Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Hitachi television repair
hitme on Oct 16, 2007
The color convergence seems to be on the fritz. all of the images on the screen have red blue and green shadows around them. I have tried the magic focus system, but it shuts down quickly and the number 5 pops up on the lower right portion of the screen. Is there a cheap fix?
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
May 04, 2009
-   I have a hitachi 53sdx89ba rear projection TV. I have convergence issues - primarily in red. After hours of on-line research, I have replaced both convergence IC's (110's upgraded to STK 394 160 E). I have carefully checked all resistors and replaced bad RK46 (1.5ohm, 1W). My operating manual and available service manuals (bought on-line) and instructions from TV Repair Kits.com do not seem to work for manual DCAM adjustment on this Hitachi TV. For example, if I press and hold Majic Focus I get two screens, first Center Mode then Static mode, but I can not move red cross or red line with any buttons on remote. These screens on not described in service manual, etc. I can not access the grid mode that is supposedly available. For example, the instructions from TV Repair Kits that begins:
Press Magic Focus to begin magic focus
3) Press magic focus again during the magic focus process to get the "stop" screen
4) While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and
the service grid
... do not give access to service grid.
I have read countless blogs and boards and I can not determine if the hardware fix is bad (I find this hard to believe as I carefully soldered the two IC's in and checked and rechecked all the IC board resistors) or if I have a Software/Menu access issue. I have seen one poster say a fuse on the convergence board could be out, but I can not find the fuse.
Any suggestions appreciated. I have about 30 hours into this repair and am too stubborn to give up now.
-   burketb
Apr 18, 2009
-   color is fuzzy and the lines on the tv is wavey--how do i fix the convergence or where do i go to get instructions on doing this on a hitachi model 50ux22ba-   Guest
Mar 03, 2009
-   I just have blue around the images. Although I have a 51 in.-   Guest
Dec 14, 2008
-   Our Hitachi also has the red blue and green lines toward the top left hand side of the screen as though the colors were not lined up properly anymore. We also tried the magic focus but it did not work at all.-   Rubyshoes45
Nov 13, 2008
-   Was watching TV when it shut off. Power light blinked 5-10 times and turned back on. Now I have Blue shadows especially around the edges. -   NighthawkJoe
Best Solution
posted on Nov 25, 2008
Helpful)
Oeboy1
Rank: Apprentice
Rating: 86%, 4 votes
The convergence ic's need to be replaced. There may also be several resistors in the same area that are burned and need to be replaced.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Sep 15, 2008
Helpful)
ms cutie
Rank: Apprentice
Rating: 86%, 5 votes
I was watching tv last night and all of a sudden a red ray of light went across the screen.
Then the tv turned off and the power button started flickering red. does anyone have any suggestions ?
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Aug 11, 2008
Helpful)
hilights
Rank: Apprentice
Rating: 84%, 10 votes
how do i access the convergence on my big screen
Was this helpful?
Yes
No
Solution #4
posted on Apr 24, 2009
Very Helpful)
Ecollier2012
Rank: Guru  Hitachi ExpertHitachi Expert
Rating: 92%, 309 votes
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Was this helpful?
Yes
No
Solution #5
posted on Apr 21, 2009
Not Rated)
MTVNJ
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem. I could not afford a new TV.
I called Hitachi for a local Hitachi repair center.
They replaced the convergence modules and cleaned the picture tubes.
They soldered some other items.
They explained that the convergence modules are the common repair for these TVs.
This repair is not for the non-professional.
The costs $512 with tax and one hour. I live in the New York Area.
The cost may be different in other areas.
$500 repair vs $1500 new TV?
Now my TV is like new.
I hope this helps.
Was this helpful?
Yes
No
Solution #6
posted on Jan 24, 2009
Not Rated)
12porkchop
Rank: Apprentice
Rating: 0%, 0 votes
I have red and blue across the top of screen how do we fix it.
Was this helpful?
Yes
No
Solution #7
posted on Jan 10, 2009
Not Rated)
mdurette
Rank: Apprentice
Rating: 0%, 0 votes
red green & blue r off changed convergence chips & resistors that were burned out magic focus starts but stops on red at the 3rd line and than #5 comes up on the right bottom corner of the screen tried manually to focus but lines will not move why i need my tv back bad any suggestions thanks
Was this helpful?
Yes
No
Related Problems
We have an Hiatchi UltraVision Model# 53SWX10B that the...
I have a Hitachi 50v500. It has a bluish tint like a cloud...
my tv started showing double and blury. what do i do to...
The sound comes on when turned on but goes off after about 3...
I have a Hatachi 53" ultra vision digital and i was watching...
