Question about HP FK784AA Pavilion Slimline s3650f Desktop PC
Installin xp also
I have created partition which is e,installed xp.now what
  • mike wells May 16, 2009
    i am running vista,and want to install xp to run scanner,games that vista WONT RUN.have xp installed,now cant use it
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    What is it your trying to do? Explain a bit further please.
    Sergeant:
    Champion:
  • 225 Answers
You have to install the software driver/s (thru your CD/DVD drive / internet download): of your computer motherboard to enable its system devices like audio, USB etc.... driver for VGA card, Printer driver & other software that you want to use in your computer. best regards
Posted on May 16, 2009
How do I make 4 partition on a 40GB hard disc. What are the proceedings.
Boot up with the Windows XP installation CD
Follow the screen instructions -
Delete the existing Partition.
Create a new Partition (1st) but do not make it the maximum partition size - enter 1/4 of the maximum size.
Create another Partition (2nd) make this the same size as the 1st Create another Partition.(3rd) make this the same size as the 1st
Create another Partition (4th) make this the remaining max. size.
Format the Ist Partition Full NTSF (not quick format)
You can now proceed to install Windows on the 1st Partition.
After Windows XP has been installed and the computer's device drivers, go to Control Panel - Administrative Tools - Disk Management then allocate a drive letter to each of the Partitions then NTFS Format each of the Partitions.
Now each of the Partitions should indicated as Healthy.
Create
Dec 09, 2011 | Samsung (SP0411N) 40 GB Hard Drive
Tip
Dual Boot Xp & windows 7
First you have to create partition.You need at least two partition. One in which you intall Xp and other for win 7. WARNIG BACK UP YOUR DATA BEFORE THIS.*(You can create partion by any hard drive manager you can make a hard drive partition in control panel>administrative tool>create & manage hard drive partition)
Now install xp first in one partition. If you have pre installed then avoid this step.
Now install Win 7 in another partition.
After you restart the machine will ask to chose your os. & just select the required OS.
If any problem appears then just put win XP disk & repair it.
You cant install win Xp after windows 7.
You have to format win 7 before installing Xp.
Commiting any of trick or Tweak you need to backup your data in another HD partition
on Mar 10, 2010 | Computers & Internet
Format
How to partition and format the hard disk using the Windows XP Setup program loadTOCNode(2, 'moreinformation'); You can use the Windows XP Setup program to partition and format the hard disk. To do this, use the following steps: Step 1: Partition the hard disk loadTOCNode(3, 'moreinformation');
  1. Insert the Windows XP CD into your CD or DVD drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer to start the Windows XP Setup program.
    Note If you are using the Windows XP Setup disks, insert each additional disk when you are prompted, and then press ENTER to continue after you insert each disk.
  2. If you are prompted, select any options that are required to start the computer from the CD or DVD drive.
  3. If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver. For more information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base: 314859 (http://support.microsoft.com/kb/314859/ ) Limited OEM driver support is available with F6 during Windows XP Setup
  4. At the Welcome to Setup page, press ENTER.
    Note If you are using the Setup disks (six bootable disks), the setup prompts you to insert the Windows XP CD.
  5. Press F8 to accept the Windows XP Licensing Agreement.
  6. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  7. All existing partitions and non-partitioned spaces are listed for each physical hard disk. Use the ARROW keys to select an existing partition, or create a new partition by selecting the non-partitioned space where you want to create a new partition. You can also press C to create a new partition using non-partitioned space.
    Note If you want to create a partition where one or more partitions already exist, you must first delete the existing partition or partitions, and then create the new partition. You can press D to delete an existing partition, and then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each existing partition that you want to include in the new partition. When all the partitions are deleted, select the remaining non-partitioned space, and then press C to create the new partition.
  8. To create the partition with the maximum size, press ENTER. To specify the partition size, type the size in megabytes (MB) for the new partition, and then press ENTER.
  9. If you want to create additional partitions, repeat steps g. and h.
  10. To format the partition and install Windows XP, go to step 2.
    If you do not want to install Windows XP, press F3 two times to exit the Windows Setup program, and then do not follow the remaining steps in this article.
    To format the partition without installing Windows XP, use a different utility.
Step 2: Format the hard disk and install Windows XP loadTOCNode(3, 'moreinformation');
  1. Use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER.
  2. Select the format option that you want to use to format the partition. You can select from the following options:
    • Format the partition by using the NTFS file system (Quick)
    • Format the partition by using the FAT file system (Quick)
    • Leave the current file system intact (no changes)
    Notes
    • If the selected partition is a new partition, the option to leave the current file system intact is not available.
    • If the selected partition is larger than 32 gigabytes (GB), the FAT file system option is not available.
