Question about Yamaha RX-V490 Receiver
Monitor problem problem this monitor condition is ok but osd not display in screen ..vedio section is ok (ic lm 1246,2476)
    Brigadier General:
  • 8,546 Answers
I don't see any OSD in the RX-V490 owner's manual. This unit only passes video through from a video source, like a VCR.
Posted on May 16, 2009
Benq q5t4 monitor. power on "BENQ" display is
i want data for benq q5t4 moniter eprom 24c04 ic my moniter is not working properly
Dec 17, 2010 | BenQ FP51G 15" LCD Monitor
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Im trying to adjust my philips lcd but menu says "osd main control is locked" how can I unlock it?
In order to resolve the OSD menu locked error:
1. You must reset the on screen display in the menu.
2. Hold down the Menu button for at least 60 seconds.
3. A menu list will appear on your monitor screen.
4. Using the adjust button, press the arrows to enter the menu.
5. Scroll down to the Reset section.
6. On the right side of your screen, you will see an alternating Yes/No choice.
7. When the Yes message flashes, press the Ok button.
8. The menu should be reset and the flashing OSD control message should disappear.
Apr 12, 2010 | Philips 190B6CB/27 19" LCD
OSD Locked pop menu
You must reset the on screen display in the menu. Hold down the Menu button for at least 60 seconds. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section.
On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Philips 190B6CB/27 19" LCD
Osd lockout
Hi friend,
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"....if the problem continues. Switch of the monitor and remove the power cable and connect it again after some time.
Thanks,
Dec 10, 2009 | Computers & Internet
700e Lg crt monitor problam power on eht on but not display
The normal crt monitor have a demo display when you unplug the vga cable to PC like this image below.. fd6b6b9.jpg
Note:
If the crt monitor green LED light steady and heater beam have light, the horinzontal and High Voltage supplied to tube is completely good. If you encountered this problem just focus on video section of crt monitor. But before you start... find the flyback transformer behind this they have two controls screen & focus. After you found it plugin the monitor use plastic precision or small screw philip driver for safety to high voltage at horizontal area choose screen control rotate it to clockwise direction follow this....
5b5166c.jpg If the display responses or from dim to lighter 100% you have a problem to ABL find this at the bottom of horinzontal section near at flyback transformer pins trace the line of ABL for dried solder, open resistor if nothing happen find the Video IC at chroma section and replace it. follow this...
3c6e89c.jpg For LG & Redfox you found LM1269NA Visit this site for seaching semiconductor matches www.alldatasheet.com Good luck.
Check this site for searching semiconductor
Aug 12, 2009 | LG Studioworks 700S 17" CRT Monitor
On Screen Display is being shown permanently
Its aproblem of command section.Check its components one by one.you can identify this section (the front panal buttons goes in this section and a ic in big size and pasted horizantally in the circuit).if the components are ok then change command ic with new one.This will solve your problem.
Jul 31, 2008 | SAMTRON 55V 15" CRT Monitor
Osd main controls locked/unlocked pops up every 5 seconds
Press the Menu button ( marked OK) for one minute, or more, and a blue/red menu list should appear on screen.
Using the adjust button (immediately to the left of the OK button) by pressing the arrows at each end up or down as required you can enter the menu and select an action by scrolling.
At the end of the list of possible adjustments on the left of the screen (brightness, contrast, etc) is the Reset section.
On the righthand side of the screen is a flashing Yes No choice which automatically alternates.
The trick is to select the Reset choice on the left and while selected press the OK button when the Yes alternative on the right of the screen is flashing.
You VDU should then Reset and all will be well.
Mar 26, 2008 | Philips 190B6CB/27 19" LCD
No Display.
the problem is seem to be in your moniter vedio driver ic which is present inside the moniter it is programmable ic, it may get heated or corrupted so pls check your moniter
the service manuals are available at eservice.com
Mar 18, 2008 | ViewSonic VA2012WB Monitor
Screen settings problem
OSD = On Screen Display. Once loaded it is normal for the OSD to stay on your screen untill it times out or you Exit it.
Nov 24, 2007 | Samtron MONO TTL 13 Monitor
Yamaha RX-V490 Receiver Logo
91 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
