I have an LG RH188 DVD / Hard Disk recorder. Whenever I turn the machine on, I get a very very loud mechanical-sounding whirring noise from within the machine. It starts as a series of brief noises, maybe 10 of them spaced out by about a second between, then whirrs constantly for about 5 minutes before eventually settling down. I can watch DVDs / play the hard drive content during this time, but the sound is noisier than the level of the TV and is really distracting. Would prefer to fix rather than throw out!
  • 2 more comments
  • martin835 May 16, 2009
    ok, how do I check? What am I looking for, and is this something I could sort out myself?
  • martin835 May 17, 2009
    Thanks for the response - when you ask if I can run DVDs without the hard drive, do you mean somehow disabling the hard drive? Certainly the machine will play DVDs, or content from the hard drive, and the noises it produces seem independent of that. The noise stops after a few minutes and doesn't come back as long as I leave the machine switched on.
  • martin835 May 18, 2009
    No, the player is on an unenclosed glass shelf with nothing resting on it. The noise occurs immediately when the machine is turned on - it doesn't have time to get too hot. I think I can also hear the fan functioning normally once the noise calms down; this is a hard, loud, mechanical noise akin to running a food mixer or a vacuum cleaner - I assume the fans in these machines are generally quite small.
  • martin835 May 27, 2009
    It's independent of the CD / DVD. Will check fans etc.
  • 749 Answers
It seems like there is a problem with the internal fan, open the top cover and you will be able to detect where the noise is coming from, after this tell me and i will tell you what the exact problem is.
Posted on May 27, 2009
  • 355 Answers
Your player is probably running a few degrees hotter than usual. This causes the fan to spin at a faster than usual speed causing that noise. It can happen if you keep your player in an enclosed space blocking the heat vents from dispersing the heat. Make sure that you place it in a location where it can disperse heat more easily. This will hopefully resolve the issue.
Posted on May 17, 2009
  • Rohit  Asthana
    Rohit Asthana May 18, 2009
    it was the fan at the back of the recorder. I fixed it by inserting a cardboard spacer between the fan & the case.
  • Rohit  Asthana
    It is the foam pad ring from a new CD or DVD spindle that was stuck on
    a disc that you put in and missed it. It does not go back in the drive.
    It goes in the trash.
    The ring is used hold the discs solidly on new retail spindle. The noise was the drive strugging with an unbalanced disc.
    If you caught it right away and nothing hit the laser or lens you are ok. Try reading or burning another disc.
  • 3,267 Answers
If the recorder is still under warranty then the hard disk needs to be replaced, free( I believe their warranty is up to 3 years). The more you use it, louder will be the noise till its scratched up the Hard disk well & good. If the players DVD can be played without the hard disk then do run it to observe if the noise vanishes or not, but i doubt whether this operation can be done. Since it sounds whether you play dvd or from the HD, the noise remains so there's no doubt about the Hard Disk is responsible. I am afraid but either buy a new hard disk or junk it, whichever is cost effective...........sodeep
Posted on May 16, 2009
  • 854 Answers
One possible cause of the noise would be the auxillary exhaust fan built inside the unit. You try to have it replaced.
I have a Panasonic SA-PT960 surround sound/dvd player. Whenever I turn it on I get a chgr err flashing on the screen and a loud grinding noise
There is a fault with the DVD Changer and the noise is the gears grinding. This is a common fault with these units as a small arm within the unit breaks and blocks the mechanism.
You can either try and replace the complete DVD Changer or remove it and just us it as a surround sound system with your auxiliaries connected to it.
May 09, 2011 | Panasonic SC-PT960 Theater System with...
I have a Lacie 1TB Big Disk Extreme. It has recently developed a loud regular whirring noise, that goes on and off every few seconds. What should I do? Thanks! Adrian
The irregular clicking or chunking sound usually indicates that your hard drive is suffering from physical damage. immediately backup your data, your hard disk will die soon.
This problem can be caused by the following:
  • Head Crash
  • Bad Sectors
  • Mechanical Faults
If your hard disk is under warranty then you contact your manufacturer.
Hard disk drive occasionally produces a whirring sound when it searches for a file which is heavily fragmented. This is caused by the spinning platters as the read-write heads zoom back and forth to access the sectors where the data is stored. It is important to distinguish the whirling sound from the clicking sound. This whirring sound can be reduced by periodically defragmenting your hard drive. Defragmenting reorganizes the scattered data on the hard drive to make files and programs run faster. It relocates the commonly accessed files to the beginning of the hard disk where data can load at a faster rate.
Apr 08, 2011 | LaCie Big Disk External USB 2.0 1TB Hard...
Our LG bottom freezer refridgerator is 2 years old. It is making a whirring noise that stops when the door is opened. It can get pretty loud at times.
The whirring sound is the fan that blows cold air into the refrigerator. It is supposed to stop when the door is opened. If it is making a loud noise there may be ice built up in the fan housing. Turning the power to the refrigerator off for a 2-4 hours may allow any ice in the fan to melt. If you do not open the freezer during that time the frozen food will not defrost.If the noise continues, you may have to take the fan apart to make sure it is not frozen. It is probably located behind the back inside panel of the freezer.
Nov 02, 2009 | Refrigerators
LG RH274H DVD Recorder keeps opening and closing the disk tray
Did this problem get solved? I have the same machine and the same problem. Any help would be appreciated.
Mar 22, 2009 | LG RH177 DVD Recorder/HDD Recorder
Dvd recorder will not play or record
≥The disc is scratched. Use another disc.
≥The disc is dirty.
≥You inserted an incompatible disc
Dec 28, 2008 | LG RH188
Dmr-es15 "can't read"
after I record a show then I push stop, it writes it to disc and gets up to 96percent and then fails.
Oct 10, 2008 | Panasonic DMRES15 DVD Recorder
I purchased a HDD/DVD Model RH1888H from myer approximatley 18 months ago,For $600 I have never been able to get it to record via my high definition set top box and gave up on using the recorder function i...
I have RH188 and I couldn't play DivX movies with it when the codec of it is Real Media codec (RMVB extension). Is there any way to update software or firmware of RH188 to solve the problem?
Sep 21, 2008 | LG Televison & Video
Cant read discs
I had the same and brought it back and they replaced the DVD unit. After another 6 moths I had the same and they had to replace it again. I think LG DVD units are lousy.
Mar 02, 2008 | LG RH188
Televison & Video Logo
219 people viewed this question
Top Televison & Video Experts
Electro Med Services...
