Question about Samsung HLR5067WX 50" Rear Projection HDTV
Tv will not stay on
I have a 52 inch i think the standby/temp and timer and lamp lights on front of tv blinks the tv will come on for about 20 sec. then cut off with lights blinking check lamp looks ok pulled out to check fan is working need help
thanks
  • mjjj4 May 16, 2009
    all three lights are on
  • Samsung Master
  • 19,396 Answers
If the lamp light is not on, then the TV is flashing because of overheating or because of a fault.
Try first unplugging the TV and leaving it unplugged overnight, this will drain power completely and may solve some problem.
If the TV keeps having a problem, then there is a fault.
Many units have more than one fan (one for lamp, one on ballast, one on board). In that case ensure that all fans are working.
If the problem is not a fan, then parts can cause the problem are ballast board and DMD board.
In that case the parts must be tested before replacement.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here, a common fault is PSU, but part must be tested before replacement.
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts.
Posted on May 16, 2009
  • Ginko
    Ginko May 16, 2009
    All three lights on is just protection . When is overheating you get just temp, and when it is the lamp you get lamp led on. In your case it is general internal fault, the TV must be tested internally, checking PSU, ballast board, Conv. board, digital board, connection boards and optical group.
Sansung model 56 Inch hpl5663w first had a buzzing sound the tv repair man said it might be a color wheel but the tv played well except for the low buzzing sound . then one night the picture went black and...
Hi Charles,
Sorry for the late reply, I'm offline upon purchasing my service.
You have said that you can hear a low buzzing sound before the unit gone to subsequent shutdown and the lamp blinks green(meaning that the unit try to turn on the lamp for consecutive attempts but not generally mean that the lamp itself is faulty.) and the temp led light come on.
As a matter of fact all the information you have mentioned linked to the symptoms you've encountered right now. A low buzzing sound might be caused by faulty FAN inside the unit that trigger the error code (blinking of the standby/temp led light) and turns off the unit automatically due to thermal protection circuit.
However, the technician might be true also that the buzzing sound came from the faulty color wheel. To confirm it, you have to verify where the buzzing sound came from. Color wheel is in front of the lamp assembly. Faulty color wheel can produce the same symptoms you've encountered right now but most of the time, it shows 3 blinking led light at the front panel (Timer, Lamp, standby/Temp).
I would advice you to open the back cover of your unit, fixed the lamp door safety switch with the tape to make it in closed position( if it is on open position the unit will not power up), and then turn on the unit and observe the fans if will spin or not, and check also where the buzzing sound came from before the unit gone to shutdown.
I've suspected that the fault came from the fan based on the led light flashes. Please let me know what you will discover after following the steps above to verify where the exact fault came from. Also, let me know the exact status of the led light at the front panel, (Timer, Lamp, standby/Temp ), which of them lit solid/blinking, it will help us to narrow the caused of the symptoms.
Jdvillanueva
Oct 14, 2011 | Samsung DLP HL-P5663W 56" TV
Hello I have a Samsung TV Model# HL50A650C1FXZA I have 3 lights blinking 2 green and 1 red light what is the problem
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions:
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks.
Feb 22, 2011 | Samsung DLP HL-P5663W 56" TV
Tonight my Sony Wega KDF-42WE655 screen went black and the audio stopped, the standby light (green) blinked on and off for about 30 sec. then the screen came back on and the green light blinked 5 sec or so...
Replace its lamp as existing lamp has been reached at end of its working hours life and need to replace to solve this issue. Please note lamp is not not broken or dead yet so you do not see lamp light on tv front.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for god picture in tv.
Thanks.
Dec 31, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My standby/temp light is blinking and my lamp light is blinking. tv is about two years old. Just started happening out of the blue. It will come on for a few minutes. I have three dogs and it gets dusty...
check the lamp if you havent changed it before that would be the easiest place to start. if the lamp is popped you will see glass pieces rolling around in the lamp.
Dec 22, 2010 | Samsung HL72A650 Television
Tv model # hl-85687 w tv comes on about 20 sec, screen goes blank. tv shuts off. standby/temp , timer , and lamp lights flash on front panel any help what may be wrong?
Have you ever changed the lamp?If not that's where you need to start.Also recheck your model# as I believe it to be in correct.The lamp code is on a sticker on the left side of the tv if it is a Samsung
Dec 01, 2009 | Televison & Video
HI FOLKS, I HAVE A SAMSUNG HL-P5063W DLP TV THAT WON'T TURN ON. WHEN I PLUG IT INTO TO WALL I GET THE SOLID RED STANDBY/TEMP MESSAGE ON FRONT ON/OFF BUTTON. THEN WHEN I TURN IT ON, THE STANDBY/TEMP MESSAGE...
Bad Lamp Call FOX 1-800-227-5369 Lamp number is
BP96-00608A or BP96-00826A $109.00 Mats Electronics is another company for Lamps 1-800-628-1118 or Find one on E-Bay
Nov 30, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Picture works normal for 10 ses then turns off. (3 blinking light
Re-position the safety switch behind the lamp door and if still the same try replacing the lamp.
May 27, 2009 | Samsung HLN617W 61" Rear Projection HDTV
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 11, 2017 | Samsung Televison & Video
Samsung HLR5067WX 50" Rear Projection HDTV Logo
250 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
