Question about FrancisFrancis! X6 TRIO
Francis Francis X6 trio stops after the third cup of coffee
My trio X6 stopps after the third cup of espresso, i have to switch it off wait untill it cools down and do the cooffee. The pump starts sort of missing and then it stops... Any help?
  • 10 Answers
SOURCE: francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Posted on Apr 01, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Francis Francis X1 - Cleaning lime from tank
CLR rinse followed by a vinegar brew then a clear water brew cycle
Posted on May 21, 2009
SOURCE: Need gasket for Alessi 6 cup stove top espresso coffee maker
I have a Elevation Espresso Coffee Maker it worked fine until today when it stopped heating the water. Any help would be great.
Regards
frank
Posted on May 31, 2009
  • 1089 Answers
SOURCE: my francis and francis is leaking and the espresso
Hi
Try calling Illy at 877-469-4559. They can help you get your machine fixed.
Posted on Jul 16, 2009
SOURCE: I have a Francis X1 Trio. Has anyone ever tried to
I would be interested in the same. Did you manage to order a ground coffee adapter for your Francis x1 Trio and if yes, does it work? Thanks
Posted on Jan 02, 2010
Hello, We bought X6 TRIO from usa. We live in
You will have to look at the machine. It should say the voltage it operates on. I would use a transformer unless I'm sure.
Aug 21, 2013 | FrancisFrancis! X6 TRIO
Need to know the tonage on a goodman model ck42-1c serial #9904471120
you have a 3.5 ton unit. this is what the 42 in the model number stands for...42,000 btu.
One ton of "refrigeration" is equal to 12,000 btu
I hope this helps
Aug 17, 2010 | Goodman Francis Francis X6 POD Espresso...
I have a Francis Francis X3 machine and would like the attachment to use ground coffee as at the moment I can only use pods.
If you have an X3 Trio you are out of luck.
If you have the older model, you can buy 'ground coffee conversion kits' or you can use a ground coffee portafilter from an Ascaso Dream/Arc etc.
See: http://coffee-stuff.blogspot.com/2009/11/thing-of-beauty.html
Oct 29, 2009 | FrancisFrancis! X3 Espresso Machine
I need a Francis Francis x3 portafilter for ground coffee
If you have an X3 Trio - you are out of luck.
Oct 09, 2009 | FrancisFrancis! X3 Espresso Machine
Francis Francis X6
It is possible that the gasket under the spring is damaged, remove the screen and diffuser and check the spring and gaskek in the middle hole. You can try backwashing which might force the spring and gasket in position.
Jun 26, 2009 | FrancisFrancis! X1 - Stainless Steel...
I have a Francis X1 Trio. Has anyone ever tried to use ground coffee and can it work. I hate the pods and would love to try to use regular ground with a tamper, but I'm afraid of ruining the machine.
You need a ground coffee adapter, these are available from various sites online. Do a web search for X1 ground coffee handle and you'll find one. Make sure it's the right one for your machine (check to see if you have the aluminium or brass boiler version)
Just found this site - It's in the UK and I'm not sure if you are but they will probably export to you.
http://tinyurl.com/lhxvg6
Regards
Richard
Feb 18, 2009 | FrancisFrancis! X1 - Stainless Steel...
I need a manual for the Francis Francis X1 Trio' espresso maker
I have pdfs of the user manuals for X1 & X2 machines, email me me if any use to you
Jan 03, 2009 | Coffee Makers & Espresso Machines
FrancisFrancis! X6 TRIO Logo
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
