Question about LG GSA-H10A Burner
How do you set a LG GSA-H10A DVD Drive as a Slave?
Which of the three jumpers is the Slave Jumper?
Closes to Data Cable or Middle jumper or closes to Audio Socket?
    Novelist:
  • 113 Answers
on the drive there will be printed or stamped:
MA, SL, CS (maybe in a different order.) Often there is a printed label, and often the re are tiny letters stamped either above or below the jumper pins.
You need to place a jumper in the vertical position over 1 set of pins corresponding to the map above.
ie if you want the drive to be a Master, jumper the vertical set marked (or indicated) as MA.
If you want it to be Slave, jumper the SL set.
If you want the drive to be set depending on where on the IDE ribbon cable is conected, connect the pins marked as CS.
BIOS will then allocate the drive as either a master or slave.
Using Internet Explorer but not Firefox, get the manual here:
http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=GSA-H10A&initialTab=warranty&targetPage=support-product-profile#
Note the manual is a dejaVu document which will ask to load a viewer plug-in into Internet Explorer.
Actually, inside that document, there is a drawing indicating that reading from left to right (ie from next to audio connector), the pins are: CS,SL, MA. So for example upper and lower pins at the extreme left are Cable Select, so you would jumper those 2 pins.
Cheers,
Steve
Posted on Jul 20, 2010
I replaced the dvd drive with a gdr8162b and added a sony cd/rw Crx217e-ds this computer is a dell 4600 cant get neither of the drives to work
If these drives are IDE deives then check the jumper settings on these drives.
The jumper setting for master (MA) and Slave (SL)
If one of these drives is on the same data cable as the hard drive the the jumper setting for this drive MUST be set to Slave (SL) because the hard drive will be jumpered as Master (MA).
If both of the drives are on the same data cable and the data cable is plugged into the second IDE controller then one of the drives MUST be jumpered as Master drive and the other as Slave drive.
Jun 01, 2012 | Dell Dimension 4600 PC Desktop
I had a Sony drive fail and replaced it with the LG Writer/Reader new drive . The PC does not reconize the LG and I have a Sony reader also and now it does not reconize it either. I just boutht the LG. I...
If the CD drives are parallel type (with a wide data cable connecting them to the motherboard), one must be set as the master and the other as the slave device. This is done with jumpers found near the cable connector. This is what just about every drive looks like from the back:
The jumpers you're looking for are number 3. The drive connected to the end of the data cable should be set as the master (MA position). The slave drive (SL position) connects to the plug near the middle of the cable.
Some systems use a cable that requires setting the drives for cable select (CS). Check the Sony drive you removed and the one still in the system. If they are set for CS, set the new drive that way as well. Then they should be correctly identified and accessible.
Jun 26, 2011 | LG Computers & Internet
Cant get burner to reconised on pc
Since this is an IDE drive, please check the Master/Slave/Cable Select jumpers, if you've connected the drive in the same cable of your hard drive, you should check its jumper settings, if hard drive is set as Master, the DVD writer it should be as Slave, if the hard disk jumper is set to Cable Select (CS), the DVD should be in the same way too. After this check if DVD drive is identified correctly in BIOS, it's a good idea to set drive detection as Auto, if this all is OK, check its driver in Windows, it must be appear as a DVD-RW drive.
Mar 03, 2011 | LG GH22NP21 DVD-Writer - Internal...
Can I put internal LG GH22 rewriter inside external GSA-E60N
First, open the external casing.
You'll find an "internal" CD/DVD drive, connected to an adapter, and the adapter connects to the USB cable.
Now, look at the adapter -- it could be a "parallel-ATA" interface, or it could be a "SATA" interface. The new CD/DVD drive will have to have the same connectors (data and power) as the adapter.
You might have to exchange the SATA device for a Parallel-ATA device.
If you have a parallel-ATA CD/DVD drive, look at the back of it.
There is a tiny jumper, and a few labelled settings:
* MA(ster)
* SL(ave)
* C(able)S(elect)
Move the jumper to the 'MA' setting, so that the USB-adapter will recognize the CD/DVD drive.
Connect the drive to the adapter.
Close the case.
You're good to go!
Jul 22, 2010 | LG Dvd Rewriter Gsa-e60n 20x Ext Black...
How to set as master
u need change in the mother board settings by seeing IDE 0 / SATA 0 , 1 or change in device in jumper settings by seeing in the device cover.
Apr 17, 2010 | LG GSA-H10A Burner
I want to make the LG a slave but don't have a
The Slave jumper is the one in the middle, depending on your set up you could also use cable select which is the first jumper.
Jan 08, 2010 | Computers & Internet
I am trying t find the jumper location on my
I would go to LG website and order a jumper for your drive. They are cheap, so don't worry about the price.
Dec 07, 2009 | HP 5188-7537 DVD Writable CD-RW...
The jumper combination for a slave drive on an LG GSA-4163B
Most CD/DVD drives have a label showing the jumper setting for Master (MA), Slave (SL)and Cable Select (CS).
You only need a single jumper and it is inserted in a vertical position.
There are a group of 6 pins (3 columns of 2 pins) next to the 40 pin IDE connector.
The Slave setting is usually the middle set of pins.
Nov 29, 2009 | LG GSA 4163B DVD±RW Dual Layer Burner
Jumper setting for cable select
The settings should be on the sticker on top of the cd drive.
Mar 13, 2009 | LG Electronics GSA-H42LK LightScribe 18X...
Samsung TS-H492 Jumper
hai
if u have two seperate data cable to hard disk and dvd rw,there is no big changes to made in jumpers,but u have only one data cable u should select jumper as a master to hard disk and slave to dvd rw,
basic identification to master jumper is that ,it place is close to data cables ,and slave is next pin,in typical models
also u se the detail in hdd and dvd rw's jumper locations
thanks
prasanna
Mar 01, 2008 | Samsung TS-H492 (TSH492AWRBH)...
LG GSA-H10A Burner Logo
1,291 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
