Question about Epson Perfection 3200 Photo Flatbed Scanner
Dull negatives My scanner works fine except that the results on-screen, of scanned negatives, is an overall darkness. The negatives and the original prints are excellent. I suspect there is not enough light when scanning. Epson Perfection 3200 Photo scanner
  • 526 Answers
Re: dull negatives
Are you using the a transparency adapter on the negatives?
Posted on Dec 20, 2009
0 characters
3 Points
How do I scan negatives?
You can try scanning negatives the same way you scan prints, but the results may not be great. Scanners that are designed to scan negatives usually have some way to put light behind the negative to make sure it scans with enough contrast. They often also come with special holders for negatives. I don't know if your model was specifically meant to do negatives, but you can't hurt anything by trying.
After you scan a negative you need to convert it to a positive. The scanner may have come with software that can do this. If not, IrfanView is a free program that can do that as well as much more. It's a great general-purpose image viewer, so it's worth downloading in any case.
May 13, 2011 | PANDIGITAL PANSCN05 Film Scanner
Dull muddy colors with extra color on backgrounds
please send Artec scanner Drive 2000
Sep 24, 2009 | Canon Scanners
Canon 9080C not scanning 11x17 pages
The problem is probably in your scanning software, you have to tell it if you want to scan legal size, and if you leave it set for legal all the time it might put dark bars under the letter size docs. It depends on the version of software on your computer.
Sep 03, 2009 | Canon DR-9080C Path-Through Scanner
Negatives scan as negatives and not as pictures with the plustek 7300
In the Twain driver for your intellscan, there should be a selection for the type of scan. It should be set to "black & White Negative" or "Color Negative". The program you use to edit the scanned file should be able to change it to a positive if the scanned result is still negative. Programs such as Photoshop, Paint shop Pro etc can use Twain to have the scanner scan directly into them. There the phot (negative) can be edited and saved.
May 30, 2009 | Plustek OpticFilm 7300 Film Scanner
Vertical colored lines in a scan
If the lines appear in the same location everytime, then it is from the scanner glass. Clean it thoroughly. No solvents except Isopropyl alcohol for cleaning.
S. Mohan, India
Mar 02, 2009 | Umax PowerLook III Flatbed Scanner
Unable to scan b/w neg's correctly using Digital ICE
Unfortunately, you cannot use Digital ICE on B&W films due to silver particles contained within the film. The Digital ICE future only works with C-41 (negatives) and E-6 (slides) processed films, but not B&W films.
Jan 16, 2009 | Nikon CoolScan V ED Film Scanner
Scanned image appears to have an exposure problem
Are you using the software from HP? It sucks. Use the one provided my your operating system works great. Go your Control Panel, Printer and other Hardwares and click Scanners, make a shortcut to your task or start menu and Scan Away!!!!
Jan 10, 2009 | HP ScanJet 5300C Flatbed Scanner
Scanning OLD Negatives - old browning? Scanner is cutting half
you better not used the automatic detection of the pictures, it never works fine
Dec 08, 2008 | Epson Perfection 4490 Office Flatbed...
Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
Epson V700 Photo Scanner
are you scanning it at the right resolution and are you using the negative holder?
Nov 09, 2007 | Scanners
Epson Perfection 3200 Photo Flatbed Scanner Logo
138 people viewed this question
Top Epson Scanners Experts
Are you an Epson Scanner Expert? Answer questions, earn points and help others
