Question about Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334 GB SATA Hard Drive
How do i reformat C drive and keep my files on sata backup
Im gonna reformat my C drive (IDE) but i also have a SATA drive with a SATA PCI card (DELL 2400 doesnt accept SATA without card) with all my files on it...How do i format the C drive and then (install) the sata card and drive with out formatting that as well?....after i install the drivers for the sata card will the hard drive just pop up?...>Help....
  • BroKKeN May 16, 2009
    After I install windows and load the drivers, when i plug the SATA hard drive back in will it just recognize it and all the files?
  • 432 Answers
Dis connect the sata cable that attaches the sata hard drive to the pci card and then format c and re install with all the drivers you require for the pci card as well as motherboard drivers, network card drivers etc and then re attach the sata cable that way you dont get confused between which drives its showing if it manages to display the sata drive at boot up.
Posted on May 16, 2009
  • Shane Russell
    Shane Russell May 16, 2009
    yes should do after you re installed the drivers for the sata pci card.
    I was just saying to dis connect it so that there is no chance you can get confused between the drive partitions and accidentally format the wrong one.
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
RUNNING A SATA HDD ON AN IDE ONLY MOTHERBOARD
If I am not completely mistaken you have to reinstall the OS on the SATA drive on IDE. That is because the first installation was configured for connection on a SATA /PCI then now on the SATA/IDE port converter.
Sep 25, 2008 | Adapters.com Serial ATA IDE Converter and...
I forgot my password
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps
Jul 27, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have forgotten my password.. please help..
USB Memory Drives"
Hope this helps
Jun 30, 2011 | Western Digital Passport 320GB External...
I hav forgett my usbcod
USB Memory Drives"
Hope this helps
Jun 13, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a Dell Optiplex 170L mnitower. It has one IDE and one SATA port. I have connected a 1 TB drive to the sata and disconnected the ide drive that came with the system. No I am thinking, what if I add...
Hi there! You don't actually need a IDE to SATA converter. If you purchase a RAID 1 card, it gets hooked up to your computer via PCI or PCI-E. The RAID card will have at least two SATA ports on it - those are what you use to create your RAID. The sata port and ide port on the computer will not be used in the raid1 configuration. If you're going to go ahead with this, I'd recommend trying to find the exact same brand and model of drive as the first one you have. Also, keep in mind that creating a RAID 1 array requires formatting BOTH drives. Your Optiplex 170 only has PCI ports, so this may be a viable RAID card. It is fairly inexpensive, but will do the job. http://www.newegg.com/Product/Product.aspx?Item=N82E16816132001&cm_re=PCI_RAID-_-16-132-001-_-Product If you need any more help/advice let me know! Alex
May 30, 2011 | Computers & Internet
I have lock my 4GB Micro SD card and yet to remenber the password so how can I retrive it ?
Support IDE/SATA/USB Hard Drives, memory cards, USB Memory Drives
hope this helps
Apr 13, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Connect ide or sata drives to a dell poweredge 2600 for additional storage
Yes and No..
The standard machine only allows SCSI, (no IDE or SATA or SAS connectors...
However SCSI drives are not cheap.. so
To overcome the power issue (you will notice there are no 4 pin molex connectors, or sata power connectors). However there is a 4 pin molex socket on the SCSI backplane. You can use one of those molex adaptor cables (one connector to many) to get power, from the molex you can use a 4 pin to SATA power connector.
Next step is to decide the drive you want to use. I personally use SCSI, SATA, SAS and IDE in mine (overkill I know).
Cheapness says use IDE or SATA. You can get a pci IDE/SATA controller card on ebay dirt cheap (PCI cards are compatible with the large PCIX slots), they dont take the entire "socket" up but they work (be carefull here, there is one 5v pci socket on these machines, and 6 pcix sockets, the pcix sockets will accept 3.3v pci cards (look at the notches).
Next you have to mount them, with a bit of jiggery pokery you can feed the IDE/SATA cables past the SCSI backplane into the hot swap bay. (If you dont have any empty caddy's pick them up off ebay), just remember you cant just pull em out like you can with the SCSI's!) - or use one of the 5 1/2 media bays.
Plud the other ends into the appropriate controller card (as installed in the PCI bus).
Load up the OS, install drivers (if needed - these should come with the pci card(s), use the disk manager to initialise/first format the drives etc.
All done.
I have done this myself running a 2600, with 2X U320 72gb SCSI (on Raid) 1 x IDE CD/DVDRW in Media bay, DAT 27 SCSI (channel B) in the second media bay. 2x 146gb SAS on a DELL SAS pcix card (in 2 of the hot swap bays) and an old 160gb IDE HDD (Funilly enough theres a bit towards the back of the two fans on the SCSI backplane that if you press the 3 1/2 drive against seems to fit perfectly in this place and stay there! (I think thats fluke to be honest).
All done :)
Jan 04, 2010 | Dell PowerEdge 2600 Server
Dll gx280 case
first off does the motherboard have both sata and ide connections or just sata or just ide? (sata are small about maybe 1/2 inches in length and 1 mm wide and a ide connection is approx 5 inches long with about 4 inches long with over 100 pins and about 1/2 inches wide) i know that the opliplex 520 are nothing but sata so if it uses the same mobo as the 520 and you have ide then its imposible to install on your computer unless it either has a ide connection or you get a ide pci or pci-e controller card and install that onto the computer. but for the most part a ide connection needs a ide cable and a sata connection needs a sata cable.
Jan 23, 2009 | Dell (2336V) Motherboard
Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334 GB SATA Hard Drive Logo
207 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
