Garmin Forerunner 205 GPS Receiver Logo
Posted on May 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with garmin navi 205w
Hi i have garmin navi 205w by mistake i was delete the file and i use my friend gps 265w file to copy to my gps but it not work when i turn on my gps sayno detailed maps found that support rounting the navi cannot be use without them .
TO Lady
Level 3:
  • Garmin Master 638 Answers
  • Posted on Mar 04, 2010
TO Lady
Garmin Master
Level 3:
Answers
638
Questions
Helped
238500
Points
1156
You will have to send it to Garmin with your original receipt and they can reload the maps your unit came with. There may be a charge for this service.
3helpful
2answers
I have Garmin Nuvi 265W. When I plug my car charge to charge up the battery and use the Navi at the same time, I only get the "GARMIN" screen connected the computer but can't use Navi function...
Try a hard reset,the Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  3. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  4. Press "yes" and the unit will reboot. This resets all your location settings and user preferences
Then make sure the unit is fully charged,then go to the Garmin site and register your product. Then download Garmin Updater and connect your unit with a usb cable directly to your computer and not thru a USB hub. Let the update go directly to the GPS and not a folder. It will take a few hours even with a fast internet connection. I have attached a link to the Garmin site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
tip
Nuvi 265W Webupdate
Garmin Nuvi 265W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 265W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Download Nuvi 265W Manuals here.
Garmin Nuvi 265W Hard Reset Here.
Garmin Nuvi 265W Favorites Backup here.
tip
Garmin Nuvi 265W Favorites Backup and Restoration Procedure Models: Garmin Nuvi...
Would you like to back up a copy of your Garmin Nuvi 265W Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
I hope that helps.
Download Garmin Nuvi 265W WebUpdater here.
tip
Download Nuvi 205 Manual Models: Garmin Nuvi 205, 205T, 205W, 215,...
Models: Garmin Nuvi 205, 205T, 205W, 215, 215T, 255, 255W, 265, 265W, 275
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 205, 205T, or 205W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
tip
Download Nuvi 205W Manual Models: Garmin Nuvi 205, 205T, 205W, 215, 215T,...
I hope that helps.
tip
Download Nuvi 205T Manual Models: Garmin Nuvi 205, 205T, 205W, 215, 215T,...
I hope that helps.
tip
Download Nuvi 265 Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 265 or 265W GPS?
I hope that helps.
tip
Download Nuvi 265W Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
I hope that helps.
tip
How to Download your Garmin Nuvi 205 or 205W Users Guide. Models: Garmin Nuvi...
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 205 or 205W GPS?
Both manuals are available from the Garmin website, or just follow the photo links below:
I hope that helps.
tip
I hope that helps.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