    • If the selected partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm).
    • If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
    • If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you are prompted to select a file system for both the System and Startup partitions.
  3. Press ENTER.
  4. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to install Windows XP. After the Windows Setup program is finished and you have restarted the computer, you can use the Disk Management tools in Windows XP to create or format more partitions. For additional information about how to use the Windows XP Disk Management tools to partition and format your hard disk, click the following article number to view the article in the Microsoft Knowledge Base: 309000 (http://support.microsoft.com/kb/309000/ ) How to use Disk Management to configure basic disks in Windows XP
Tanks. Cheer!
Mar 23, 2010 | Computers & Internet
Gateway MX6455 - AMD Turion 2.0Gb with 1Gb Ram Stops working and goes to black screen after POST. Will not boot into windows. The more I try re-booting, the faster it stops.
If you recently installed and any new program it could be a corrupt driver. Boot to safe mode by hitting F8 and delete it. If you didn't, you will have to remove drivers individually. Failing hardrive is another culprit.
Mar 04, 2010 | Computers & Internet
How do i remove windows vista and install windows xp with out losing all my other stuff
If your Vista still work, go to the control panel> administrative tools> computer management > disk management > create an additional partition (larger then my documents folde size)
Move your files to this partition then install xp.
A few tips
  • Make sure there xp drivers for each componenet
  • Use driver magician and find xp drivers (check the pc mfg site and download all xp drivers and put them on this partiton too.
  • Use a partition program (dos) and format the vista partition and the hidden partition that vista creates or xp won't go in properly
Jan 24, 2010 | Microsoft Windows XP Home Edition
I have 40gb hdd.need a partition scheme for windows xp such that i have 17GB gb for my games THANK YOU
Using the Windows XP installation disk, procede to install windows normally. In the windows setup you will get a list of options. Choose "C" to create partition. Create a 20GB partition. When that is done create another 20GB partition unless you plan on installing another Operating System such as Windows 7 later. If you want to keep XP and install Windows 7 at a later date on the same PC, then Set up 2 - 10GB partitions for Operating Systems and 1 - 20GB partitions for games. Make sure to install the games on the 20GB drive letter only so that Windows has enough space to run.
Nov 08, 2009 | Microsoft Windows XP Professional
Problem installing xp
You can install both wista and xp in the same computer, better for this to create new partition (resize ild one and free some space and create partition in its place) then install XP created partition (partition create is possible professional tools paragon partition manager, norton partition magic or other).
afrer restart only XP works, then insert VISTA install cd and "fix boot"
Here is brief discussion about this VISTA>XP or XP>VISTA.
Take care of drivers may some of them dont be created for XP if your pc is super new.
Aug 20, 2009 | Microsoft Windows XP Professional With...
How to install xp in HP Pavilion dv6 1030 us Laptop and how to repartition my C: drive especially I have still 150 GB free space in C drive Please help me in this case Thanks in advance.
get a winxp installer CD, you can repartition your drive on the first part of the winxp installation process. Prepare your drivers for your machine especially the network and USB drivers which you will need to copy and transfer files firstly.
If u meant of installing an additional OS like winxp to your extra space, you need a boot loader to switch between OSes.hope this helps
Aug 17, 2009 | HP Pavilion dv6-1030us Notebook
Installing XP after formatting Vista in Dell Laptop
When you install XP, when you select which drive you want to install it on, you also have the option to create and delete partitions.
When you're asked which drive you want to install on, instead of selecting one you need to delete your C partition (There are keyboard shortcuts displayed at the bottom to tell you how), then use the free space to create as many other partitions as you want.
Make sure you size your partitions correctly, because otherwise you would go over the size capacity of your drive.
After your partitions are created, you can install windows on C. After the installation is complete, make sure to format the other partitions (From My Computer, right-click a drive and select Format) so you can use them.
Aug 12, 2009 | Computers & Internet
Recovery partitions
You' want to set aside some space where to create these backups, they are generally 25% of the total drive space.
the assumption is that there is no data on the drive to save. During the install it will ask where you want to install windows, if there are existing partitions delete them all. Then create one partition and specify it to be 75% of the drive (or whatever you prefer). Leave the rest unpartitioned.
Select the partition you created to install windows on.
Once you have installed windows and all the drivers etc, format the rest of the drive in Disk management (part of Computer management in Control Panel). Finally install your favourite software to create backup restore images, and set it to save on the partition you created.
NOTE: you will still need to back up on some external media, if the drive fails all data will be lost.
Hope this helps
Feb 01, 2009 | Microsoft Windows XP Professional
HP FK784AA Pavilion Slimline s3650f Desktop PC Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
