The cd draw has locked it self dont know how to
The cd draw has locked it self dont know how to open it? its a compact component system
  • 2 more comments
  • rcaroline197 May 16, 2009
    i cant see a small hole?
    its a stack system with a 3 cd multi change?
    i know im realy thick weres the drive????
    there is no hole ?
  • 33 Answers
There will be a small hole on your drive.... insert a safety pin in it....it will unlock...
Posted on May 16, 2009
My jvc compact component system cd drawer won't open
The loading belt is broken, or the gears are jammed and locked down, either way a major dis-assembly will be required to attempt repair.
Mar 27, 2012 | JVC Audio Players & Recorders
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
I have a kenwood compact hi-fi system xd-751 the 3
I have a Kenwood hi-fi system XD Series. the three disc draw won't open or play discs. The table shudders when on...can anyone please find a repairer in the adelaide district.
Dec 04, 2009 | Kenwood Audio Players & Recorders
My NAD cd-player has locked it self! I cannot play the cd's or even open to take the cd out. What can I do? Marit
Mine does the same. Press eject and give the front of the draw a sharp tap.. the draw should then open.
Also when loading a disk give the draw a hard shove closed just as it is almost shut - seems to make the disk read ok.
I think both problems are related to a worn / slack tray drive belt... I just haven't been able to find a replacement.
Nov 12, 2009 | NAD C521 CD Player
Will not play CD's ,press play and the drawer opens
darkie u need to clean your lazer i had seem problem with same model jake here
Dec 08, 2008 | Audio Players & Recorders
My compact component system mx-gc5 keeps turning it self off after u turn it on. it stays on for like 10 sec
This is probably a fault on the power supply sometimes caused by a diode. If you are capable investigate but if not PLEASE dont try anything to put your life in danger as the voltages present in the stereo can easily kill or injure. Good luck.
Sep 26, 2008 | JVC MX-GC5 CD Shelf System
P-Error on JVC compact component system FS-GD7 when turned on
1. Unplug the JVC compact component power cord from the power outlet.
2. Unplug any connected devices.
3. Press and hold the JVC compact component power button for five seconds.
4. Plug the JVC compact component power cord back into the power outlet and turn on the JVC compact component
5. Open the menu to confirm that the JVC compact component is responding again.
6. Turn off the JVC compact componentand reconnect the devices.
7. Turn on the JVC compact component...
Jul 23, 2008 | Audio Players & Recorders
HNSE05SS Compact Frig
There are very few parts on this unit. UNPLUG unit jump out the 2 wires to the t-stat. plug it in, if it runs the t-stat is bad.
After that theres the overload /start component on the side of the compressor. UNPLUG remove cover look for burnt wires , wires are ok feel if the compressor is HOT to the touch. if it is it could be off on internal overload. let it sit for a while plug in and listen for a hum or click in the compressor. If there is a Hum then click your back to eather your overload /starter is bad of the Compressor is bad. If you have an amp meter you can check the compressor by clipping the meter on power wire. on the information tag that has the model and serial # there is a amp draw for Lock rotor. If the unit draws Lock Rotor amps the compressor is bad.
May 21, 2008 | Haier HSB03 Compact Refrigerator
"Locked" CD does not come out
Turn off the power, and then hold down the "stop" button on the actual system (not the remote). While you're holding down "stop," push the "eject" button on the system and it should say "unlocked." If ever for some crazy reason you might want your tray to lock again, just do the exact same thing until it says "locked."
I have this problem all the time and it's sooooo annoying. It just seems to happen randomly every now and then.
Mar 17, 2008 | Audio Players & Recorders
105 people viewed this question
 Grubhead
Grubhead
