Question about Motorola Mobility Q Smartphone
Sound problem I have a recurring problem with the Q. At random times it quits emitting sounds, like ringers, or keypad tones. This means that I cannot tell I am getting a phone call unless I have the phone switched to vibrate. I have tried everything I can think of, including hard resets, and update of software. I have the earpiece volume at the highest volume. It occasionally will revert to having sound but it does not last.
Re: sound problem
Hey I had that problem before... It used to happen every once in a while... The problem stems from the fact that I went to a University where the cell phone reception indoors was 0, so it would revert to saying "No Service" inside. I had the options enabled for the phone to beep when it looses service or switches to a roaming carrier. The problem seemed to occur after being inside where it kept beeping as it switched from "No Service" and then going to a roaming carrier, then my Home Network (Telus in Canada)...
To fix the problem, WAIT UNTIL THE UNIT IS EMITTING SOUND, then disable the beeping when switching networks, and disable the "No Service" beep.
You should have no problems with loosing sound after that.
Posted on Oct 25, 2008
  • 46 Answers
Re: sound problem
All you can do is a battery reset. Important thing for battery reset is to always make sure unit is on. Remove the battery. Wait 10 sec and then put it back in. Other then that check your warranty status.
Posted on Nov 24, 2007
0 characters
3 Points
The ringer is off on the blackberry curve, how do i turn it back on
In the sound profile menu, scroll down to SET ring tone/alerts and check that sounds have been chosen as message/phone etc alerts. Also check in that same menu whether your ALL Alerts OFF option is not enabled.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Feb 06, 2011 | RIM BlackBerry Curve 8310 Smartphone
How to get music playing out of my palm it see the sounds and plays but no sound
Check if your ringer volume is turned to low. Adjustment buttons are at the left side of the phone. Check also Prefs under applications - you can set your tones volume there.
Jul 09, 2010 | Palm Treo 600 Handheld
No sound Blackberry
Check your profile settings and make sure that it is not set to phone only or all alerts off. If it is set correctly double check your ringtones and make sure they are set for sound. If those options are there then do a battery pull. If it still doesn't work then I would do a search on the website. It is a great site for all things blackberry.
Apr 29, 2010 | RIM BlackBerry Curve 8310 Smartphone
Can't hear ringer
I had this same problem with my Blackberry. You should check the settings on your sound and volume for incoming calls and make sure you have a tone set. You can also find a way to amplify your ringtone by hooking it up to your computer. If you dont' hear anything at all, then check the buttons on the side and see if that increases the volume. Please rate my answer.
Oct 12, 2009 | RIM BlackBerry 7290
My G1 won't make any ringing or media sounds
go in setting ringers and display and check your volume
Oct 11, 2009 | HTC G1
Ringer and speakerphone not working
a lot of the system volumes were put back to default. I only realized this when I downloaded the "Audio Manager Widget". Then I found that I apparently missed a couple volume settings.
also It might be due to the In-Call volume. The only time you can adjust the In-Call volume is when you're in a call (duh!). So, I called my voicemail and put it on speakerphone just left it all the way up and now I can hear the dialpad tones again!
also I think it was swapping from vibrate to full volume when I received an SMS (or was doing multiple things at once).
All sound stopped working on the device. It's an Dream from Optus.
try a quick reboot.. that shud fix all the problems though
if all the above moethod fails... its time to call the manufacturer....
good luck
Jul 08, 2009 | HTC G1
the phone has to be taken to a service center and have the either ringer replaced or it could be a software issue and then it would have to be reflash for the calendar reminder to work.
Sep 16, 2008 | T-Mobile Dash Smartphone
Using a file in MY Rintone file as my call ringer
When Your Ring Tone Is Highlighted Click on it then click Menu And Select Set As Ringtone. That Will Now Be Your Defaullt Ringer.If You Want It To Be A Custom Ringtone i can't help you with that sorry.
Jun 24, 2008 | Pantech Duo Smartphone
Just set keypad tones to "off" from the sound preferences option.
May 27, 2008 | RIM BlackBerry Pearl 8100
No audio from speakers
With other models (I don't know about the 6515) there's a known hardware issue with the switch in the headphone jack sticking, getting bent, or breaking. One discussion at: If the phone ringer is on the same circuit as the rest of audio, then that would not be the explanation. But I can also imagine the ringer being a separate circuit. Good luck.
Sep 12, 2005 | HP iPAQ hw6515 Pocket PC
Motorola Mobility Q  Smartphone Logo
101 people viewed this question
Top Motorola Mobility PDAs Experts
David Payne
David Payne
Abby Carter
Are you a Motorola Mobility PDA Expert? Answer questions, earn points and help others