Can you Help with these Projection Television problems?
hatachi projection screen problem
Solve
the blue lens has a bow in as dones the green but the red is fine.how do i ge the bows out i can do... (More)
my hitachi 50c20 50 inch tv has had...
Solve
my hitachi 50c20 50 inch tv has had a purple tint ever since the bulb was replaced what can I do? It... (More)
I HAVE A HITACHI 36
Solve
i have a hitachi 36" crt type tv. i have no audio output from the rear jacks.
spot in screen.
Solve
looks like the screen is flexed a lil. or a dent in the screen dont know ho w to get screen off to... (More)
25 Other Users Have The Same Problem - Continued
Comment by djavone91, posted on Sep 18, 2008
yea my screen blue lens is unlined looks as if it has ghosts
Comment by danlyons69, posted on Sep 15, 2008
red shadow and tv shuts off occasionally
Comment by gold5ie, posted on Sep 10, 2008
all colors have a shadow and after the television is on awhile it will shut off.. Any suggestions on how to fix it
Comment by Guest, posted on Jul 26, 2008
hitachi tv has ghosts
Comment by timcraddock, posted on Jul 22, 2008
Blue color seems to be out of adjustment. Cannot adjust with Majic Focus or manually with controls. What do I do.
Comment by bobnast, posted on Jun 19, 2008
Having the same problem with the reds, blues, and greens. Sets about 5 years old. What to do???
Comment by Shendandoah, posted on Jun 13, 2008
Red ghosts suddenly appreared. Check out transreceive by connecting to other TV, no problem. Replaced S Video cable to TV. Tried Magic Focus but no fix
Comment by Guest, posted on Jun 11, 2008
same problem except after magic focus 10 flashes mainly green ghost sometimes worse than others. tried cleaning, got better picture but still had ghost problem
Comment by Guest, posted on May 09, 2008
ghost and red color around images but if i let the set warm up for 20 min the magic focus will sometimes work to correct the problem
Comment by Guest, posted on Apr 18, 2008
Hitachi # 53FDX20B same problem. What is the
cost range for a technician to come to your home? Magic Focus results in same manner.
Comment by briankehoe, posted on Apr 03, 2008
I have the same problem - blue is ghosting - majic focus runs for a minute, then goes blank and shows a number 5
Comment by Guest, posted on Apr 01, 2008
Yes, i too have the same problem. I cannot converge the 3 colors using the interface, so I wonder if it may be a problem with the lamps. The green seems to be the most off.
Comment by Guest, posted on Mar 19, 2008
I have ghosts when i first my tv on after 20 min i use majic focus and that clears the problem but if i turn the tv set off and back on the ghst are there
Comment by CTurp, posted on Feb 23, 2008
I'm having a similar problem. Mine is a green red ghosting. The red seems to be ghosting about 2 inches below the green across the top third of the screen. I opened up the TV and there is a distinct 1/4 grayish black line running just to the left of center on the red lens. Any relation to my problem? How can I fix this? Is it simply out of convergence? How could this just happen one day? Any help, suggestions or input is greatly appreciated.
Comment by dgdick, posted on Dec 23, 2007
hitachi model 51SWX20B purchased 3/6/03. Magic Focus gets 5 in lower left of screen. Tried manual focus, and green lines on left side of screen are wavy. Aligned red and blue, so picture is clear, but left side of screen is vertically wavy.
Comment by Guest, posted on Dec 06, 2007
hitachi 53 projection tv with major convergence problem. red image is approximately 2" to the right of other images. tried the magic button to no avail. Wonder what next step is if any.
Comment by collier, posted on Dec 02, 2007
i have blue convergence problems is it true that if i change the convergence correction circuit 6 channels and output muting circuit this will fix my problem there should be two of these ic's ? and what circuit board are they located on ?
Comment by nick9, posted on Nov 22, 2007
I have a Hitachi 61SWX10B, which was purchased in 2002, and my TV started having the color converse problem/3D type of issue a few days ago. I also stated having rpoblems with the sound where about a minute after I turn on this TV, either the sound disappear or it starts making some wiered noise.
Comment by mateomasc, posted on Nov 06, 2007
my colors are not in sync anymore and my magic focus doesn't work after a few seconds on magic focus 5 just apears on the bottom of the scream.
Comment by Geo68, posted on Nov 03, 2007
Same issue but when using the magic focus it goes thru blue and green quickly and takes 20-30 seconds to get through the red. Magic focus does not fix. Alignment of colors in center appear closer to normal but red aligns higher toward bottom of screen and red aligns lower toward top of screen.
Sponsored Links
Describe your TV & Video problem:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 2825
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Projection Television Experts
Top TV Repair
(407) 952-4048
WE REPAIR ALL BRANDS TV-BIG SCREEN-PLASMA-LCD...
        JR  ELECTRONICS
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
