Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Showing the error E18 , lens jamming camra wont turn on a show's up error e18
Canon SD890IS Shows e18
connection broken . send ur cam to us for servicimg
Jun 18, 2009 | Cameras
My camra has E18 on the screen
E18 is an internal error, the lens drive mechanism.
Canon has to fix it. If it is not under warranty, it will cost you around $160.
Apr 10, 2009 | Canon PowerShot A75 Digital Camera
Lens is jammed for Canon Powershot SD200
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 05, 2009 | Canon PowerShot A470 Digital Camera
E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
E18
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
It's important that you fix the E18 error first, as the blur of colors may be symproms of a failing CCD. If so, Canon would fix this for you for free IF the camera has no other problems (ie no E18 lens error). Please see the following info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
May 27, 2008 | Canon PowerShot A70 Digital Camera
Canon ixus 500 turns on beeps 4 times,shows E18 on the bottom left of thelcd screen and then turns itself off.
May 25, 2008 | Cameras
Hi, I have a Canon IXUS 40 digital camera - My lens suddenly does not want to close and show me an E18 error code on screen - what is the problem?
Hey there johans, the E18 error code indicates there is a problem with your lens unit or lens cover. It was probably the result of an impact of some sort, or you may have something such as sand or dirt jammed in the device. If you cant see anything to clear and clean away, try turning off the camera and restarting. If this doesn't reset it and allow it to function properly, then you will need to bring it in for service.
Mar 31, 2008 | Cameras
Canaon powershot A10 showing E18 in screen
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Jan 01, 2008 | Canon PowerShot A10 Digital Camera
SD200 E18 Error
E18 is the error that comes when when the lens is stuck, so if the lens is stuck out, turn off the camera, carefully turn the lens until you hear a small clicking noise, then turn it on. I had the exact same problem, and that fixed it for me
Jun 23, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Problem with E18
The "E18" error code indicates an error that involves the lens unit or lens cover. Or it may appear if you apply pressure to the area surrounding the lens while handling the camera. Remove and reinsert the batteries to see if the error code will reset. Generally speaking, there is nothing you can do to correct the problem other than to send the camera to the appropriate factory service center for correction of the error. Following the repair cost you should decide, whether it worth it
Oct 02, 2006 | Canon PowerShot SD200 / IXUS 30 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
160 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
