Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Portable Hard Disk not being recognised
I have a portable 60 gb hard disk. ( Brand Buffalo). When I switched on the computer my keyboard would not function and I noticed that my portable hard disk was not showing up in explorer. When I rebooted, the keyboard started doing fine but the hard disk is still not showing up. I changed the case thinking that it might be the case. But that does not seem to be the problem .
I have important data on it...any advice as to how to get it working or just recover the data.
  • dillyman May 16, 2008
    Have a 160 Gig ide hdd as c and d partition. Added a new Sata 7200 500gig hdd on the sata MB connection. BIOS enabled , show up as IDE 3 drive on boot up info but is not visible in windows explorer. I have tried removing the pin doppler pin as in master or slave drives although I did not think it was required. I get a nessage searching for fixit file, tried the MB setup drivers disk - no go also put in the PCI Express disk but no response. Still cannot see sata drive in Explorer. MB only a few months old. apreciate assistance
    derek
  • julesbuijs Dec 09, 2008
    mp3 harddisk 2,5 inch fujitsu siemens 60 gb
    casing works fine, but doesn't show up in explorer though its recognized by safely remove hardware as generic usb disk usb device
    got some tips?
  • 74 Answers
If you cannot get the USB connection working, you can recover the data by taking the drive out of the case and connecting it directly to the PC as a second drive.  Make sure the jumper settings are correct for use as a second drive.  You can get the drive information and jumper settings from the web site of the drive manufacturer.
Posted on Oct 16, 2007
My external buffalo hard drive is not being recognised by my laptop
Right click on My Computer (or Computer is Vista/7) and select Management from the menu. Click to expand Storage and then click on Disk Management underneath it. It may take a couple of seconds for the area on the right to populate.Scroll down in the lower pane and see if you can locate your external hard drive in the list. When you locate it, right click in the left area that says Disk # and see if there is an option to Initalize the disk. Click on Initalize.
Mar 20, 2011 | Buffalo Technology DriveStation HD-HC500U2...
Can i make my portable hard drive an external hard drive?
It is already. Just connect it to a USB port and it should pop up as a new drive.
Jun 02, 2010 | Buffalo Technology 250GB MINISTATION TURBO...
My buffalo external Hard disk is not working in the Philips DVD player. 4 gb pen drive of Sony is working. What is the problem..? how can I correct it........?
Some usb input ports on dvd players, projectors, etc. have a limit to what size it will read from. Right now it's usually 4 gb to 32 gb.
Apr 03, 2010 | Buffalo Technology 320GB MINISTATION TURBO...
PC not recognising Iomega Prestige 320gb usb portable hard drive. I've connected it all up, disconnected, reconnected, rebooted the computer, but the drive is just not recognised and does not show up in...
Does the drive show in Device Manager? Right click on 'My Computer' and select properties, the open device manager.. Navigate down to Disk Drives or Hard Drives, click on the plus sign and see if your drive is listed. If it is, then right click on the drive name and open properties for the drive. Click on the 'Volumes' tab and hit the 'Populate Button'. It may be the disk just needs initialising, then reformatting before you can use it. If it does need initializing, a wizard should appear to guide you through the process!
If this doesn't solve your problem, try using a different USB cable and/or USB ports on your computer, and ensure to unplug all other USB devices other than keyboard & mouse.
Mar 06, 2010 | Prestige Portable 320gb Usb 20 IOMEGA ...
I have purchased a Buffalo portable Hard Drive & I cannot get it to work. Model - HD-PE320U2. Any Clues??
just connect the cable in to the system and go to disk management system by right click on my computer and go to manage option in that you will see disk management option. if it is listed there then access it other wise go to device manager option and check there is any devices listed in yellow mark uninstall it and refresh it. It will automatically install .still you facing the problem then change the usb cable.
Jan 14, 2010 | Buffalo Technology 320GB MINISTATION TURBO...
How to recover files from corrupted drive
hi my 250 gb hard dish but i not detect in any computer
Dec 21, 2009 | Buffalo Technology 250GB MINISTATION TURBO...
Formated hard disk
Go to Computer Management
Then click Disk Management
You Will find Your Portable HDD without Drive Letter
Just Right Click and Assign a Drive Letter...
Thats all...
Enjoy..
-Rajkumar
Jan 29, 2009 | Maxtor One-touch III Mini 40 GB USB 2.0...
I can`t see the harddrive from my PC
Try looking for the drive in the "Disk Management".
Right click on "My Computer" or "Computer" and select "Manage" then select the "Disk Management" item.
If you can see the drive, but there is no drive letter assigned, you may need to format it for your operating system or create an accessible partition on the drive. You can access all these options by right clicking on the drive from the "disk management" screen that you should be on.
mine needed to be initialized (by right clicking on it) and then i formated it
Good Luck!
Oct 26, 2008 | Buffalo Technology 250GB MINISTATION TURBO...
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
169 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
