero de su modelo en particular :
Elna United States Machine Manuals
Buena suerte
D
Dec 05, 2015 | Elna Sewing Machines
I nead a manual for a elna special ? please
try this link http://www.arizonaexpressionz.com/elna_instruction_manuals/Elna_EC_ZZ_SP_ST_SU_manual.pdf
there is a sewing guide available too, the SP would have less stitch functions than the SU - they did combined manuals for this range I think.
Good sturdy Swiss made machine, these were used in school classrooms for many years in NZ.
May 22, 2011 | Elna Sewing Machines
I purchased a used Elna su type 62cr209707. I need an instruction manual, where do i find one?
The Star Series SU is a lovely machine,
you can purchase a manual from here - well worth spending the dollars to find out how it works, especially the buttonhole which isn't like modern 4 step ones. You may also find that the foot control has a switch to give you slow speed vs normal speed sewing.
http://www.tradebit.com/filedetail.php/91117786-elna-sp-st-su-sewing-machine-manual
If you are in the USA you could also visit www.whitesewingcenter.com, they have lots of Swiss Elna goodies for sale and are very knowledgable on these machines.
You might also want to track down a newer Swiss made Elna pressure foot holder with the clip on feet, rather than using the full feet with your machine. They are interchangeable. Have you got the black discs to go with your SU too? there is a large range so you can sometimes track down some more to add to your collection.
There is also a newer black pressure foot screw which is a combined thread snip, its a bit bigger in diameter to the black thumb screw on your machine now and you can use it to cut and hold the threads at the end of each seam, very cute.
Always give this machine a good clean and oil before using it, there should be a red dot in the middle of the bobbin holder, oil here regularly and any other points that the manual shows with good quality sewing machine oil, it takes 130/705H standard sewing machine needles, put in a new needle for each project to get great stitching results.
Enjoy your SU!
Apr 15, 2011 | Elna 3210 Mechanical Sewing Machine
I have a old Elna machine. The air electronic SU 390 B. I have lost the manual and am trying to do buttonholes on a dress. I have forgotten the sequence of nob adjustments to complete the process.
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Aug 26, 2010 | Elna 2007 Mechanical Sewing Machine
Need parts/manual for old Riccar sewing machine
Here's a manual for the 551, it should be similar enough for your machine.
http://www.riccar.com/ftp/whitepapers/551-Owners-Manual.pdf
If not look on www.riccar.com/help/manuals for a similar model.
Find out what shank your machine is and you should be able to buy parts for it. I find ebay great for old sewing machine parts.
Hope this helps!
Jul 18, 2010 | Riccar R552
Sew Pro QuickStitch SP-402 Manual
i have found where you can get this instructional manual for free. Go to http://www.topinnovations.com/products/sew/SP-402/SP-402.html. if you are not looking for the SP-402 they also have other sewing machine manuals at this web site and you can get the address http://www.topinnovations.com and type in the search for what you want. I hope you all like this and it helps you in time to come.
BonnieLou
Nov 21, 2007 | Sew Pro QuickStitch SP-402 Mechanical...
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
