Question about Brother XR-65t Mechanical Sewing Machine
I can't find my manual and need to make a buttonhole
    Problem Solver:
  • 13 Answers
I need to know what the settings need to be on the Kenmore 158 machine to use the buttonholer?
You'll have to provide more information about the sewing machine. 158 indicates the manufacturer. However, there are a lot of Kenmore sewing machines from that manufacturer. The 158.1340 manual is available here: https://www.manualslib.com/manual/150291/Kenmore-1340.html .
Page 40 (41 in the linked format) begins the section on buttonholes. With the buttonhole attachment, you need to set the stitch to the second narrowest zig-zag stitch. You can use any stitch length. The description of using the buttonhole attachment starts on page 45.
Without the buttonhole attachment, you set the stitch selector to each part of the buttonhole as you reach them. The stitch length dial has to be set to an appropriate length in the block for buttonholes. The top and bottom tack bars use the same stitch selector. There are separate ones for the left and right sides of the button hole.
I hope this helps. Please add a comment with the rest of the model number on your sewing machine for specifics with your machine.
Jan 04, 2017 | Kenmore Sewing Machines
How do make buttonholes with the Necchi 3102? I followed the instructions from the manual but cannot get the machine to properly make the buttonhole. Any suggestions? Persimmon
Expand exactly the symptoms of what is not working with your buttonhole function. There are generally 5 or 6 steps to a built-in buttonhole, so we need to know which function(s) is/are not working.
http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/3101FA_3102FB_Instruction_Manual.htm
How to Make Buttonhole on Your Sewing Machine Sew4Home
BTW, any zig-zag sewing machine can be used to make buttonholes without the built-in buttonholer or a buttonhole foot. The built-in buttonholer just took the manual method and made a dial to switch to the next step. You can do that manually on your machine. You just need to perform each step manually: knot-on, stitch the bartack, zig-zag forward, bartack, zig-zag backward, and tie-off. I've made many buttonholes manually on sewing machines before having a machine with built-in buttonhole or a buttonhole foot. Just be sure to practice on some scrap fabric first before trying it on your garment.
Until Wednesday Calls How To Manual Machine Buttonholes
Nov 07, 2016 | Necchi Sewing Machines
Need instructions for Singer buttonhole attachment 103233.
I found a manual for several Singer Buttonholers here: http://ismacs.net/singer_sewing_machine_company/manuals/singer-sewing-machine-manuals.html . I'm not sure of the part number for the Professional Buttonholer Model, which looks like the one for my Singer Touch & Sew. Mine is part #161829 (if I read the box correctly).
I hope these help.
Feb 06, 2016 | Singer Sewing Machines
How do you do button holes
Firstly look in manual. Secondly, search online for manual. Thirdly, I seem to remember that you had to select the buttonhole function on the machine. If you haven't got one then you need to sew two parallel lines of stitching very close together, then overstitch at each before finally cutting between the parallel stitches.
Jul 08, 2015 | Sewing Machines
When I press the button to make a buttonhole and step on the power, all I get is a beep. How do I make a buttonhole in that one easy step?!
Is there a little arm you need to pull down behind the presser foot? And a buttonhole foot that needs to go onto the machine?
Do you have a manual for it to check out the buttonhole procedure? try this link
http://www.singerco.com/resources/buttonhole.html for some instructions and images but always good to have the machines manual if you can get one.
Many of the machines with the one step buttonhole function have a white plastic slide type foot and the buttonhole lever that you pull down. You put a button into a clip at the back of the foot to "measure" the buttonhole length. Then start sewing, the machine will do a bartack, then start backwards, the pulldown lever will then connect with the foot when it gets to the right length, start the end bartack, then reverse back up the other side of the buttonhole and finish off when it comes back to the start of the foot.
The Singer will probably be some variation of this system, hope this helps.
Mar 09, 2011 | Singer 7422
I have temporarily misplaced the instruction manual to my White 979 sewing machine. I need to put this shirt in todays mail and I have forgotten the direction to make a buttonhole. I s there a place I...
Automatic BUTTONHOLE making with 979:
  1. Carefully mark the position of buttonhole on your garment.
  2. Slide the button carrier and insert the button.
  3. Attach the buttonhole foot.
  4. Place the garment under the foot so that the needle pierces the fabric at the beginning of buttonhole.
  5. Lower the buttonhole lever and the presser foot lever.
  6. Push the buttonhole lever away from you.
  7. Start machine to complete entire buttonhole.
NOTE:
  • While making buttonholes, maintain an even sewing speed for uniform buttonholes.
  • When buttonholes are completed, be sure to push up the buttonhole lever as gar as it can go.
Feb 11, 2011 | White Sewing 979
I need to learn how to make a buttonhole on my Husqvarna 210 electronic sewing machine.My manual is gone.
You may be able to still get that manual, check with your dealer. If not you can call Viking at: 1-800-474-6437 if it's out of print for a photo copy of the original owners manual.
To make a buttonhole do the following:
1. Turn the selector dial to the top position, That is the first step of the buttonhole.
2. Turn the stitch length dial (the bottom dial) to the picture of the buttonhole, it's between the 0 and the 1 on the dial.
3 Put on the "C" foot and put the tension dial, (the small dial just above and to the right of the needle) on 4.
4. On a test fabric, sew about an inch or so and stop. Turn the selector dial down one click and sew the bar tack of the buttonhole. Just do a few passes, don't build up alot of stitches here.
5. Turn the dial down another click to the 3rd step, the right side of the buttonhole and sew until you reach the place where you started the left column of the buttonhole and stop.
6. Turn the dial UPWARD one click to the bar tack position again and do another bar tack like you did at the top of the buttonhole. Don't build up alot of stitches here, about three passes does the trick.
7 Remove the fabric from the machine and when you cut the threads, leave a tail about 2 inches or so of the thread. From the back side of the buttonhole, pull gently on the thread and a loop from the front thread will appear on the backside. Pull the front thread to the rear and tie off the threads and then cut them close to the knot you tied and the buttonhole will not come apart.
Oct 14, 2009 | Husqvarna Viking 1
Buttonholes
Put on the C foot. Select the buttonhole stitch. The machine will start sewing in the bottom left corner of the the buttonhole. Sew the length that you need, press and release the reverse button and sew the right side of the buttonhole. When you get back to the bottom, press and release the reverse button again and the buttonhole will be finished and the thread will tie off and the machine will stop. If the buttonhole is what you want, press and release the Stop button and the machine will repeat this buttonhole as many times as you need until the machine is turned off or the Stop is pressed again. When repeating, you need not press the reverse. Just press down on the foot control and continue until the machine stops by itself.
If you don't like the first one, just sew another one using the reverse button to set the ends.
Jun 28, 2008 | Husqvarna Viking 1
One step button Hole V for Singer Sewing Machine
Hi, I had the same problem, but I finally found my manual. The solution is that you have to use the presser foot for buttonholes but the most important part is that you have to lower the buttonholer lever. It is located right next to the needle to the left. It is a metal lever with a little square white plastic end. You need to pull that down in order the the buttonhole feature to work. My button was too big for the buttonhole presser foot, so I had to use the regular presser foot, but hit the buttonhole lever with my had to make it go up or down.
Aug 30, 2007 | Singer 7422
Brother XR-65t Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
