Question about Panasonic DMR-E85H DVD Recorder
The machine stops and goes to self check
When ever I try to play a dvd the machine stops and goes to self check mode and this continues on and on.
  • 31 Answers
This problem was solved by Randychev. Do a little searching for his solution. It worked for me but on a diferent set of capacitors. I went to Radio Shack and replaced the bad parts and the problem wos fixed. He even gives you pictures to explain what to do precisely. Good luck!
Posted on May 27, 2009
  • Robert Morris
    Robert Morris Oct 30, 2012
    How do I find Randychev solution for "goes into self-check" on this site?
The video 1 and video 2 display flashing simultaneously back and forth...cant play dvd cause it continually switches back and forth
Try a different resolution setting.
You can also try playing the dvd into another device to confirm dvd works fine.
Check output\mode of device as well.
I assume, you inserted another dvd and it worked fine, then you inserted the "questioned" dvd is it flashes back and forth.
Try another video mode or setting change on device.
Jul 22, 2014 | Televison & Video
Why does my Dvd player in Flatscreen TV continue to try to eject disc when it has already been taken out?
My first guess is that something is jammed inside and is triggering the eject mode.
Have you tried inserting and playing a disk?
Apr 25, 2014 | Televison & Video
My machine goes into self checking mode and gets stuck.
If it's going into self-checking then either there is a problem with the drawer deck mechanism not being able to communicate with the logic board, hence the reason it stays in the self check. Contact your local Panasonis dealer to arrange a service engineer to perform a software update on the recorder as your current software could either be an older version or has been corrupted & needs to be updated.
Sep 05, 2009 | Panasonic DMR-E55 DVD Recorder
Stuck in self check mode
Manually pull down the front shield, then somewhat forcefully pull down the inner shield and maybe two little white pins so the tray is exposed with nothing blocking it. Have someone plug the machine in while you are holding everything out of the way and the tray should start to open. Pull your fingers out quickly so you don't block the tray from sliding out.
Mar 16, 2008 | Panasonic DMR-ES10 DVD Recorder
Corrupt discs
I suggest changing media Use memoreX dvd-r and see if this helps this.
Jan 11, 2008 | Panasonic DMR-E50 DVD Recorder
Problem with cd playing
You have not described the fault or machine type clearly, is it just a CD player, what make and model, shuts down,? CD play stops or machine goes into standby mode or what ?
If stops playing or maybe going into s/by mode, check the cable that connects the laser to the cct board.
Capital98
Dec 14, 2007 | Audio Players & Recorders
DVD Recorder keps re-starting self test & will also not finalize discs.
This seems to be a common problem with the E55 and E85 models, could be one of two things, either the RAM Drive or the Power control ic (STRG6353 primary side of PSU), i would suspect its the latter. You'll need an engineer to replace this component.
Oct 29, 2007 | Panasonic DMR-E55 DVD Recorder
Unit automatically switches off
Maybe all you need is to dust off the DVD player's pickup. I have had this happen several times with several players. After dusting the pickup, those players are still in service.
Feb 15, 2006 | Denon D-M51DVS System
Panasonic DMR-E85H DVD Recorder Logo
167 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
